lsx manifold options
Old Nov 26, 2008 | 06:51 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
for those who used 4th gen cast manifolds for your ls swap how did you guys work with the regular spohn tranny crossmember.
this is what i am starting off with
any pictures out there? of a complete set up .. catted or non catted i just need an example before hand
Old Nov 26, 2008 | 07:13 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Re: lsx manifold options
such as kubus build
Old Nov 26, 2008 | 08:46 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
any one? ??
Old Nov 26, 2008 | 10:57 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Good question! At this point (before I know anything ) I'm planning on essentially duplicating the factory setup, but that really depends on where the headers come out...
Old Nov 27, 2008 | 10:46 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
did some browsing couldnt find too many people with manifolds..
but heres a non drews crossmember set up
Old Nov 28, 2008 | 11:54 AM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
mine is literally straight piped back under the crossmember, hammered in where it gets close. I'll find a picture or 2 of it. It's relatively low, but i live in FL so its all good
Old Nov 29, 2008 | 11:49 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Are you using the stock k-member? With a Spohn I am taking the exhaust the stock route. If interested I hope it will be complete in 1-2 weeks
Where did you get the flanges? I haven't found the larger one yet and could use a source.
Old Nov 30, 2008 | 11:59 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
im using spohn k member.. i had those fabricated about 1/4 inch thick
Old Nov 30, 2008 | 04:35 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I may not be anyhelp since I made my own crossmember (double hump) I made my flanges myself. I used 3/8" steel and traced out the shape. then I found the center of the hole drilled it and used that to install a bolt and used the lath to cut out the rest of the center. drill press on the smaller holes and a band saw for the shape.
I used 3" mandrel pipe all the way from the flanges to the catback
Old Dec 1, 2008 | 05:30 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
any pictures?
Old Dec 1, 2008 | 05:45 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
In order to pass the REF inspection, the cats need to be in the same location as the LSx Year you got it from. Then you build from there
Old Dec 1, 2008 | 06:00 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
my main concern right now is working around the piping as well as having a sportline srpings.
Old Dec 4, 2008 | 02:12 AM
Engine: ls1, LB9
any pictures?
I can't find them. they reall were not good pictures anyway
Old Dec 4, 2008 | 08:30 AM
Saleen85's Avatar
I can take some pictures of my y-pipe, but it's no longer on the car. I ran factory manifolds with a stock k-member and spohn crossmember.
Old Dec 4, 2008 | 11:35 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
saleen85
that would be great..
Old Sep 30, 2009 | 10:04 AM
screeminchicken's Avatar
looking for details and pic for this setup.
like to know where did you guys get the 02 bung plugs ? whats size and thread
and some good pic of how the manifolds where extended to the y-pipe. preferably stock K-member and 4l60e
Old Sep 30, 2009 | 02:26 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Since this topic has been bumped already I am gonna go ahead and ask if anyone knows if those flanges can be bought? I know TPI TERR said he made his but I don't know if I have the resources to make my own lol. Also, anyone ever used stock cats with the factory manifolds? I am not sure how I'm gonna mount my cats if I go aftermarket if I want to keep them close to the manifolds like the stockers.
Old Sep 30, 2009 | 02:36 PM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
you can buy the o2 bungs at carquest. the part number on the bag they came in is 4962. 18mm o2 sen. boss. i just welded mine on today. i will post pics this weekend.
Old Sep 30, 2009 | 02:51 PM
whats did u use to plug the exisiting holes in the manifolds ?
Old Sep 30, 2009 | 04:43 PM
Pocket's Avatar
Car: 91 Trans Am
They offer plugs for O2s as well
Talk to your local exhaust shop
Old Sep 30, 2009 | 06:06 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
I have a set of cut off flanges from a truck not sure it there the same but if some one wants them I can dig them out.
Old Sep 30, 2009 | 07:19 PM
Shift06's Avatar
If you got a picture of them I might be interested.
Old Sep 30, 2009 | 08:25 PM
Pocket's Avatar
Car: 91 Trans Am
The oddball flange is different from car to truck manifolds. The semi-symmetric appears the same
I have both to compare
Old Oct 3, 2009 | 08:11 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
heres a pic of where i put my 02 bungs. i still have to get a cap for the old hole. this should be temp. i am planning on running longtubes. i should get my car started in the next day or 2 . i am hoping to take it out for a couple of shakedown runs and put it up until spring. hopefully i figure out by then what i want to do with the exhaust.
Old Oct 3, 2009 | 09:40 AM
Pocket's Avatar
Car: 91 Trans Am
Why weld a bung to the cast manifold when you can move it 6" downstream to the Y-pipe?
Old Oct 3, 2009 | 06:02 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
this is all the exhaust i am going to have for awhile. i am leaving my exhaust off until next spring. i just wanted the o2 connected while break my engine in.
Old Oct 3, 2009 | 11:09 PM
Pocket's Avatar
Car: 91 Trans Am
Put a short section of pipe on the end of the manifolds. Open shortys/manifolds is a bad idea
Old Oct 4, 2009 | 10:12 AM
V8Rumble's Avatar
Old Oct 7, 2009 | 09:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That 02 is only reading 1 cylinder. On the other hand, sticking it into a shorty tube hanging off the manifold may not give you the most accurate results either, because it might get some outside air.
Why not fab up at least a y-pipe for now?
Old Oct 7, 2009 | 11:24 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
The way we used to do this on our oval track cars was put cheap spray paint on the pipe. Run a race. Wherever the paint was melted off too we would cut the pipe there and/or make a new one that same length. Old school farmer tech but they all swore it was the way to go. Dunno but thought Id mention it
Old Oct 10, 2009 | 03:02 PM
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Sorry it took so long and not sure if your still interested, and the oddball flange is bent any way. but hear is a pic. It looks like the gasgets are difrent to. Oh well.
As for the origanal topic I don't think you can run the exaust in the 3rd gen stock location because the oil pan is in the way of getting the exaust over there the only option seems to be running along the trans in the tunnel.
Old Oct 12, 2009 | 05:27 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
im still having leaks with my flanges that we made.
im using felpros. any of you guys have problems with felpro?
i might go pick up some gm ones.
customblackbird
Oct 1, 2015 04:30 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
Rally Smith
Sep 14, 2015 06:59 PM
