Cable X speedo convertor
Old Nov 28, 2009 | 06:56 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Has anyone on here who as done an LTX or LSX swap used the Cable X speedo convertor?? Do you like it, was it easy do install, etc etc. If you didnt use the cable X convertor what did you end up going with? I'm looking for a good speedo convertor for my third gen dash to go to my T56 transmission. Something number 1, easy to install and #2 fairly accurate. Thanks for the help guys.
Old Nov 28, 2009 | 11:29 PM
86LT1's Avatar
Engine: 357 LTx
Re: Cable X speedo convertor
how did everyone convert their speedometers over to the new transmissions?? Everyone on here can't be driving around w/o a speedo...... can they?
Old Nov 29, 2009 | 12:39 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
https://www.thirdgen.org/forums/tran...p-cheaper.html
Old Nov 29, 2009 | 06:23 PM
86LT1's Avatar
Engine: 357 LTx
thanks for the link alloy
Old Nov 29, 2009 | 06:30 PM
alloy's Avatar
Car: 87 IROC-Z28
Your very welcome. I have a customer with a Cable-X box and he's having me convert his trans to cable drive. If you want I can ask him to share his experiences with the Cable-X box with you.
Old Nov 30, 2009 | 01:30 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
What about swapping in an 88 or 89 firebird electronic speedo?
Old Nov 30, 2009 | 01:52 PM
Pocket's Avatar
Car: 91 Trans Am
Easier to swap in a 90-92 camaro speedo since he has a camaro to start with
Huge job compared to adding a cable box
Old Nov 30, 2009 | 02:01 PM
screeminchicken's Avatar
+1 on that !! get a electronic 140 mph speedo fpr less that 100 bucks
Old Nov 30, 2009 | 02:28 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
don't you have to change the dash wiring if you wanted to go from mech speedo to an elec speedo?
Old Nov 30, 2009 | 03:29 PM
Aaron91RS's Avatar
Car: RS
He has an 86 with the round guages. He'd need to redo his whole dash with a 90-92 camaro setup.
An 88 or 89 firebird setup would still be the black round style and a much closer fit.
Not to mention they are $20 at a junkyard or on here.
90-92 firebird would also work being round but not match as close being more gray.
most of us are bypassing the vss buffer box already on the electonic speedos. I don't know of any other special electronics after that, but I don't have that year.
The PCM will need to be reprogrammed but that's a given on any 3rdgen.
Old Dec 2, 2009 | 03:05 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Im still on planing on going that route just as convince myself to spend $300 on a box LOL. Been driving without one for 3 years lol
Old Dec 2, 2009 | 03:59 PM
Engine: LSx 5.3
Ok, i'm going to run into this problem in a few more months. I have an 89 Iroc LSX swap with a T56 trans and I'm thinking about going with the box but if you guys are making the electronic clusters work, then I'll do it that way.
Old Dec 6, 2009 | 04:48 PM
86LT1's Avatar
Engine: 357 LTx
so an electric cluster will work? If I got an electric dash out of a newer thirdgen would i be able to swap that in w/o any wiring issues? and would it connect to my T-56 w/o any problems? I also was thinking about eventually getting a digital dash, possibly from dakota digital. If i went this route would there be an easier way to convert my speedo??
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
