LS1 Conversion
Old Jul 2, 2008 | 11:19 PM
817bigtex's Avatar
Car: 1993 Mustang,1989 GTA
Engine: 5.0 302,5.7 350
Transmission: AOD Built 500HP Mustang
Axle/Gears: 8.8 Rear Built 4.10's Mustang
LS1 Conversion
I have been doing research on the forum and see that it is better to swap in a LS1 in my 3rd gen then spending money on a 350TPI. Would you recomend it I have 5K to spend on hte Car?
Old Jul 2, 2008 | 11:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: LS1 Conversion
what is your goal? HP, drivability, mpg? you can build one hell of a 350tpi for that.
Old Jul 2, 2008 | 11:46 PM
Stephen's Avatar
Car: 87 GTA
Re: LS1 Conversion
$5k =
A stock, used LS1 or a modded out, gas guzzling TPI
Go LS1.
Old Jul 3, 2008 | 06:21 PM
817bigtex's Avatar
Re: LS1 Conversion
I just want a Stock LS1 with this http://store.summitracing.com/partde...5&autoview=sku
But I don't know if the Rear end will Last with the LS1. Unless I get it built
Old Jul 3, 2008 | 08:10 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: LS1 Conversion
Can't use the intake parts. So don't waste your money
Old Jul 4, 2008 | 12:38 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Re: LS1 Conversion
Go LS1 style... I'm speakin 6.0 iron block you can get one cheap now adays. It's a truck motor. you can get it cheaper than half the LS1 price.. Way better in the end. Rear would need to be upgraded if stock eventually but should be ok for a while. I still run my stock rear with my 5.3
Old Jul 4, 2008 | 03:28 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Re: LS1 Conversion
I went LS1 and never regretted it. Definitely the way to go, IMHO.
Old Jul 8, 2008 | 12:48 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: LS1 Conversion
just go efi ls something you wont regret it
the rear end in the car is the same pos 10 bolt behind that motor in an ls car
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
