Solid engine mounts
Old Oct 21, 2009 | 02:10 PM
kammi10's Avatar
Car: 1989 camaro
Solid engine mounts
does anybody make any solid engine mounts that bolt right in to a 3rd gen for a lsx swap?
Old Oct 21, 2009 | 05:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you use swap mounts on the chassis side that use the LS1 engine side mounts, then you should be able to use solid engine side mounts http://www.summitracing.com/parts/UPI-0051/
Old Oct 21, 2009 | 06:28 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Solid engine mounts
Seans pocketbook has no end!
Old Oct 21, 2009 | 06:39 PM
kammi10's Avatar
Car: 1989 camaro
except from what i understand the way the motor mounts mount on the engine and cradle they are reversed from what they are on gen1 blocks so that would not work because the clam shell mounts to the frame stock but then when u swap a lsx in there its on the engine so if u buy the swap mounts the ones u showed woul dhave to mount on the engine and those do not look like they will work..
you dont even know the new plans do you ?
Old Oct 21, 2009 | 06:51 PM
MattODoom's Avatar
Car: '88 G T/A
no'sah
Old Oct 21, 2009 | 11:39 PM
five7kid's Avatar
Correct, those would mount on the engine. They replace the clamshell that mounts on the f-body LS1. That's why they'd work. With 3rd gen LS1 swap mounts on the crossmember (which "normally" mate with the factory clamshell on the engine), these will slid into the "U" bracket instead of the clamshell, you slip the long bolt through both, and you're mounted up.
Old Oct 22, 2009 | 09:59 AM
kammi10's Avatar
Car: 1989 camaro
except those ones u posted are are supposed to go on the frame pad not on the block itself so i do not thing the bolt pattern will work
Old Oct 22, 2009 | 12:22 PM
five7kid's Avatar
You might be right. Gotta be something out there.
Old Oct 29, 2009 | 07:27 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
They don't exist, you should give up now, your project is doomed.
Old Oct 30, 2009 | 02:24 AM
kammi10's Avatar
Car: 1989 camaro
your always such a hater
Old Oct 30, 2009 | 02:41 PM
five7kid's Avatar
If you used the swap mount plates that allow Gen I/II engine side mounts on Gen III, you could use those solid mounts on the chassis side.
Assuming you aren't using a tubular LS1 swap cross member.
Old Nov 1, 2009 | 09:58 AM
MattODoom's Avatar
Car: '88 G T/A
Soooooo... why not make your own? Couple rolls of duct tape and a decently thick piece of cardboard should work for the amount of HP you'll be putting down.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
