LT1 water pump issues
Old Jul 29, 2009 | 06:26 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Issue 1: Small issue w/ the LT1 swap. Motor is out of a '95 Camaro, but the water pump is from a Caprice/Impala SS LT1. I plan on using the standard 3rd gen coolant reservoir and radiator, but have noticed that the Caprice's use the coolant bottle w/ the pressure cap on it. Do I need this type of bottle if using a Caprice LT1 pump? I know I can use the 3rd gen bottle and radiator w/ a Camaro LT1 water pump. I just happen to have a Caprice one on hand.
New Issue 2: Water pump bolt snapped off. After drilling the broken bolt in the block, I tried an EZ-Out, which has broken off as well. The drill bits won't drill into the EZ-Out. Eh, it never ends. I'm out of ideas.
Old Jul 29, 2009 | 08:57 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 water pump issue
It's the same waterpump, the caprice doesn't have a radiator like the one i the 3rd gen, or 4th gen.
Old Aug 26, 2009 | 11:55 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: LT1 water pump issues
Bump-New Issue
Old Aug 27, 2009 | 08:18 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Any chance of getting a welder in there to tack to it?
Old Aug 27, 2009 | 09:08 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I tried welding a nut to the broken bolt, but that did not work. I ended up using my Dremel w/ a carbide cutting tip. I was able to grind out the broken EZ-Out and bolt. A bit time consuming, but I was able to save the threads.
Old Oct 10, 2009 | 05:42 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Ended up using the Camaro style water pump and installed the reseal/bearing kit (purchased from the h2opumpman). Time to move on and get the trans in there.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
