What Oil Pan?
Car: 2006 Pontiac GTO
Engine: 6.0 (383)
Transmission: A4
What Oil Pan?
Got an LS1 for my 91 camaro but it has a truck oil pan. I understand a oil pan from a 4;th gen camaro is a good fit, but from what years? I assume froom the one post i read that a LT oil pan will not work. What other options do i have?
http://cgi.ebay.com/ebaymotors/Moros...item1c0caad02a
would this work?
would this work?
Transmission: 4L80E/4L80E
Any year LS1 f-body, '98-'02.
Can't say I've heard much about aftermarket pans.
I assume by "LT" you mean "light truck".
Engine: 6.0 (383)
Transmission: A4
Re: What Oil Pan?
Sorry, I meant an LT1. Thanks for the info, thats what i thought but just wanted confirmation, i tried reading through all the post but talk about information overload.
Engine: Cammed 6.0L LSX
Re: What Oil Pan?
You're going to want to get an oil pan from any year LS1 fbody from 1998-2002. Aftermarket, I'm not sure, but I can tell you the GM pans will work fine.
LT1 is Gen II, and you can exchange pans with the later Gen I SBC's with one-piece rear main seal.
But, the LS engines are Gen III, share next to nothing with the earlier SBC's. Oil pans are completely, entirely different.
