Who sells mityvacs????
Transmission: 4L80E/4L80E
Harbor Freight, O'Rielly Auto Parts, amazon.com.
I'm sure there are others.
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: Who sells mityvacs????
Bought mine at my local Sears, I HIGHLY suggest using one for bleeding the clutch. It was $30, and took me 30 seconds to bleed my clutch.
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
thanks looks like i got places to go even though i didnt find it at the zone
Engine: Cammed 6.0L LSX
Semi-off-topic: I'm assuming it would be pointless to use one of those for bleeding my clutch if I have a Tick Performance speed bleed one-way check valve? I'm used a mityvac to bleed my brakes but never have used one for clutch fluid.
It would be hard to be easier than the Mity Vac way. It took me a little longer than 30 seconds, but it was mess-free and didn't require being in two places at the same time.
Engine: LSx 5.3
I never even used the bleeder on the slave cylinder, i just used the mityvac and it works perfect. Here's the write-up I followed:
http://www.performanceworks1.com/ls1...h_bleeding.htm
The reason I asked is because you don't have to be in two places at once with the Tick bleeder either. You just open the valve which is connected to a long line that you feed up into the engine compartment, then push on the clutch pedal a few times until there is no more air, then close up the valve.
Stangski09
Nov 14, 2015 01:27 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
