finally found the code for my ls1
Old Oct 25, 2009 | 10:43 AM
ScorchedPaint's Avatar
Car: 1992 Camaro RS
Engine: Ls1
Axle/Gears: 4th gen 3:43
i finally found the code that was causing the mis idle. It was P0335 which is
Crankshaft Position Sensor A Circuit Malfunction
Now, what would be the recommended next step as to how to fix this problem?
Old Oct 25, 2009 | 01:53 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: finally found the code for my ls1
I would track down a wiring diagram for the crankshaft position sensor showing which wires go to the PCM and which (if any go to ground). Now take a voltmeter/test light and check each wire for continuity and if it is being grounded like it should (or shouldn't). One of them will most likely report that it is being grounded when it shouldn't be - then you either hunt the ground or run a new cable.
I suggest autozone.com for wiring diagrams. You just have to register and they have a ton for our cars and the ls1 f-bodies.
Old Oct 25, 2009 | 02:15 PM
Car: 1992 Camaro RS
Engine: Ls1
none of them go to ground,
1 is 12v reference
1 is low voltage reference
1 is CKP sensor signal
i am going to do a continuity test and see if thats what is doing it. there were some wires that were cut that were running to the pcm that werent connected back together until now. dont know if those effected anything or not.... will the code turn off on the obd 2 scanner if the problem is fixed?
will i have to take the car to the dealership to get the crankshaft sensor to relearn?
Old Oct 25, 2009 | 04:21 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Check your gounding anyways. 5v refrence is a circuit that connects to the computer, so make sure the computer grounds are all good.
Next, check the plug itself, commonly people will accidentally plug the low oil level sensor into the crank sensor. (i did this once, you cant see down there, so your just fishing around and guessing)
Next would be to run a program a scanner program to see if the computer is getting any reading what so ever from the sensor. If not, try a "crank re-learn"
If this still doesnt work, replace the sensor.
Old Oct 25, 2009 | 08:20 PM
Pocket's Avatar
Car: 91 Trans Am
B2 Lt Grn Crank pos 12v ref
B12 Dk Blu/Wht Crank pos Signal
B21 Yel/Blk Crank pos Low ref
LS1 schematics arent overly useful as there are very few places that multiple wires connect. 90% of them are direct connections to the PCM like the Crank sensor above. Pinouts are easier
All critical circuits are direct to the PCM. Non criticals like the HO2s and MAF have separate IGN and grounds which are just as easy to trace
Old Oct 26, 2009 | 08:44 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I got your PM. But basically the fellas here offered the same advice I would have. You need to check your wiring, check the plug, maybe replace the sensor if everything else checks out.
Its pretty much the procedure any time you get a code like that. You just gotta check it all out. Make sure grounds are grounded, powered are powered, and signal wire have continuity from the plug all the way back to the PCM pin.
J.
Old Oct 26, 2009 | 08:49 AM
Car: 1992 Camaro RS
Engine: Ls1
will do, ill let you know what i find today....
Old Oct 26, 2009 | 01:49 PM
Car: 1992 Camaro RS
Engine: Ls1
the car is now able to idle! woohoo!! i think it was the fact the wires were close to the headers causing resistance which in turn caused the bad idle but now it is fine!
i noticed when i give gas and let off quickly it takes a little longer to come back down to idle. what could that be caused by?
also i bled the brakes but now when i turn the car on and it idles the brakes are back to being squishy and not engaging. any ideas???
Thanks to everyone for the info so far!!
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
antares57
Aug 6, 2015 07:47 AM
