Cam angle sensor connector trick
Old Sep 26, 2010 | 06:59 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
This little connector is causing me lots of headaches. Apparently I should have put the harness in first, then the intake.
Does anyone have any tricks for hooking this up without removing the intake? BTW, I have a 92mm FAST, which probably doesn't help matters
Old Sep 27, 2010 | 06:26 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Cam angle sensor connector trick
If I remember correctly... that one is a bit of a bear to get in with the intake on. Stock or otherwise.
I think I shaved some of the release tab down to make it snap in easier. Just the part of the tab that is angled up so you can grab it. But since you cant really get your fingers under there anyway, I usually use a screw driver to release the tab.
Not sure if that would help you or not...the 92 might be different than my 90.
J.
Old Sep 27, 2010 | 11:40 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just plugged mine in....
Old Oct 1, 2010 | 06:58 PM
Pocket's Avatar
Car: 91 Trans Am
Take the wiper motor off and try again
Old Oct 3, 2010 | 05:57 PM
Omega's Avatar
Engine: LS1 / LS3
The wiper motor is not the issue. I can get my hand with the connector down there (barely) but the connector just won't go it.
Oddly enough the MAP sensor has a VERY similar plug... just keyed differently.
Have not worked on it, went the Carlisle swap Saturday and Rally Car at NJ Mortorsports Park today
Old Oct 3, 2010 | 07:01 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
maybe you should remove the cam sensor and make sure its the correct one for that pigtail or that the pins aren't bent. mine went right in each time
Old Oct 4, 2010 | 07:05 AM
Omega's Avatar
Engine: LS1 / LS3
I think the intake removal is definite.
Are the intake gaskets reusable?
It would be a good time to glue a nipple where the MAP is supposed to go. Ill remote mount it. All the R&D for that intake and they fall short on the MAP mount. WTF.
Old Oct 5, 2010 | 09:11 PM
Engine: ls1, LB9
ive reused them several times, they will take a set over time though so if you just used new ones befor you should be fine
Old Oct 6, 2010 | 07:04 AM
Car: 86 Trans AM
Did you try shaving down the tab a little bit? The part that angles up?
Old Oct 6, 2010 | 07:38 AM
Omega's Avatar
Engine: LS1 / LS3
Not yet, that will be tonights project.
Old Oct 10, 2010 | 12:42 PM
Omega's Avatar
Engine: LS1 / LS3
I was able to get the CAS plug on after I trimmed the tab. The MAP sensor got a little RTV attention while I was there to.
Thanks for the help.
Old Oct 11, 2010 | 02:24 PM
Car: 86 Trans AM
Glad you got er.
I hate the MAP sensor set up. Its just so hacky for such an expensive and overall nice intake. I never know if mine is sealing or not.
J.
Old Oct 11, 2010 | 06:16 PM
Pocket's Avatar
Car: 91 Trans Am
Mine is RTV'd grommeted and zip tied down
No leaks here
Old Oct 11, 2010 | 09:02 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I used a 1/4" NPT tap and then put a bung on it. Makes for easy remote mount map.
Old Oct 12, 2010 | 08:58 AM
Car: 86 Trans AM
I built a bracket using the bolt thats back there as a hold down. And used RTV. Im not saying that I def had a leak...but it was always suspect.
Ide rather have it attach via a hose and nipple, or some type of threads. When the motor comes out again I plan to make something that I KNOW isnt leaking and that is easier to remove/replace without disturbing the seal.
J.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
