hp estimate please
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
Re: hp estimate please
With no cam specs its hard to say but according to my desktop dyno you should be in the 325 hp range maybe 350hp with the custom tune.
Transmission: 4L80E/4L80E
You already asked once. I moved it to the LTX and LSX engine swap subforum because that's where we discuss LTx engines.
its the stock 94 f-body lt1 cam i got these specs from another sight:duration 230/208,lift .450/.460, lobe 116 ,hope that helps,the 325-350 hp that would be at the flywheel right?thanks for the reply,joe
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
http://www.dsm.org/tools/calchp.htm
http://www.fastcoolcars.com/hp_calculator.htm
Standard 20%+/- between chp and whp.
http://www.dragtimes.com/horsepower-...calculator.php
Stock 94 LT1 rated at 275 chp.
Add 50 hp (maybe) for your mods. 325 chp.
Less 20% gets you 260 whp.
260 whp in a 3650 lb vehicle might get you 14 sec at 98 mph.
Car: 1987 Camaro Iroc-z
Engine: 305 tpi
Transmission: t5
well stock i think the lt1s ran low 14s i think around a 14.2 or so, so with those mods if i had to guess id say youd be around 14 flat or so depending on suspension you could gain more, its not all in the amount of power your putting to the ground its how you put it to ground.
Engine: 305 tpi
Transmission: t5
Stock 305? cuz i got a best of 15.09 with my stock 305 stock suspension and my friends 350 tpi does a best of 14.8 all stock. and from what i see your lt1 is pretty much stock unless i missed something. so i would be happy with right around a 14
15.09 thats pretty quick for a stock 305 tpi auto,most stock 305 tpi auto's ive seen run 15.4-15.6,my 305 had stock bore full bolt ons,p&p heads, ram air ,stock suspension and no tune(hypercrap chip) ,yeah my lt1 is pretty much stock but i seen a stock lt1 trans am on youtube with only a cutout,tune and 3200 stall and it ran a 13.8@98mph and from what the 1/4 mile calculator i used said a car weighing 3440lbs with a whp of 260 would run a 13.7,but like i said well see this spring and i would be fine with a flat 14
