reverse lockout wiring
Old Oct 30, 2009 | 02:20 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
alright, anyone know where to tie the reverse lockout solenoid into for my swap? isnt there a connector somewhere i can use and not have to hack into the brake light wiring?
Old Oct 30, 2009 | 02:42 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: reverse lockout wiring
I spliced into my brake light wire. I don't consider it a hack. I use solder and adhesive lined shrink sleeve. The swap works great this way. Dean
Old Oct 30, 2009 | 03:55 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
so just put one lead to the brake light wire, and ground the other? and where is a good spot to find the brake light wire? i dont think the polarite to the solenoid matters does it? thanks,
Old Oct 30, 2009 | 04:04 PM
DeanJ's Avatar
Engine: LS6
Ground one side of the solenoid, other side splice into light blue wire at the brake light switch. Thats how I did it on my 88 Camaro. Yours should be the same. Dean.
Old Oct 30, 2009 | 04:13 PM
DeanJ's Avatar
Engine: LS6
I just looked at my Firebird shop manual and the light blue wire is correct. Dean
The polarity of the solenoid dosen't matter.
Old Oct 30, 2009 | 05:44 PM
Pocket's Avatar
Car: 91 Trans Am
It should be a 2 pin connector
R44 Lt Grn Reverse lockout
Pnk wire to IGN source
Being a truck engine you likely wont have that pin on PCM the connector but LSx terminals are super easy to move without any tools
Old Oct 30, 2009 | 06:07 PM
DeanJ's Avatar
Engine: LS6
My bad, I didnt realize he wanted the PCM pin #. My T56 swap is currently non LS. Dean
I guess I forgot what forum I was in.
Old Oct 31, 2009 | 01:18 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Holy crap I completely forgot I could've done that! I ran the t56 before I went LS* and now that I finally put an LS* in I should've cleaned up the wiring a bit. Oh well..
camaro11j
Sep 19, 2018 08:49 AM
deracer
Apr 11, 2016 12:04 AM
Rakim_RS25TH
Sep 1, 2015 04:07 PM
Rakim_RS25TH
Aug 27, 2015 05:04 PM
hokis
Aug 9, 2015 03:57 PM
