my LSx 87 IROC build
Old Nov 22, 2008 | 05:36 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
my LSx 87 IROC build now sporting new looks
this is my current build on my 87 iroc. been working on the car for about 5 years with the old tuned port set up but i decided to ditch all the maintnance and break downs and go with a lsx conversion with a 06 gto tranny that was adapted to my sbc. ditched the old school dash and went with a complete 02 dash and even got my FUEL gauge to work!!!
Engine was off 02 SS with 50k miles included
LS1 accessories power steering pump, TB, etc
New alternator
New seals
Port and polished TB
sent in oem harness to lt1wiring
Standalone extended Wiring harness and ECU
with basic tune
used
4th gen tank
modded feed return and evap
255 walbro fuel pump
06 GTO ls2 MN12 tranny and bell housing
06 GTO ls2 starter
LS7 clutch kit
New slave cylinder and master
Pro 5.0 short shifter
SPOHN LSx motor and tranny mounts
06 GTO CAI
C5 valve covers
MSD wires
Catch can
Gatorback belts
Summit aluminum radiator
Stock dual fan set up
Steel braided fuel line and Adapter Fittings
Auto meter adapter fittings for oil pressure and temp
TB Cable Non-TCS
02 SS ebony dashboard
Fuse relay box for ignition and 12v source
Switch breaker bar for ignition power
some small suspension work form the past
Still running the 4th gen rear drive train
3:42s and alum. Driveshaft
my process went from dropping in the engine pacing it butmostly workin on the dash .. cluster and electrical.etc
the last part was the harness and whole lots hours sodering and wiring!!!!
to start off heres the car
Old Nov 22, 2008 | 05:42 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Re: my LSx 87 IROC build
prepping the engine bay.
I started off by removing most of the wiring. Me and my brother have already experienced a ls1 swap in the past his his 3rd gen.
After hours of working on his car I gained a bit more experience and my set up was a bit more organized..
My engine was far gone I was ready to start prepping the engine bay for a better quality look.
My previous set up consisted of a cammed 350 mated with McLeod bell, mn12 GTO tranny and 4th gen rear differential
My intentions is to build a reliable 80s performance vehicle with the LSx drivability performance, yet fuel efficient, with modern interior and able to say I built this car.
I used esi data output for all the schematics for the 4th gen wiring.
Im attempting to run the evap and a fully functional cluster.
The process took a few months the only problem I came across was using a ls2 bell housing and finding the right starter. After researching the least expensive starter was the OEM Mitsubishi starter for lsx goats.
I purchased the ls1 with a k member and brake set up off ls1tech member.
As well as the fuel tank and dashboard.
Small appliances were supplied by the local parts store
All the fuel fittings and adapters were from others online or summit
Al work was done by myself with help of my close friends
And soon enough need some exhaust work for the y pipe
Old Nov 22, 2008 | 05:50 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
I see your in So Cal... what are you going to do about emissions? Do you have EVAP, 4 o2s, smog pump, cats, etc?
Old Nov 22, 2008 | 06:12 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i started off with dissembling the old dash . Cutting grinding and bending metal for a test fit on the new dash .
Soon moved on to the 4th gen vents these fall right on top of the 3rd gen unit.. Modded and cut for future usage.
After painting the engine bay I left it plain and simple.
Main red wires to control ignition supply.
the instrumental work was done with extending wiring and merging the 4th gen cluster plug mostly color matched
Old Nov 22, 2008 | 06:55 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i used two power distrubution blocks. from the battery as the main 12v source and power with ignition.
before with tpi wiring
after with Spohn motor mounts in place.
using the ls7 clutch kit
Moved back to the engine and worked on the smaller components
Used autometer adaptor fitting for the individual gauges for my oil pressure and water temp. aside from the cluster .
Used a summit radiator and hoses from AutoZone to run the cooler routed back to the power steering pump unit fuel rail fittings and evap controls etc,
Here I used 90* swivel fittings from the local speed shop
As well as compressor fitting which I used to shorten the 4th gen fuel feed line
Old Nov 22, 2008 | 07:10 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Catch can and
Present intake set up with shield
A clearance shot with with the stock k member. And moded/bent brake lines.
Old Nov 22, 2008 | 07:12 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
No one yet? Well I think it looks awesome. Keep up the posts and pics.
Old Nov 22, 2008 | 07:17 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Over view of the 4th gen fuel tank
I extended the wiring from the evap canister module, and the sending unit up to the dash .a whole lot of wiring.
Re worked on the quick disconnects and added fuel hose with some good clamps. These fuel lines were routed up by the rear area united to the fuel filter and hard lines to the front on the engine bay.
I used the walbro fuel pump a few mods. And this is what it looked like with a opening in the cargo area for easy access sealed up pretty good.
Old Nov 22, 2008 | 07:21 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Cut 2.5 inches off the filler neck to clear the fuel door
The sending unit harness extended sodered and united to the control plugs
Once I received my harness from lt1wiring . Couldn’t be easier.
Pictures below everything was test fit and included with the obd2 port, fan relay, fuel pump relay and extended 2.5 feet for easy installation
Just scaring u guys a bit.. jk a bit unorganized but wire loom can take care of this.
The rest of the wires on my cluster plug consisted off the signal off the harness vss, oil temp
Old Nov 22, 2008 | 07:29 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
WOW awesome job thus far, I have to tear my engine out and give it a once over, long story short I've either spun a bearing slung a rod or possibly blown headgasket and over heated doing god knows what type of damage. I will start to tear it out tomorrow after work, but I dont know how long it will be to inspect the engine, and might have to jump into the 350 build I have been thinking about.
Quick financial question for you terr, ball park about what do you have in your set up. I doubt that I'll emulate it at this point and time, but it'd be nice to see what a true "sho 'nuff" bad *** motor/tranny combo can be had for.
Old Nov 22, 2008 | 07:37 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
The most time consuming part of the build process was wiring. Bit complicated but easy to accomplish with experience and patience.
All the schematics found online were printed out by my brother from esi, thirdgen.org and ls1tech. for his lsx conversion on his z28 and from that we accomplished another build.
https://www.thirdgen.org/forums/ltx-...983-z28-h.html
Somewhere along routing the wiring for the fuel I got lost. My odometer turned on and a lot of unnecessary light were on.
Within time ill take care of that
Car cranked over yet has to be tuned
I will currently be working on my exhaust fabrication due to the fact that I am using stock manifolds. o2 sensor bongs in place and maybe work with a 4th gen y pipe that I have.,
Current pictures of my main cheerfulness. Fully functional gauges and soon to finish off the rest of the missing pieces
i dont have too many data scans. this is a quick overview of the build. i might leave some question unanswered but ill keep you guys updated once i gather up my info
Old Nov 23, 2008 | 12:59 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Another schweeeet build by you guys. Well done!!
Old Nov 23, 2008 | 01:56 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
You are using the gto tranny correct? Did you have to modifiy the shifter location or did you set it back farther than normal? It looks like it lines up well with the center console.
Old Nov 23, 2008 | 06:28 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
thanks guys.
i will be workin with oxygen sensors. and evap
soon enough i will try to do my own harnesses.. lol
i disassembled the gto shifter and dropped in a 4th gen pro 5.0
the gto shifter falls a bit back
Old Nov 23, 2008 | 06:57 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Did you exchange the gto shifter cup bushing with the firebird/camaro one or does the 5.0 shifter use the existing gto shifter cup bushing. This is the piece that requires you to remove a roll pin in order to replace. I guess that is what I was trying to ask.
Old Nov 23, 2008 | 07:28 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
how are you getting by emissions with L/T and no Air pump?
Old Nov 24, 2008 | 01:01 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
the complete gto unit was over exaggerating that came off. the f body shifter sat in place.
as for emission its still in the process im barely getting to the exhaust work not sure where im headed towards.
Old Nov 24, 2008 | 04:08 AM
007BALT's Avatar
Car: 91 Red Z28 G92 Spohn Suspn
Engine: 6.0/L92 Supercharged. Fully Built.
Transmission: 6L90E + G8 Shifter
Axle/Gears: 3.08
wow, nice. I must say im tempted by that Dash.
Nice job. Keep us posted on what you did on the emissions.
Old Nov 26, 2008 | 02:30 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
the dash is actually pretty easy as you go. the wiring gets a bit complicated and the headlight switch has to be worked with . ill be working on the side pillars or a corner piece mold to fill in the gap.
Old Nov 27, 2008 | 09:34 AM
ssean92's Avatar
Car: sold
Realy nice build
Old Nov 27, 2008 | 11:33 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
you my friend get a big gold sticker for the day! lmao! nice too see some useful diagrams on the dash wiring finally! im bout to do the swap myself this will save a whole lot time.
Old Nov 27, 2008 | 11:57 AM
one more question do you need the 4th gen tank to make the fuel gauge work properly? if so this would be my best time to do it i just finished up the rear suspension nothings even torqued yet so itd be super easy to drop it back down.
Old Nov 27, 2008 | 10:49 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
yes im using the 4th gen plastic fuel tank.. 4th gen lines with a few mods. bends, shortened, compressor unions, good clamps and good fuel hoses.
Old Nov 28, 2008 | 12:41 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
looking sweet I love how you went with the camaro dash instead of the firebird setup most people opt for I've always admired your car great job
Old Dec 1, 2008 | 01:23 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
by the looks of it im having some delays..
as soon as i get my ecu its goin to a muffler shop .. hopefully some one can fabricated some decent exhaust work till i get some hawks headers and a fabricated x member such as the drews.
Old Dec 1, 2008 | 05:32 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
My Drews cross member required me to elongate the bolt hole openings where the bolts go into the subframe as well as elongate the tranny bolt opening. When I got the car the drews was already on there but the tranny mount could not be bolted up without a crapload of stress on the tranny mount.
I also had to clearance the radius opening that the exhaust pipes pass thru. If you have the ability I would suggest trying it yourself (re:ghettocruiser). It looks like Justin's crossmember has a lot more clearance for the exhaust pipes than my drew's did. If you plan on running 3 inch pipes off the LT's into a Y you will want all the room you can get anyway.
By the way the build looks awsome.
Old Dec 4, 2008 | 06:28 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
ran into some problems with the 5th gen pro 5.0 shifter.. have to reasearch and see how i can use a 4th gen shifter with the gto mn12.
im looking for a 4th gen shifter cup .
Old Dec 4, 2008 | 09:27 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
All these people doing what I want to do (and doing it well). I'm telling you, working through college is really over-rated.
BTW, you have some more pics of your car? I'm thinking about replacing my ZR1s with C5 Z06s.
Old Dec 4, 2008 | 09:48 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Old Dec 4, 2008 | 10:03 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
hey btw i wasnt using it correct.. it was when i was using the sbc and the gto shifter.. once i tried to put it into gear i realized it.. now i have to look for the fbody cup
i was so confident that i didnt have to mess around with it. because they look so identical.. i want to use the pro 5.0 though
Old Dec 5, 2008 | 05:29 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
O ok right on. Yea i thought you stumbled onto something when you said it worked fine. I guess there is no free lunch on this one. I haven't swapped mine out yet but when you compare the stock gto and bird shifters side by side you see the difference. Check with six speeds inc or d&d performance for the replacement piece.
Old Dec 5, 2008 | 09:51 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
updates.. drove the car on open exhaust today. lol
filled up .. gas gauge is functionally working!!
i went back to the gto shifter .. but its too short so ill be lookin for the fbody cup shifter..any other word usage for this? looks like i need some more researching.. cuz i couldnt find them. only articles on it. when i called theses places they didnt know what it was..
thats gto placed which is set further back .. and the fbody to the side a bit shorter. ..
Old Dec 5, 2008 | 11:56 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
man....you have such a nice car....i will be doing a lsx swap my self in the future
Old Dec 6, 2008 | 12:32 AM
hdxl92's Avatar
Nice ride,righteous project.I got an 88 IROC I've owned for 12 years.Hope to do an LS swap in the next year,maybe two. Always looking/reading others projects,getting ideas/info.Great job with the dash work.Enjoy!
Old Dec 6, 2008 | 08:30 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
If you were to slot the mounting holes on the base of the F-Body shifter, it would have worked fine.
I used to run a SLP(HURST) shifter in my GTO. Had to elongate the mounting holes on the base and it worked great.
But the new cup is just as easy and no mods to the shifter base.
Congrats on a great looking build!
Old Dec 6, 2008 | 11:32 PM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Wow, great job, and good to see some wiring diagrams too.
Old Dec 7, 2008 | 01:26 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
If you dont have the HVAC hooked up why did you have the duct work all set up? That lack of HVAC is the thing holding me back on the 4th gen int swap.
Old Dec 7, 2008 | 04:31 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
updates.. got a y pipe fabricated.. good for now.. other plans in the near future. looks like the power steering fluid was boiling or idk i can hear my pump .. sounds like a ford. lol ill check up on that tmrw.. ride quality is 100x better than sbc and dash makes me feel as i was driving a completely different car. . .. dash fully functional with some abs inop lights on ..and my brake light.. ses.. take care of this later.. as for the hvac control will be added when i find all my ac accesories .blower motor.. hoses.. and wiring data. etc
Old Dec 9, 2008 | 06:16 PM
dust3r's Avatar
Do you know what exactly the guys at lt1wiring.com removed from your wiring harness? Did they remove two of the 4 o2 sensors? I have an ls1 that I plan on sticking in my 86 Z28, but I will be keeping all 4 o2s, evap, air pump, 4th gen tank, etc.
Old Dec 10, 2008 | 08:45 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
its a standalone unit. with vats delete etc. your able to crank over the car with just a few wires.. i have a illustration on their work . they do not remove the 02s.
Old Dec 10, 2008 | 09:32 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Dude that is one beautiful car! That is a show winner! Their isn't one thing that is bad on that car it is perfect. Awsome job man!
kevin
Old Dec 14, 2008 | 06:59 AM
  #42
wjiroc86's Avatar
Car: 1989 RS
Engine: 305 tbi, junk, freakin slow!
Transmission: 700r4... holds up =]
Man i love that car, it should be on fire its so hott lol...
As soon as i win the lottery ( i keep dreaming hahaha) im gonna do an ls7 =]
Old Dec 15, 2008 | 07:23 PM
  #43
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
so far so good. Ive been driving the car. about 300 miles already. car idles good runs really cool. and rides better than before the car feels pretty light
my friends dad was able to fabricate my stock seat sliders onto my passenger vette seat.. il be attempting to do the same to the driver side.
here some snaps of her stance
Old Dec 16, 2008 | 06:43 AM
  #44
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Got any pictures of the pass. side vette seat mounted up? Im curious to see how those look in there.
Nice work on the car! Looks really good! Nice stance, nice color, real clean... great stuff!
J.
Old Dec 16, 2008 | 06:19 PM
  #45
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
J.
thanks..
well heres a few.. they got the job done. im still ganna work on the driver side
i need new seat belts also .. and put on the fbody cup . pro 5.0 and shifter boot.
Old Dec 16, 2008 | 06:27 PM
  #46
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
some interior shots..
im using the gto shifter.. dislike it. but im driving the car. and i love it..
i just received the regular fbody cup for the fbody shifter
and heres a quick vid.
Old Dec 16, 2008 | 06:42 PM
  #47
Doc_G's Avatar
Car: 87 Trans Am
TPI man that car gives me wood like you wouldn't believe. Sorry to be crass, but I've no other way to explain to you how nice I find your car.
Can you link me to some good pics of the dash as it meets the windshield. I'd like to see what it looks like from inside and out if possible. I didn't see any that I'm looking for in the above posts.
Old Dec 17, 2008 | 06:49 PM
  #48
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Where did you end up finding a shifter cup from? Just curious. The shifter doesn't look too far rearward in the console. You still don't like it though?
Old Dec 17, 2008 | 07:18 PM
  #49
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
Nice car....very clean!!!
Old Dec 18, 2008 | 11:13 AM
  #50
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
thanks guys. well i got almost everything together.
maybe looking into a suspension package for the new year.
as for the f body cup . i found it in the local vendors from the tremec website.
helped out a lot !
