ls1 wont start, suspected vats, how to delete vats?
Old May 9, 2010 | 02:05 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello there
car is factory 89 tpi with vats, i changed the column to a non vats column with a different key, i am not getting power to the starter from the purple wire, how do i permanently bypass the vats, i dont want to put in a resistor, i want to hardwire around all of the vats... how do i do this.
Old May 9, 2010 | 03:20 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: ls1 wont start, suspected vats, how to delete vats?
there should be a relay behind the driver side kick panel, either ground the relay or connect the two big wires together
Old May 9, 2010 | 03:50 PM
Car: 1989 IROC-Z
Engine: 346 LS6
yes. the starter enable relay, there are 4 wire on it, a small green with white stripe, a large green with white stripe, and two large yellow wires.
i know the large green with stripe goes to the shifter.. i cannot differenciate between the yellow wire becuase they are the same, neither have a black stripe.
which two big wires do i connect? what do you mean by ground the relay.. it is made of plastic so im asssuming you mean ground on the the four wires.... which one?
thanks
Old May 9, 2010 | 07:13 PM
Engine: LSx 5.3
Here is the diagram:
Look at the starter enable relay, either ground the solid dark green wire or take one of the yellows and connect it to the dark green/white striped wire.
Old May 10, 2010 | 04:04 PM
Engine: LSx 5.3
You get that thing runnin yet!? lol
Old May 10, 2010 | 06:05 PM
kevinc's Avatar
Car: 1982 Z28
thanks
Looking at the diagram, it looks like you want to splice either of the large yellow wires to the large dark green/white wire.
Old May 10, 2010 | 06:12 PM
Engine: LSx 5.3
Yep, I recommend doing that if you want to eliminate that relay. That's what I did
Old May 10, 2010 | 10:32 PM
Car: 1989 IROC-Z
Engine: 346 LS6
i took the relay off, connected one of the yellow wires to the green wire to the shifter and it started!!! thanks very much for your help.. my initial trouble was a bad igniton switch but after i changed that, the yellow to green wire fix totally got rid of my vats problems.
And its sounds soooooooo good.. vroom vroom
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
