Anybody use a 4L80E instead of a 4L60E for swap?
The 4L80s is a heavy duty version of the 4L60E that was used in trucks and SUVs, just wondering if anybody has used one of these and whether or not there were any installation differences????
Car: 87 GTA
Re: Anybody use a 4L80E instead of a 4L60E for swap?
It is my understanding, that the 4L80E has a bigger case & has some interference issues with the floorpan, that requires some "massaging" of the floor to fit them in.
Transmission: 4L80E/4L80E
The 1-3 gearing of the 4L80E is identical to the TH400 http://www.tciauto.com/Products/Tech...ear_ratios.asp It has overdrive and torque converter lock-up as well, and is electronically rather than mechanically controlled.
It is bigger and heavier than a 4L60E. Dimensions available here http://www.tciauto.com/Products/TechInfo/trans_dims.asp
I don't recall seeing anyone documenting an install of one in a 3rd gen.
I picked up an LQ4/4L80E combo that I plan on installing in the '57.
Car: 1991 Trans Am
Contact Maxx Mitchell on here. He has a 4l80e in his car behind a turbo 5.3. Amongst some of the problems he had was a very low hanging oil pan for the transmission. It works but hangs pretty low IMO. Especially if you ever wanted to give the car the correct ride height.
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Also be warned you need some extra computer tuning to have it control the 4L80e.
Look onto LS1tech's automatic transmission board, theres information on a 4L80 running behind a motor originally equiped with a 4L60
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
you could also buy a stand alone computer to run the 4L80E. that's what i did for my install on a '72 Camaro. the computer stuff is just as expensive as the transmission though. i had to get a TCI tranny control unit, 4L80E wire harness and a TPS sensor to use it. all the tranny control stuff was about $1300.
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
I am just finishing my 6.0l/ 4l80e swap. it goes pretty much right in... make sure to cut off the ears of the bell housing.
-You have to make a cross member.- ( I will take some pics of what I did)
- You have to use a diff. torque arm set up = I am using jegster tunnel mount
- there is a flexplate dance if you have anything other then 6.0 factory setup... (not hard, but I didn't have to deal with that)
- the multi pin trans control harness is really close to the end of the frame railing, that runs pigin toed towards the rear. (tranny mount rails)... but it does fit... ( I will take some pics)
- have to use a t-400 yoke and a cross over u-joint... I will get numbers for you all.
- shift bracket fits like crap, I moded mine to bolt up and I think its fine, not sure yet
- Lokar dipstick is the way to fly, not cheap but works nice for me
- HEAVY TORQUE CONVERTER, after market is the way to fly much lighter, I am starting with the factory one.
- I didn't have to "massage" anything
The pan does hang low, it does ride below the trans rails, I have pro-kit Eibachs and I will also get pics of that. ( I think it will be fine, my duel 3" pipe will hit first...lol)
I think it would be easier to run the truck PCM 6.0/4l80e, and tune down to what ever liter motor you are useing. (I use Hptuners here) that would be more useful in the long run. and I am assuming that you are running a LS1 or Lt1 because you posted here. Judgeing my your sig, I hope you already have something like that.
Car: 1984 Z28
Engine: none
Transmission: none
I'll have to look around, but I know I've heard of people manually shifting the 4L80 to avoid using any computer at all.
Car: 1984 Z28
Engine: none
Transmission: none
Yep thought so, first thing I found when I searched for performance 4L80 on google:
http://www.transmissioncenter.net/4l80e.htm
I haven't heard of this builder, but shows what's possible for these trannys.
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Transmission: 4l80e
why dont u try to use the new 5 speed automatic...i have read its closer to size to the 4l60e and better ratios
So it may end up better in fitment, extra gear
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
P.S. what size rear tire and rim are you running as well? THX....
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
I have a 4l80E yes, they are super heavy!!! the manual valve body kit is cheap.. so you will not need electronics.. and agreed with above I do not see any reason why you would need to grind or dent your floor... the trans housing is thicker... but not that far off from a 4L60E... drive shaft will be fun as well as the torque arm and crossmember
Transmission: 4l80e
First three gears are the same as a T-400, there are plenty of sites with those gear numbers. 2.48 1.48 1.00
third is 1.0 like most so that makes math pretty easy.... 245/50/16's (street) about 25"
third gear 142mph@6200
second gear 96@6200
first gear 57@6200
gear x rpm link
http://http://www.angelfire.com/fl/p...tion/rear.html
My stock drive shaft worked fine...
second gear 96@6200
first gear 57@6200
gear x rpm link
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
pocket did it in this one https://www.thirdgen.org/forums/ltx-...-not-left.html
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
I am about half done with mine and will be done in the next week.
Here is the swap thread, i included a quite a few pics.
https://www.thirdgen.org/forums/ltx-...l80e-swap.html
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The only reason why one would want a 4L80e over a 4L60e is that the engine power is destroying the 4L60e models. It weighs more, is physically larger, and is a lot stronger than anything that cam stock on a thirdgen. If you have a 11 second car, don't need it. you have an 8 second one, you will need it.
Car: 92 Camaro
Engine: LS 6.0 LQ4 + Turbo
Transmission: T56 6 Speed Manual
Axle/Gears: 4.11 For now
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I have yet to start mine. Hopefully soon
Transmission: 4L80E
Reading above post, You want to be into a transmission swap that can handle some HP for $1000 or a $3000 trans that can handle some HP? I'm happy to pick up the extra weight. Shooting for 10's.
Car: RS
Axle/Gears: 9" for the ladies
I rebuilt a complete 4l80e and can tell you a lot of the year to year changes after learning all about them. Then I stuck it behind and LS1, changed some wires and had a segment swap done on the ls1 PCM so it could still control it.
The special yank converter cost more then the 4l80e.
In the end I just wanted something a heavy 2ndgen wasn't going to hurt as easily.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
Hello, Michael
Aug 20, 2015 03:19 PM
400, 4l60e, 4l80, 4l80e, bellhousing, dimensions, gen, gmt, harness, install, swap, t56, transmission, weights, wiring
