starter help
Old Aug 4, 2008 | 07:04 PM
1988RSLS1's Avatar
Car: 88 black RS
Engine: 04 GTO crate LS1
Axle/Gears: 3.73:1
starter help
ok, so im still finishing up my project (CA legal 2004 GTO into 88 RS), but while i have a car out of the college shop (summer vacation hate it, comes fall hehe), im trying to get around the starter problem. I got Powermaster XS torque and it didnt clear the engine. I switched to one from Summit, looks like it fits, but it is so much different from other ones - gear actually sticking out from the mounting plate.plus the bolts are rubbing plastic cover on the bellhousing. i got a bad feeling about that one.I tried MSD one, which clears BUT the mounting plate hole for the starter doesnt match the hole on the plastic cover (it should be higher at least half an inch or so), otherwise it fits perfectly.
Mini is the only way to go for me, for longer ones would not clear exhaust.
What starters are you guys running?
Old Aug 5, 2008 | 06:12 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: starter help
why not just use the stock f-body LS1 starter?
Old Aug 6, 2008 | 07:00 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: starter help
I just bought this one, we'll see how it works...
Old Aug 6, 2008 | 08:53 AM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Re: starter help
I have the factory GTO starter, it clears the Hawks headers just fine.
Old Aug 6, 2008 | 01:22 PM
trakcar's Avatar
Re: starter help
F-body and GTO starter (and bellhousing) are different. If you have a GTO engine/bellhousing, use the stock GTO starter.
Old Aug 7, 2008 | 07:21 PM
1988RSLS1's Avatar
Car: 88 black RS
Axle/Gears: 3.73:1
Re: starter help
thnaks guys for replies..i was in starter hell for a while
Trakcar i came to that idea too...
V8Rumble thats the one i got, but i dont know, the way it sits when bolted one - it just doesnt look right. plus the bolts are terrible, dont use them, they almost broke the plastic cover for trans bellhousing (mine anyway) the outside one catches and drag on the plastic.
however it clears my modified edelbrock shorties. i guess i should try stock GTO one - one more starter in my collection wont hurt...
Old Nov 17, 2008 | 08:52 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: starter help
your going to need the gto starter..
it has its own different cone design for that gto bellhousing
Old Nov 18, 2008 | 10:18 AM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Re: starter help
I used this one too, so far no problems except I personally think the bolts are too short so I swapped those out. I am using the 4th gen f-body manifolds.
Old Nov 18, 2008 | 03:58 PM
1988RSLS1's Avatar
Car: 88 black RS
Axle/Gears: 3.73:1
Re: starter help
and they fit?what crossmemeber are you running?
i went with GTO starter - was able to get it for 180 through college shop.it works)
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
