non-mounting motor mounts
Old Mar 21, 2010 | 03:45 AM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Hello again.....question?
I have a 91 RS Camaro with a BMR tubular K member...I had a
RamJet 350 in it before...
I now am going with a LSX block(427HO) from Mast Motorsports..
I used a moroso hard mounts from the 350 and purchased the mounting
plates for off-setting the mounts from Speedway....
Prob is when motor went in...it lined up on Driver side...1/4 inch off
on the pass..the hard mount is 3/8 thick....
well is there any thing out there I could look out!!!
I'm going to get a buddy to plane the brackets up a 1/8 off both of them...
and see if that does it....MOCK up``````````````the ones I'm making now are 1/4 in....tks for the in
Old Mar 21, 2010 | 08:16 AM
Pocket's Avatar
Car: 91 Trans Am
Re: non-mounting motor mounts
Pics a pic or link to the mounts. There are several types and its hard to recommend a solution without knowing which
Old Mar 22, 2010 | 03:13 PM
hey pocket..goinn to try to figure this downloading pic.. to show u what I got...
Old Mar 22, 2010 | 04:12 PM
Hey here are the mounts that I'm dealing with...I didn't
take pics when I was installing down there under the camaro.
Old Mar 22, 2010 | 05:02 PM
hey Pocket..I'm going nutts on trying to get pics to u...they down load but are not showing up....try it again..
Old Mar 22, 2010 | 05:14 PM
Pocket's Avatar
Car: 91 Trans Am
When posting a reply, click manage attachments, browse, find the pic and click upload. Close the small window when you're done and post the reply
Alternately you can upload them to an offsite photohosting place such as photobucket. Either post a direct link to the url up at the top of the browser or use the [img] blah [/img] codes to make it show up in the thread
Old Mar 22, 2010 | 05:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can host the pics on photobucket.com . They even provide a ready-to-post image code that is copied when you click on it, then you can paste it into your post.
Old Mar 22, 2010 | 06:12 PM
Here this is the deal ....I have a LSX block.... and it is
made into a 427HO. The plates for the block in order
for it to work with a Small Block BMR K-member...came
from Speedway.com(LS-1 to SB mounting plates)
I have used a Moroso solid mount SB mounts that mount
to the bracket...
I was curious if the LSX blocks are a 1/4 in bigger in size then
then a LS-1, 3, or so on...
I will try to get pics on here...any ideas
Reason I ask is a buddy used the same K-member and plates with
solid mounts and slide right in...so....
Old Mar 22, 2010 | 08:01 PM
Pocket's Avatar
Car: 91 Trans Am
LSX blocks are the same dimensions as stock. The adapter plates are the problem. Loosen the bolts and try to shoot the mount bolts through again. You may have to slightly slot the holes
Old Mar 23, 2010 | 08:56 PM
Hey Pocket...yeah it looks like a 1/8 in with a drimal tool
would put me in the spot...but I thought that might be to
risky...or maybe not.
I have a buddy cutting some on a 1/4in aluminum..to see if that will work..
Trying the pics the way you said tooo..tks for the help
Old Mar 23, 2010 | 09:06 PM
Pocket's Avatar
Car: 91 Trans Am
Slotting the holes is a non issue. If they bother you that much, put a washer on there
Old Mar 23, 2010 | 09:10 PM
well cool....I will go with that then...a little stretching of the
hole in the mount..should work
I will try the mounting plates first!!
I have the 1/4in ones being made...
Last edited by candy burple rs; Mar 23, 2010 at 09:13 PM. Reason: lack of info on my part
Old Apr 11, 2010 | 12:20 PM
Hey got that motor in awhile back..3wks I believe....Use of a BMR K-member I had to mill off a 1/8th in off each one where the solid mount was applied...DROPPED right in like gravy..lol..Looking good too..tks for the help
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
