Oil Pressure Sender (LS1)
Old May 27, 2010 | 05:20 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
http://img31.imageshack.us/img31/7100/1135118.jpg
I picked up this handy piece from a store on eBay, it's an original style oil pressure sender with the correct threads to screw into the LS1. Anywho, I am having trouble getting it actually in there. I can screw it in, but I can get a wrench in there (motor is in the car) and I don't have a deep socket deep enough. I've looked all over for those specialty oil sender socket, but none of them are the right size. I believe the common size for these is 1 3/16" but this piece I bought is actually 1 1/16". I've seen 1 1/16" sockets for oil pressure senders but they are all too shallow because they appear to be for the new style piece (original LS1 piece). ANYWAYS, basically all I want is a solution. Ami I going to have to remove the intake?
Old May 27, 2010 | 05:28 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: Oil Pressure Sender (LS1)
possibly.... i believe i either ground the sender or socket down to fit....
Old May 27, 2010 | 06:13 PM
Shift06's Avatar
The only sockets I can find are too big. Not too small.
Old May 27, 2010 | 08:34 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i used a craftsman 1 1/16 deepwell 1/2 drive. no problems.
Old May 27, 2010 | 09:00 PM
Shift06's Avatar
Craftsman eh, I will have to make a trip to Sears lol.
Old May 30, 2010 | 10:50 PM
Pocket's Avatar
Car: 91 Trans Am
Id remove the intake. Its not too difficult in a 3rd gen
Old May 31, 2010 | 06:08 PM
Shift06's Avatar
Yeah but I need to remove the valley cover too, even then I am not sure a wrench could get on it because of the recess.
Old May 31, 2010 | 07:45 PM
Pocket's Avatar
Car: 91 Trans Am
Why the valley cover?
Old May 31, 2010 | 08:16 PM
Shift06's Avatar
Because I can't get a wrench on it from the front, even with the intake removed (I just toom it off) The only way to get at it is from the back which is impossible because of the firewall.
Old May 31, 2010 | 09:11 PM
Pocket's Avatar
Car: 91 Trans Am
Wierd, I got mine with a crescent with the valley cover installed, but its not a huge deal if you have to remove it. The gasket is reusable
Old Jun 16, 2010 | 10:25 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Do you have a part # for this sender? Sounds like an easier option than drilling and tapping the LS1 sender.
Old Jun 17, 2010 | 12:32 AM
Shift06's Avatar
http://cgi.ebay.ca/LS1-Swap-Oil-Pres...item1c0fc862fa
Nook and Tranny on eBay carries some useful LSx swap parts.
Also, I got it in, but I had to buy 2 deep 1 1/16" sockets and cut and weld one onto the other. Luckily I work at a fabricating / machine shop so I could tig them together, blasted it and painted it black. Turned out great, and now I have a new tool for the future.
Old Jun 21, 2010 | 04:55 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Custom tools are fun. If nothing else than explaing to your buddies; "Yeah, I had to build that when everything else out there didn't fit my needs."
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
