lsx engine is running
Old Oct 10, 2009 | 09:20 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
finally got my engine running today. it took me longer than i thought it would(don't they all!) but between this forum and ls1 tech i thought it was pretty straight forward. pockets and ghetto post where really helpful!
i am going to put it up for the winter but at least i can relax because everything worked guages etc. i have plenty of work left cutting and rerouting wires, fuel lines etc.
heres a couple of pics of the swap.
Old Oct 10, 2009 | 10:35 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: lsx engine is running
Congrats on the milestone man!
(And thanks for reminding me of how long my own build is taking...)
Old Oct 10, 2009 | 11:40 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Looks great!!
Living the Dream!!!!!!!!
Old Oct 11, 2009 | 12:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Congrats!
If it fired, you're farther along than I (start date 2/08).
Old Oct 11, 2009 | 06:34 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
by the way. i used a plug and play harness i bought off ebay from a seller named lsthunder. the harness fit was perfect and very easy to install. the seller also answered my questions very quickly. i believe i paid around 400 for the harness. it came with a cd of instruction, relays, fuses and a custom programed pcm. highly recommended! between that harness and pockets thread on 3rd gen harness the wiring was easy!
Old Oct 11, 2009 | 10:50 AM
V8Rumble's Avatar
Wow. I haven't priced harnesses in a while, but if I'm remembering correctly, that's a great price...
Old Oct 11, 2009 | 01:46 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Yeah thats cheap! I paid $150 for mine and another $300~ or so to get it modified.
Old Oct 11, 2009 | 05:07 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i have seen his harness assy's go for as low as $350.00 to $500.00 plus.
Old Oct 12, 2009 | 08:51 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
That sounds like an AWESOME price if the harness is nice and it works. It looks like they gave you a good amount more for the PCM harness too. So you can mount it inside without issue.
Swap is looking clean and so is your car! Especially that interior! Congrats on getting it to fire!
J.
Old Oct 14, 2009 | 03:08 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You sure lsthunder was the guy's username? I just did a search and ebay doesn't recognize that username.
Old Oct 14, 2009 | 06:19 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
sorry it's : chevythunder_ls1 he doesn't have them on there all the time, so check occasionally.
Old Oct 15, 2009 | 05:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
is that a GTO power steering setup? does it play nicely with the f-body stuff?
GTO CAI as well?
what upper rad hose are you using?
Old Oct 15, 2009 | 08:12 PM
Shift06's Avatar
I think those are the CTS-V accessories. (I might be wrong but I thought I remembered that from another thread he posted)
Old Oct 16, 2009 | 03:34 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
yes they are gto accessories. i used the iroc power steering pressure and return /cooler line. the iroc lines fit nicely with the gto power steering i did not have to bend the line at all. gto cai and it is the turbo trans am rad. line(i got the part number here). the gto accessories work well except the alternator plug is different than the fbody harness.
Old Oct 16, 2009 | 06:21 PM
mw66nova's Avatar
Engine: 7.0L
turbo transam upper radiator hose eh? hmm...that may just solve my upper hose problems.
how are you running the coolant purge line? where are you running it to?
Old Oct 17, 2009 | 06:02 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i did the waterpump mod for the coolent hose.
Old Oct 17, 2009 | 07:03 AM
mw66nova's Avatar
Engine: 7.0L
oh, is that what that little nipple is on the top of the water pump?
Old Oct 17, 2009 | 07:07 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
yes. it connects with the coolent crossover.
Old Oct 17, 2009 | 08:00 AM
mw66nova's Avatar
Engine: 7.0L
i'll do that when i get my new upper rad hose, lol! i used a 01 camaro upper hose, and made a manifold for the coolant purge to go into with some 1 5/8" roll-bar tubing, and a brass nipple, then i spliced it in to the upper rad hose. wasn't a bad idea, but it's not the best way to do it i don't think. it's not very clean looking, and i had to stretch the crap out of my rad hose, and i think it compromised the integrity of the hose. one of the cool things about these motors is that they are relatively reliable per the HP they make, so i want the car to be reliable enough to make a decently long trip (at least a 3 hour one) no reason to do things that will cause reliability issues, ya know?
Old Oct 17, 2009 | 09:32 AM
Car: 86 Trans AM
I made the 8 hour drive down to OBX with my 87 shortly after finishing. Not only was the t-topless, loud, fast ride down absolutely fantastic, but I didnt have one single issue. No overheating, no clutch issues, no leaks...nothing. AND...I wasnt the worst MPG vehicle on the trip. In fact, my car did almost as well as some of the smaller cars that were in the caravan.
The ONLY motor I trust more than an LS1 at this point...is the venerable 4.0 Inline six Jeep motor. Ive seen those things perform some amazing mechanical feats...like running perfectly fine while one of the pistons is missing most of its skirt and half the rings. Talk about a tank of a motor.
I digress... Im using the 4th gen rad...so steam line hook up was easy for me. However..I hate that steam line. Its two different diameters of hose. So its clamped in the middle. And it runs across all the other hoses. Ive been trying to figure out a good way to clean that up, but havent really gotten anything nailed down.
J.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
