Stock 700r4 shift cable work with 4L60E?
Old Apr 24, 2009 | 06:07 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I'm guessing it should. My cable can pull the trans out of park, however it can't push/pull into any other gear once its done that. I'm assuming my cable is shot and I'll need a new one. I'm not sure if it makes a difference, but I'm using the stock bracket that came with the 4L60E? Do I need a 700r4 bracket?
However, I just thought I'd post this question in case they are different, and I've just never heard of anyone changing the cables.
If its a stupid question, feel free to ridicule me. But I'm hoping for a real answer.
Old Apr 24, 2009 | 06:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Stock 700r4 shift cable work with 4L60E?
http://shop.advanceautoparts.com/web...ter%20cable___
Old Apr 25, 2009 | 06:18 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
I was wondering the same question but then again I went a different route..I'm using the stock cable and the stock bracket that came with my LS1/4L60E..The cable is a perfect fit, its long enuff and fits in the stock location..The only thing I changed is the way it mounts to the acutal shifter (no biggie tho)..good luck..
Old May 1, 2009 | 04:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
My 700R4 unit works just fine on my 4L60E.
Old May 22, 2009 | 05:36 PM
mavsdad's Avatar
my 700r4 cable will putt the 4l60e in gear but then it wont go back to park anyone else have this problem
Old May 22, 2009 | 06:27 PM
Your cable is probably broke up by the center console. Mine broke too, had to replace it. Wasn't hard.
Old Jun 28, 2011 | 06:09 PM
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
where did you mount the stock bracket my bracket is off it original place for the shifter cable on the tranny
Old Jun 30, 2011 | 12:48 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
How did you guys mount the 4l60e shifter ojnto the stock shifter? I'm thinking of drilling the tab on the shifter and running a bolt/nut to secure it.
Old Jun 30, 2011 | 01:07 PM
I used my stock replacement thirdgen shift linkage cable.. It bolted right onto the 4L60E shift linkage arm on the pan.
Old Jun 30, 2011 | 11:07 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
silly, mostly on topic question - anyone know what the nut size is that attaches the shift linkage/bracket to the transmission? mine was missing and now i feel like i've tried 1/2 a dozen sizes without any luck. sorry for getting a bit off topic...
Old Jun 30, 2011 | 11:21 PM
Pocket's Avatar
Car: 91 Trans Am
Trans shifter shaft M10 x 1.5
Cable nub end M8 x 1.25
http://www.compnine.com/index.php?u=...04&grouptype=B
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
stalkier
Aug 7, 2015 04:49 AM
