LT1 engine sensors
Old Dec 26, 2009 | 03:03 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
LT1 engine sensors
Anyone know where I can purchase all new engine sensors for my LT1 build? I need everything except emissions stuff for my supercahrged 383 LT1 build.
Old Dec 26, 2009 | 05:17 PM
TexasLT1's Avatar
Car: '92 RS
Re: LT1 engine sensors
Any parts store. Why do you need all of the sensors?
Old Dec 27, 2009 | 02:00 AM
Car: 1992 z28
I bought a partially complete 383 LT1 from someone who had none of the sensors. I had the entire motor rebuild from scratch for a supercharged 383 build and now need to get all the sensors for the engine. I guess I could try to find a junked LT1 and take them from that but since I am doing every single thing new I would rather get all new AC Delco sensors as well.
I was thinkin of just Autozone or Advance but was just wondering if there was someplace to just get a package of all the sensors making it easier but I guess it makes no difference.
Old Dec 27, 2009 | 07:50 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
no, you'll end up buying the sensors individually, you'll have 2 o2s, 1 temp sensor for the waterpump, 1 temp sensor that goes in the head (for the gauge), 1 knock sensor, and of course, the TPS, IAC (both inlet air and idle air control) and the oil pressure sensor. I'm pretty sure that's all you'll end up needing.
Old Dec 27, 2009 | 05:07 PM
Pocket's Avatar
Car: 91 Trans Am
MAP, MAF and two knocks too
At $30-80 per sensor, that little kit just got expensive. Hit up a junkyard, most are interchangable with non-LT engines
Old Dec 27, 2009 | 06:41 PM
Klortho's Avatar
Car: 1987 GTA
actually just one knock sensor, at least my LT1 only had one.
Old Dec 28, 2009 | 12:42 AM
Pocket's Avatar
Car: 91 Trans Am
All of my LTx harnesses were based on B-body LT1 and they all had two knocks but they came together at a single terminal on the PCM
Strange
Old Dec 28, 2009 | 06:24 AM
Klortho's Avatar
Car: 1987 GTA
Yup, the f-body only has one.
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
