ls1 turbo questions
Old Jan 16, 2010 | 03:49 PM
ls170GTO's Avatar
ls1 turbo questions
Which exhaust manifolds work on a 3rd gen with ls1?
Also, which K member has the most clearance?
Old Jan 16, 2010 | 04:09 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: ls1 turbo questions
are you asking what manifolds will work to flip around to use for a turbo system? I think the truck manifolds stick to far out and will hit the frame. Maybe stock manifolds. A tubular K member is gonna have more clearance the stock.. A lot more.
Old Jan 16, 2010 | 04:12 PM
ls170GTO's Avatar
Yes I am asking which stock manifolds work, I thought I read somewhere that GTO manifolds work.. I know aftermarket ones have more clearance, I was more or less asking which one has the most.
Old Jan 16, 2010 | 06:02 PM
1bdbrd's Avatar
Car: 1991 Trans Am
I can say with 100% certainty that truck manifolds will fit and work. There is some clearancing and such that you will have to do though. I have seen the completed kit with my own eyes and it looked amazing.
Old Jan 18, 2010 | 01:48 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I can second that truck manifolds will fit BUT I dont know how in the hell you could ever run a decent exhaust passed the engine without a tubular K so consider that a "must have" for this kind of build. Also the inlet ( TB intake piping ) requires some mighty fancy routing and/or mods to the rad support and rad mounting if you want to run an intercooler. Good luck
Old Mar 15, 2010 | 11:56 AM
Transmission: 4L80E
Anyone try C6 Manifolds?
Old Mar 15, 2010 | 01:11 PM
Pocket's Avatar
Car: 91 Trans Am
C5, C6, GTO manifolds all are center exit which is exactly where your K-member is. They are also rather long so inverting them would put them through the hood
Camaro LS3 manifolds look promising
Check it out
http://www.ls1tech.com/forums/conver...asurments.html
Old Mar 15, 2010 | 03:26 PM
Transmission: 4L80E
The C6 LS3 manifolds do look like they may work. I really would like to retain A/C. With those manifolds it just might.
Old Mar 17, 2010 | 08:52 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I'm in the process of Redoing my IROCBOOST from the STS setup and stock LS1 to a built 6.0 and a front mount turbo setup. I have truck manifolds, 98 manifolds, 2001 manifolds, and a set of hugger LS headers i might just have to chop up to make fit. I'll let you guys know what i can make fit. When i tried before the truck manis hit the stupid big *** steeering knuckle...
Old Mar 17, 2010 | 11:26 AM
Transmission: 4L80E
Keep us posted for sure! A lot of people cut the flange off and weld on a V-Band. Worth a shot?
Orr89RocZ
Apr 25, 2016 08:28 AM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
