Whats the differences in (93-94) & (95-97) LT1 starters???
Old Jan 20, 2009 | 10:18 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Whats the differences in the (93-94) LT1 starters to the (95-97) LT1 starters??? and why do they have two diffrent part numbers? is there a difference in wiring or something? because im replacing the one thats currently on my gen1 block and i belive the one thats on there i got off a 94 LT1, iv seen the (95-97) LT1 starters are a bit cheaper is there a reason? would either one matter?
Old Jan 20, 2009 | 05:00 PM
FueledSoul's Avatar
Re: Whats the differences in (93-94) & (95-97) LT1 starters???
bump, kinda need one soon thanks...
Old Jan 20, 2009 | 05:10 PM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
the vette lt1 starter will work and is cheaper than the reg capricelt1 starter and is gear reduction unit.
Old Jan 20, 2009 | 10:38 PM
FueledSoul's Avatar
thats not saying much... i mean theres gotta be a reason why theres a slip in model years?
Old Jan 22, 2009 | 04:01 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I dont have a response but I do have an additional question that may help you and others as well...
I have a 94 LT1 with a 95 style cam/opti and am running a 97 T56/flywheel
which starter would you use? which high torque mini starter is the best? Can any be interchanged with the different years?
Old Jan 22, 2009 | 05:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I have a 97 brand new lt1 starter which won't work with my new motor combo and it will work on all year lt1s. I looked into the online catalog and my part number is listed 93-97 which will also work on all 153 tooth older sbc as well. I paid 160, and would take 100 shipped if any of you were interested. I started the old motor probably 10 times total and the unit looks brand new. It's a bosch starter.
Old Jan 23, 2009 | 01:21 AM
FueledSoul's Avatar
So i pulled my intermint starter of my engine tonight its a reman OEM No: 9000773 stater i looked it up and it says
PG260M Series Starter for Delco
1.7 kW, 12 Volt, CW Rotation
Design: PMGR (Permanent Magnet Gear Reduction)
Drive Teeth: 11
SERIES:FOR DELCO PG200/250/260M
LESTER NO: 6442
WAI No: 2-1481-DR
OEM No: 9000773
I'm pretty sure this is a b-body starter, it worked on my 305 with the stock flywheel and starter bolts and i didn't have to shim anything. . . what f-body starters can i use thats going to work then??
Old Jan 23, 2009 | 08:44 AM
xpndbl3's Avatar
Car: 1984 Z28
I posted the answer right above your question, any 93-97 lt1 starter should work no problem. I asked for a 95 camaro, but the catalog only shows one starter for all these years. Hope this helps, and if you'd like mine before it hits ebay let me know.
Old Jun 30, 2009 | 06:16 PM
renemedrano842's Avatar
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
what is the most compression ratio that the lt1 starters will turn.
midge54
Dec 27, 2019 04:14 PM
mhatfield 14
Oct 24, 2015 07:48 AM
midge54
Aug 29, 2015 09:51 PM
5spdcamaro
Aug 28, 2015 02:12 AM
milk
Aug 10, 2015 06:26 PM
