LT1 water pump
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
LT1 water pump
I am away from my car for a few days and I want to order an electric water pump. Does anyone know the size of the hose that goes into the water pump so I can order the right size hose adapter fitting as well. engine is a 95 lt1 Thanks
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Re: LT1 water pump
EWP does not come as a whole unit, you need to dissasemble your old unit, put the electric motor in, and then seal it up. I personally like the CSR pump. In this case your old housing will be used, eliminating the need for any extra parts/adapters. Just don't forget to buy a relay kit for it as well.
For example: http://www.jegs.com/i/CSR/170/901LT1...oductId=744293
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
Re: LT1 water pump
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
Re: LT1 water pump
I think double rollers clear the timing cover with grinding. If not wouldn't the opti/WP have to move outward in that case? Then you would certainly need spacers for the WP.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
