lt1 swap
Old Mar 17, 2009 | 01:20 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Engine: LT1 w/lt4 hotcam kit
Transmission: stage 3 700r4
Axle/Gears: posi 3.42
lt1 swap
i have looked and looked and cant find a harness to do the lt1 swap into my 91 z i know someone makes it i just wanna be able to buy a harness and plug everything in if ne one has a idea please help me out here
Old Mar 17, 2009 | 02:47 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: lt1 swap
engine swap and "plug and play" don't really go hand in hand. you'll have to have someone custom build it to match the year of your donor car and the exact year/model of your car. There were many small changes over the years that have to be accounted for. And you will pay quite a bit for someone to do that work!
Old Mar 17, 2009 | 03:03 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: lt1 swap
Here's just one vendor, Howell.
http://www.howellefi.com/customer/pages.php?pageid=4
Here's another, Hot Rod Lane.
http://www.hotrodlane.cc/
They make and or sell harnesses + ecm's.
Good luck
Old Mar 17, 2009 | 11:38 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: lt1 swap
Along with those mentioned is www.speartech.com or www.painlessperformance.com they are essentially four wires to splice in..
Old Mar 17, 2009 | 11:47 PM
burnrubber9095's Avatar
Re: lt1 swap
check painless wiring
Old Mar 19, 2009 | 03:58 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Re: lt1 swap
in the lt1 swap guide this is what is says
"You will need a different fuel pump (electric). SLP's headers have worked for many people on LT1's. The painless wiring harness is highly recommended for ease of installation, it's part # PRF-60501 in summit and is $350, it specifies a reprogrammed prom. Hope this helps."
the only thing i can find on the number is a emission kit for 71$ i know that the posting is 7 years old mite have somethin to do with it. but i still cant find i harness that will plug into my 91 and control the 93 lt1
Old Mar 19, 2009 | 05:09 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: lt1 swap
You won't, the painless kit is basically an LT1 harness that has the ends cut off to splice in, the Howell harness will be the closest thing to what you're looking for....but you're going to end up splicing some wiring in.
And yes, you'll have to change the fuel pump since your's is a TBI, it won't put out the fuel pressure needed to run the LT1.
Old Mar 19, 2009 | 08:28 PM
92Forumla's Avatar
Car: 2017 2.0T Camaro / 1989 IROC
Engine: LTG / L98
Transmission: Tremec TR 3060 / 700R-4
Re: lt1 swap
This is what I am doing as well. 94 Camaro LT1 into a 1992 Camaro LO3. What wires need to be spliced to utilize the Howell harness?
Old Mar 26, 2009 | 01:52 AM
BiggTrav's Avatar
Car: 92 zo3 z28
Re: lt1 swap
well i sold my rs and bought a 91 z28 with a 305 tpi and thats the one im gonna put the lt1 in another idea i was wonderin is if i cant get the lt1 wired correctly will a tpi intake bolt up to it and work properly i was just wonderin if ne one has tryed it before
Old Mar 26, 2009 | 06:27 AM
Klortho's Avatar
Car: 1987 GTA
Re: lt1 swap
You would be killing the engine, keep the LT1 like it is supposed to be, check out a couple of the stickies about the wiring in this forum and you should come out ok.
Old Mar 26, 2009 | 04:55 PM
Re: lt1 swap
try an inline fuel pump its alot easier without the hassle of getting into the gas tank
Old Mar 29, 2009 | 06:58 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: lt1 swap
TPI on an LT1 would be defeating the purpose.
As for the harness, i used speartech, and you have to splice about 4-5 wires into the bulkhead connector, and a couple more under the dash. Very simple. You have to use the power and fan stuff from your old harness.
I knew nothing about electrical work when i took on that project, and i had 0 issues, aside from pluging stuff in the wrong sensor on the engine...
Old Mar 29, 2009 | 07:47 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: lt1 swap
I am also doing the LT1 swap in my LO3 whats a good easy fuel pump? Someone said something about a inline one?
thanks
kevin
Old Apr 1, 2009 | 08:22 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Re: lt1 swap
ya i see harness aren t cheap either i really dont have the money to do rite now but the tpi motor is junk and i know my lt1 is solid so im gonna attempt to make the lt1 harness work i know people have used the lt1 harness so i have the harness that came with the motor and i noticed that it actually umplugs and one half goes to the ecm and the other half goes to the fuse box but what im wonderin is if i can just cut and splice the lt1 harness into the cars harness i figured someone wuld have a dummies guide to wiring a lt1 but havent found one yet
Old Apr 1, 2009 | 08:58 PM
Klortho's Avatar
Car: 1987 GTA
Re: lt1 swap
Have you checked the wiring for dummies sticky in this forum?
Old Apr 1, 2009 | 09:10 PM
BCdawg57's Avatar
Re: lt1 swap
You can absolutley make the harness you have work. The reason i didnt is because a few of the wires were looking a little less than trustworthy and i was paranoid about losing my investments in a car fire. So i forked over some $$ for some peace of mind.
Like he said above look at the wiring for dummies sticky.
Old Apr 1, 2009 | 09:29 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Re: lt1 swap
ya i seen the wiring for dummies sticky but i really have no clue on what there talkin bout
Old Apr 2, 2009 | 04:34 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: lt1 swap
There are 4-5 connectors on your LT1 harness that you have to splice into your chassis harness. The wiring for dummy thread is describing the wires on each connector. You need to get power to 4-5 of the wires on those connectors. You can add a small fuse block or you can reuse many of the fuses already wired in your car (injector 1 & 2 for example). The remaining wires will be for ALDL, gauges, and fan/fuel pump relays.
It does seem a little daunting at first, but once you get started its not that bad. I just got on shbox.com and got the specific wiring connectors for the year of LT1 I have. Then I poured through the different wiring diagrams specific to my GTA and started taking notes in a spread sheet to make it easier when I started cutting and splicing.
I've never used a painless harness, but I'm guessing it would just eliminate the first step and give you some nice pretty marked wires that you would still have to research where and how to splice into your existing harness.
Old Apr 2, 2009 | 06:12 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: lt1 swap
http://www.camaroz28.com/forums/showthread.php?t=474185
I like this one it's a little better layed out (to me anyway). There will be some more wires you will need to look over and see if you do/don't need to wire them in.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
