LS1 carb'd ??
Old Sep 10, 2010 | 02:18 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
LS1 carb'd ??
OK so i def wont be attempting this anytime soon. but as i was browsing i found a few people who had carbed an ls1. if that can be done would it be possible to TBI an ls1? just use a carbed intake with tbi adapter plate? and maybe a 454 tbi or something like that. just wanted to know if it was possible
Old Sep 10, 2010 | 02:34 PM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
Re: LS1 carb'd ??
well,..... if you can carb it i do not see why not. i just dont think anyone has ever tryed the tbi setup,.... might as well go carb,........ or fuel injection either way is easy..... so
Old Sep 10, 2010 | 02:37 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: LS1 carb'd ??
well i figured if you go with tbi there wouldnt be any wiring to work out, or am i mistaken?
Old Sep 10, 2010 | 02:44 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: LS1 carb'd ??
I'm going to say no. You could mount everything up probably, but since the factory distributor is what fires the injectors, you would have problems with that.
Why bother with the TBI though in the first place? Either just carb it, or take advantage of the much better fuel injection setup the LS1 already has.
Old Sep 10, 2010 | 03:49 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: LS1 carb'd ??
TBI is junk for any performance in the first place, and expecting it to keep up with the high revving LS engines? Couldnt tune it even if it would fire the injectors. They just cannot keep up. Just do a budget carb setup and make more power than EFI or go EFI if you have the cash and want a bt more drivability.
Old Sep 10, 2010 | 08:27 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: LS1 carb'd ??
Oh i didnt think about the dizzy. well i cant carb it because then it wouldnt pass inspection in NC and i think the wiring stuff would be diffucult. it was just a random thought i had.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
