Why call them lsx/ltx swaps why not ls/lt
Old Oct 5, 2010 | 09:43 PM
jayjay23's Avatar
Car: 88 iroc camaro bros car/my build
Engine: tpi 383 413hp
Axle/Gears: 373 eaton locker
I dont understand why we have to put the x inthere. i know its for the x factor but there is a block called the LSX. that should be a LSX swap not a ls1. I always called it a ls swap. The (LSX BOWTIE BLOCK) is a Fully CNC-machined cast iron block
• True priority main oiling
• 6-head bolts per cylinder
• Standard 4.400" bore spacing
• Extra-thick siamese cylinder bores
• Semi-finished, machined thicker decks
• LS7-style, 6-bolt dowel-located billet main bearing caps
• Wet-sump and dry-sump oiling capability
• Production-style deep-skirt head bolt holes
• Production bolt hole and thread sizes
• Maintains production exterior accessory mounting provisions
• Front motor plate mounting holes added
• Additional material cast around cam bearings for greater strength
• 8mm exterior/interior fifth- and sixth-head bolt holes
• All five cam bores machined for bearing P/N 19167218 (supplied)
• Standard 0.842" lifter bores
• Accommodates all LS oil pumps and oil pans
• External oil pump feed (rear of block)
• Main web bay-to-bay breathing holes to support greater horsepower
• Includes unique cam retainer, rear cover, lifter retainers and productionstyle replacement cam bearings For the advanced LSX competition engine builder, you will fully enjoy reading the following features of the new LSX Bowtie Block:
• Front oil feed holes can be plugged/restricted for mechanical flat tappet or mechanical roller lifter applications
• Can be machined safely to 9.200" deck height
• Maximum 4.200" bore at .200" minimum wall thickness (naturally aspirated applications)
• Head bolt holes can be machined for 1/2" studs
• Cam bores can be machined to accept 60mm roller bearings
• Can be machined for larger diameter lifters and/or 1.060" bronze bushings
• Front oil feed lines can be plugged and external oil pump and/or aftermarket dry sump systems can be used via oil pump feed at rear of block—may be required with certain large stroke/aluminum rod combinations
• Belt cam drive systems can be accommodated—some machining will be required
• Front motor plate can be used for racing chassis applications (sprint car, drag racing, truck pulling, etc.)
• Threaded water plugs can be used for external heaters or coolers
• Extra stock for main bearing align-honed inch and it is a small block.
NOW THAT IS A LSX SWAP ONE BAD BLOCK
Old Oct 5, 2010 | 10:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Why call them lsx/ltx swaps why not ls/lt
Written properly, it should be LSx but everybody is lazy.
Old Oct 5, 2010 | 11:36 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
LSx is because you have LS1 LS2 etc. Same with LTx LT1 LT4 etc.
Old Oct 6, 2010 | 12:05 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
When selling a car, do you report the mileage as 125,387 miles, or 125,xxx miles? The x is a place holder for any integer. There are many different LSx blocks, so an x is used to cover the whole family.
Old Oct 6, 2010 | 12:15 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Since I have an LQ4 shortblock should mine be LQx ? lol
Old Oct 6, 2010 | 08:44 AM
Pocket's Avatar
Car: 91 Trans Am
Still in the LSx family along with my LM7
L99 is a 4.3 LTx even though theres no "T" in the engine code
Dont confuse LSx (which can be anything) with LSX which is the GMPP block notable for it's 6 bolt heads, stronger walls, larger displacement and flashy red powder coat. Still in the LSx family, just a very specific name
Old Oct 6, 2010 | 03:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not everybody is lazy (with capitalization). That started with the texting generation. All caps, no punctuation, run-on sentences, abbreviated words, numbers in place of words - doesn't come from old farts.
Anyway, there's more confusion than convention out there. Why not call them "Gen II" and "Gen III"? Okay, then what do you call the '96-'99 "Vortec" truck engines? Speaking of Vortec, why are '96-'99 and '00-up truck engines all called "Vortec", when they are completely different? Why are the V6 truck engines also called "Vortec"?
What's the difference between an "LT-1" and an "LT1"? How about "LS6" and "LS6"? If you say you have an "LS4", will that necessarily distinguish exactly what you have?
All you need to know is how the crowd you're hanging out with uses the various terms.
Old Oct 6, 2010 | 04:12 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
IIRC, the Vortec V6 was the original vortec motor, and let not forget about the Vortex motors. LT-1, that's easy, 302 or 350 smallblock (depending on year and model) the hottest carb smallblock motor to go into a factory smallblock. LS6, could be a 454 or an LSx motor, LS4, either a FWD LSx or another 454. We could go on for days, even the L99, it's comeback as a 6.2L LSx whereas it used to be a 4.3L LTx motor.
Old Oct 6, 2010 | 04:15 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
because 'vette' motor was already taken
Old Oct 6, 2010 | 04:23 PM
five7kid's Avatar
Must not be that easy, as it was never offered in 302 form.
Old Oct 6, 2010 | 04:42 PM
ericjon262's Avatar
I thought the 302 in the 67-69 Z-28 was named LT-1 also.
Old Oct 6, 2010 | 04:56 PM
Drew's Avatar
Don't you know 'Vortec' means any V8 with centerbolt valve covers anymore? The intelligence level of the general public just keeps getting lower.
five7kid's Avatar
Nope.
Old Oct 6, 2010 | 05:20 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
'roids---??---
Make crazy big,
OR
Ya can't sit down..!!.. Lol !
I thought it was a design & // or displacement change,
although retaining the " small block " family name.
Old Oct 6, 2010 | 05:31 PM
Pocket's Avatar
Car: 91 Trans Am
GEN I, II, III, IV are all SBC's, but when someone says SBC they generally default to GEN I
Kind of pointless to call the new stuff small blocks since GM axed the whole BBC line after the 8.1L. It's simply GM V8's
Old Oct 6, 2010 | 05:36 PM
ericjon262's Avatar
Nope.
<hijack>
because I've started scratching my head, what was the name of the 302 then?
Old Oct 6, 2010 | 06:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Z/28
five7kid's Avatar
Ever heard reference to a "DZ"?
http://www.chevy-camaro.com/faq/chev...o-faq-Z28.shtm
Old Oct 6, 2010 | 06:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
DZ was the suffix code, the RPO was still Z28.
Old Oct 6, 2010 | 06:05 PM
ericjon262's Avatar
Yes, I've heard of a DZ, but that's from the suffix code, not the name of the motor.
Old Oct 6, 2010 | 06:08 PM
five7kid's Avatar
The engine was never given a specific name or letter/number designation. It was special enough in its own right.
The LT-1 was also used in Vettes, so it wasn't quite as "special".
Old Oct 6, 2010 | 06:10 PM
ericjon262's Avatar
</hijack>
Old Oct 6, 2010 | 06:18 PM
five7kid's Avatar
Actually, it proves the point. There are a lot of confusion, misnomers, and misinformation out there.
We've even had people argue that there was no such thing as an "L98" in 3rd gen f-bodies. And, they're probably right.
Personally, I object to the use of "motor" instead of "engine" (this was the "Motor Swap" forum at one time), but...
Old Oct 6, 2010 | 07:35 PM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Technically the Gen III/ Gen IV motors are a mid block.
Old Oct 6, 2010 | 08:01 PM
Guest
Guest
Posts: n/a
5.7L 3rd gens have L98 on the RPO sticker, but GM considered the B2L the iron head TPI 350, and that leaves L98 for the aluminum-head 'vette version, which has no other ID. I think that's the way it should be, but third gen guys refuse to switch to using B2L, and there's nothing anyone can do about it. Well, they could get the same software as other forums, where certain things you type and submit come up as something else. On one forum, and I'm sure ericjon262 has seen this, if you type "Archie" in your post, then after you click submit, it shows up as: "Cletus". If you type "Aaron", it shows: "Retard". If TGO had that software, then we could have way more accuracy.
And about the LS4 block that five7kid mentioned, it really is very different from all other LSx blocks, and likewise it's special crank. It's FWD only, except if swapped into a Fiero. The block is shorter, the crank is shorter at both ends, and other such.
Old Oct 6, 2010 | 08:24 PM
Drew's Avatar
Except, and this is important... GM engine codes almost always start with L. All the way back to the 60's you'll find GM engine codes Lxx, and no Bxx engine codes. And the LT1 in the 9C1 and Impala SS had iron heads (instead of aluminum) and are still LT1's. Like it or not, L98 is the engine code.
You could argue that B2L triggered iron heads, or the cast iron manifolds, or any number of other items, but there's no concrete proof to back up those notions.
Old Oct 6, 2010 | 08:28 PM
Guest
Guest
Posts: n/a
Why is it important? Who says? The L is still there. Surely GM is allowed to move it. And if it was for the iron manifolds, then the LB9 / T5 cars would have had the same code, since they used the same high-flow exhaust manifolds. The dual-cat option was N96, IIRC, and both engines got that.
Old Oct 6, 2010 | 08:33 PM
Drew's Avatar
N96 is a wheel. N10 is a converter package.
Old Oct 6, 2010 | 08:41 PM
Drew's Avatar
Just for fun here are some Camaro engine codes from 67-up...
L03
L22
L30
L34
L35
L36
L39
L48
L65
L69
L78
L89
L98
LB8
LB9
LC1
LG3
LG4
LH0
LM1
LS1
LS3
LT1
LU5
Notice a pattern? Show me where B2L fits into that list.
Old Oct 6, 2010 | 08:52 PM
Drew's Avatar
Here's an even longer list...
L01 : ENGINE, GAS, 4 CYL 1.6L MFI, OHC
L01 : ENGINE, GAS, 6 CYL, 3.4L, MFI, OHC, V6, HO
L02 : ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC
L02 : ENGINE, GAS, 4 CYL, 2.0L, MFI
L03 : 5.0 LITER V-8 TBI ENGINE
L03 : ENGINE, GAS, 8 CYL 5.0L TBI
L04 : ENGINE, DIESEL, 4 CYL, 3.0L
L05 : ENGINE, GAS, 4 CYL, 2.0L, 1 TBI
L05 : ENGINE, GAS, B CYL, 5.7L, 1 TBI, V8
L06 : ENGINE, GAS, 8 CYL, 4.5L, MFI, HO
L08 : ENGINE EMISSION CHI
L09 : ENGINE, GAS, 6 CYL, 2.5L, FUEL INJECTION
L11 : ENGINE, GAS, 4 CYL, 1.9L, PREMIUM FUEL
L14 : 307 CID V8
L17 : ENGINE, GAS, 4 CYL, 1.6L, 2BBL
L18 : ENGINE, GAS, 8 CYL, 8.1L, MFI
L19 : ENGINE, GAS, 8 CYL, 7.4L, 1TBI, VB
L21 : ENGINE, GAS, 8 CYL, 7.4L
L22 : ENGINE, GAS, 6 CYL, 4.1L, 1BBL
L25 : ENGINE, GAS, 6 CYL, 4.BL, 1BBL
L26 : ENGINE, GAS, 8 CYL, 4.9L, MFI, V8
L27 : ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, HO (3800 SERIES)
L29 : ENGINE, GAS, 8 CYL, 7.4L, SFI
L30 : 327 CID V8 275HP
L30 : 305 CID V8
L31 : 409 CID V8 400HP (SPECIAL HIGH PERFORMANCE-SOLID LIFTER CAM)
L31 : ENGINE, GAS, 8 CYL, 5.7L; TRUCK
L32 : ENGINE, GAS, 6 CYL, 3.4L, MFI, V6
L33 : 409 CID V8 340HP ( LOW PERFORMANCE-HYDRAULIC CAM)
L33 : ENGINE, GAS, 8 CYL, 5.3L
L34 : ENGINE, GAS, 4 CYL, 2.0L, MFI, DOHC
L35 : ENGINE, GAS, 6 CYL, 4.3L, CPI, V6, 90 DEG
L36 : 427 CU. IN. ENGINE – 390HP
L37 : ENGINE, GAS, 8 CYL, 4.6L, V8 OHC
L38 : ENGINE, GAS, 4 CYL, 2.SL, 1 TBI, HO
L33 : ENGINE, GAS, 8 CYL, 5.3L ALUMIINUM
L40 : ENGINE, GAS, 4 CYL, 2.3L, MFI SOHC
L43 : ENGINE, GAS, 4 CYL, VORTEC 2200, HO
L44 : ENGINE, GAS, 6 CYL, 2.8L, MFI V6, HO
L46 : 350 CID V8
L47 : ENGINE, GAS, 8 CYL, 4.0L, MFI, OHC
L48 : ENGINE, GAS, 4 CYL, 1.4L, MFI, PREMIUM FUEL
L49 : ENGINE, DIESEL, 8 CYL, 6. SL
L4B : ENGINE, DIESEL, 4 CYL, 3.9L, CUMMINS
L52 : ENGINE, GAS, 5 CYL, 3.5L
L54 : ENGINE, GAS, 4 CYL, 1.8L, MFI, REG FUEL
L56 : ENGINE, DIESEL, 8 CYL, 6.5L, TURBO
L57 : ENGINE, DIESEL, 8 CYL, 6.5L HO
L59 : ENGINE, GAS, 8 CYL, 5.3L
L5J : TRIM COMBINATION, CLOTH, MED SLATE GRAY (J) (91)
L5Q : MOLDING COLOR, MED GRAY MET (91)
L61 : 230 CID 6 CYLINDER
L61 : ENGINE, 4 CYL, GAS, 2.2L, SAT-PONT-CHEV
L62 : 250 6 CYLINDER (HIGH PERFORMANCE)
L63 : 250 6 CYLINGER (SPECIAL HIGH PERFORMANCE)
L64 : ENGINE, FLEXIBLE FUEL, (GAS/ALC), 6 CYL, 3.1L, MFI
L65 : ENGINE, DIESEL, 8 CYL, 6.5L. TURB0, HO
L66 : 396 CID V8 265HP (2 BARREL)
L66 : 3.5L V6 ENGINE, HONDA/SATURN VUE
L67 : ENGINE, GAS, 6 CYL, 3.8L, YFI, V6, SUPERCHARGED
L68 : ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, SHORTER LENGTH
L69 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL, HO
L71 : 427 CU. IN. ENGINE – 435HP
L72 : ENGINE, GAS, 4 CYL, 1.3L, TBI
L73 : ENGINE, GAS, 4 CYL, I 6L, T8I, REGULAR FUEL
L74 : 327 CU. IN. ENGINE – 300HP
L74 : 327 CU. IN. ENGINE – 360HP (FUEL INJECTION)
L75 : 327 CU. IN. ENGINE – 300HP
L76 : 327 CU. IN. ENGINE – 340HP
L76 : ENGINE, GAS, 8 CYL, 5.3L, ALUMINUM
L77 : 283 CID V8 220HP (4 BARREL CARB)
L78 : ENGINE, ALCOHOL, 4 CYL, 2.0L, MFI, OHC
L79 : 327 CU. IN. ENGINE – 350HP
L80 : ENGINE, GAS, 6 CYL, 2.5L, MFI, HO
L82 : ENGINE, GAS, 6 CYL, 3.lL, MFI, V6, HO
L84 : 327 CU. IN. ENGINE – 360HP
L85 : 250 CID L6 (4 BARREL CARB)
L87 : 250 CID 6 CYLINDER (TURBO CHARGED)
L88 : 427 CU. IN. ENGINE – 430HP
L89 : ALUMINUM CYLINDER HEADS FOR L71
L90 : 250 CID 6 CYLINDER (LOW COMPRESSION)
L91 : ENGINE, GAS, 4 CYL, I.6 L, UFI, WHC
L92 : ENGINE, DIESEL, 4 CYL, 1.9 L, TURBO
L92 : ENGINE, GAS, 8 CYL, 6.2L' ALUMINUM
L93 : ENGINE, DIESEL, 6 CYL, 2.5L, TURBO
L96 : ENGINE, GAS, 8 CYL, 5.7L, MFI
L98 : 5.7-LITER V8 TPI ENGINE
L99 : ENGINE, GAS, 8 CYL, 4.3L, MFI
LA1 : ENGINE, GAS, 6 CYL, 3.4L, MFI
LA2 : ENGINE, GAS, 8 CYL, 4.5L, MFI
LA5 : ENGINE, GAS, 4 CYL, 1.8L, MFI, OHC, TURBO
LA7 : ENGINE, DIESEL, 4 CYL, 1.5L, ISUZU
LAP : WHEEL COLOR, CHARCOAL MET (91)
LAS : ENGINE, GAS, 6 CYL, 3.0L, TURB0
LAW : TRIM COMBINATION, VINYL, DK CHARCOAL, (W)
LB1 : ENGINE, GAS, 6 CYL, 4.3L, 4BBL, V6, 90 DEG
LB4 : ENGINE, GAS, 6 CYL, 4.3L, TBI, V6, 90 DEG
LB6 : ENGINE, GAS, 6 CYL, 2.8L, UFI, V6, TRANSVERSE
LB7 : ENGINE, DIESEL, 8 CYL, 6.6, DI, V8, TURBO, HO, DURAMAX
LB8 : ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, LONGITUDINAL
LB8 : ENGINE, GAS, 6 CYL, 2.5L, CHINA
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
LC0 : ENGINE, GAS, 4 CYL, 1.8L, UFI, TURBO
LC1 : ENGINE, GAS, 6 CYL, 2.8L, 2B8L, V6, LONGITUDINAL
LC2 : ENGINE, GAS, 6 CYL, 3.8L, 4FI, V6, TURBO, HO
LC3 : ENGINE, GAS, 6 YL, 3.8L, 2B8L, V6, 90 DEG
LC5 : ENGINE, GAS, 4 CYL, 1.5L, 2B8L
LC6 : ENGINE, GAS, 6 CYL, 2 0L, MFI, OHC
LC7 : ENGINE, GAS, 8 CYL, 4 IL, MFI
LC9 : ENGINE, GAS, 4 CYL, 1.6L, 2BBL, TOYOTA
LC9 : ENGINE, GAS, 8 CYL, 5.3L
LD2 : ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC
LD4 : ENGINE, GAS, 6 CYL, 4.1L, 4FI
LD5 : ENGINE, GAS, 6 CYL, 3.8L, 2B8L, V6
LD8 : ENGINE, GAS, 8 CYL, 4.6L, MFI, V8, OHC
LE2 : ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, TRANSVERSE
LE3 : ENGINE, GAS, 6 CYL, 4.1L, 2BBL, VARAJET STANDARD
LE4 : ENGINE, GAS, 4 CYL, 2.0L, MFI, OHC
LE5 : ENGINE, GAS, 4 CYL, 2.4L
LE8 : ENGINE, GAS, 8 CYL, 7.4L, 4BBL, HO
LE9 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL, HI COMP
LF3 : ENGINE, GAS, 8 CYL, 5.0L, TRUCK
LF5 : ENGINE, GAS, 8 CYL, 5.7L, 2BBL, HO
LF6 : 400 CID V8 225HP (2 BARREL)
LF7 : ENGINE, DIESEL, 4 CYL, 3.6L
LF8 : ENGINE, GAS, 6 CYL 3.0L, MFI, V6, REGULAR FUEL
LF9 : ENGINE, DIESEL, 8 CYL, 5.7L
LFA : ENGINE, GAS, 8 CYL, 6.0L
LG0 : ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC, HO
LG2 : ENGINE, GAS, 6 CYL, 3.8L, SFI, V6
LG3 : ENGINE, GAS, 6 CYL, 3.8L, MFI V6, HO
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
LG4 : ENGINE, DIESEL, 6 CYL, 7.8L, ISUZU
LG4 : ENGINE, DIESEL, 6 CYL, 7.2L, CAT
LG6 : ENGINE, GAS, 6 CYL, 3.1L, TBI, V6,
LG7 : ENGINE, GAS, 6 CYL, 3.3L, MFI, V6
LG9 : ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, TURBO
LGB : ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
LGS : ENGINE, GAS, 6 CYL, 3.1L, 4FI, V6, TURBO
LH0 : ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
LH2 : ENGINE, GAS, 8 CYL, 4.6L NORTHSTAR
LH6 : ENGINE, DIESEL, 8 CYL, 6.2L
LH6 : ENGINE, GAS, 8 CYL, 5.3L
LH7 : ENGINE, GAS, 6 CYL, 2.8L, 2BBL, 60 DEG, TRANSVERSE
LH8 : ENGINE, GAS, 4 CYL, 1.8L, 1 TBI, OHC
LH8 : ENGINE, GAS, 8 CYL, 5.3L
LIP : WHEEL COLOR, SILVER (91)
LJ5 : ENGINE, DIESEL, 4 CYL, 1.8L
LK5 : ENGINE, GAS, 4 CYL, 2.8L
LK9 : ENGINE, GAS, 6 CYL, 3.0L, 2BEL, V6
LL2 : ENGINE, GAS, 6 CYL, 2.8L, 1 TBI, V6, 60 DEG, HO
LL4 : ENGINE, DIESEL, 8 CYL, 6.2L, HEAVY DUTY
LL8 : ENGINE, GAS, 6 CYL, 4.2L
LLR : ENGINE, GAS, 5 CYL, 3.7L
LLV : ENGINE, GAS, 4 CYL, 2.9L
LK5 : ENGINE, GAS, 4 CYL, 2.9L
LM1 : ENGINE, GAS, 8 CYL, 5.7L, 4BBL
LM3 : ENGINE, GAS, 4 CYL, 2.2L, 1 TBI
LM4 : ENGINE, GAS, 8 CYL, 5.3L, MFI, IRON, GM
LM7 : ENGINE, GAS, 8 CYL, 5.3L
LM9 : ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, TURBO
LMG : ENGINE, GAS, 8 CYL, 5.3L, IRON BLOCK, ALUM HEAD
LMM : Engine, Duramax Diesel 6.6L V8
LN2 : ENGINE, GAS, 4 CYL, 2.2L, MFI
LN3 : ENGINE, GAS, 6 CYL, 3.8L, MFI, V6 (3800 SERIES)
LN7 : ENGINE, GAS, 6 CYL, 3.0L, MFI, V6, HO
LN8 : ENGINE, GAS, 4 CYL, 2.5L, 1 TBI LONGITUDINAL
LNJ : ENGINE, GAS, 6 CYL, 3.4L, SFI
LP2 : ENGINE, GAS, 3 CYL, 1.0L, TBI, OHC, SUZUKI
LPS : ENGINE, GAS, 8 CYL, 5.7L, 2BBL, HO
LQ1 : ENGINE, GAS, 6 CYL, 3.4L, MFI, OHC, V6, HO
LQ2 : ENGINE, GAS, 4 CYL, 2.0L, MFI
LQ4 : ENGINE, GAS, 8 CYL, 6.0L, MFI, IRON, GM
LQ6 : ENGINE, GAS, 8 CYL, 4.5L, MFI, HO
LQ7 : ENGINE, DIESEL, 4 CYL, 2.2L, ISUZU
LQ9 : ENGINE, GAS, 8 CYL, 6.0L, MFI, IRON, GM, HO
LR1 : ENGINE, GAS, 4 CYL, 1.95L, 2BBL
LR2 : ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, 60 DEG, TRUCK
LR4 : ENGINE, GAS, 8 CYL, 4.8L, MFI, IRON, GM
LR6 : ENGINE, GAS, 8 CYL, 4.5L, 2TBI
LR8 : ENGINE, GAS, 4 CYL, 2 .8L, 1 TBI,
LR9 : ENGINE, GAS, 4 CYL, 2.0L, 2BBL
LS1 : 5.7L GEN III V8 ENGINE
LS2 : 6.0L GEN III V8 ENGINE, SFI
LS3 : 402 CID ENGINE, CHEVROLET
LS3 : ENGINE, GAS, 3 CYL, 1.0L, MFI, OHC, TURBO, SUZUKI
LS3 : 6.2L GEN III V8 ENGINE, CORVETTE
LS4 : ENGINE, GAS, 5.3L FWD
LS4 : 454 CID V8 235HP (4 BARREL)
LS5 : ENGINE, GAS, 4 CYL, 1.6L. I TBI, OHC, ALUMINUM
LS5 : ENGINE, GAS, 8 CYL, 454 CID, 4 BBL
LS6 : 454 CID V8 450HP (SPECIAL HIGH PERFORMANCE & 4 BARREL)
LS7 : 454 CID V8 (HEAVY DUTY & 4 BARREL)
LS9 : ENGINE, GAS, 8 CYL, 5.7L, 4BBL
LSA : ENGINE, DRESS KIT, 4.3L, UPS RETROFIT
LSJ : ENGINE, GAS, 4 CYL, 2.0L, MFI
LST : ENGINE, DIESEL, 4 CYL, 3.9L, CUMMINS MBT
LT1 : ENGINE, GAS, 8 CYL, 5.7L, TPI, HO
LT2 : ENGINE, GAS, 4 CYL, 2.0L, TBI, OHC
LT3 : ENGINE, GAS, 4 CYL, 2.0L, MFI, OHC, TURBO
LT4 : 5.7L GEN III V8 ENGINE
LT5 : ENGINE, GAS, 8 CYL, 5.7L, MFI, OHC
LT6 : ENGINE, DIESEL, 6 CYL, 4.3L, V6, LONGITUDINAL
LT7 : ENGINE, DIESEL, 6 CYL, 4.3L V6, TRANSVERSE
LT8 : ENGINE, GAS, 8 CYL, 4.1L, 2T8I
LT9 : ENGINE, GAS, 8 CYL, 5.7L, 4BBL, HD
LU2 : ENGINE, GAS, 6 CYL, 4.3L, TBI V6, 90 DEG, HO
LU3 : ENGINE, GAS, 6 CYL, 4.3L, MFI, V6, 90 DEG
LV2 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
LV4 : ENGINE, GAS, 4 CYL, 1.6L, OHC, TURBO, PREMIUM FUEL
LV6 : ENGINE, GAS, 4 CYL, 1.8L, MFI
LW0 : ENGINE, GAS, 4 CYL, 1.6L, MFI, OHC, HO
LW2 : ENGINE, GAS, 8 CYL, 4.5L, MFI
LW5 : ENGINE, GAS, 6 CYL, 3.0L, TURBO
LW9 : ENGINE, GAS, 6 CYL, 3.6L
LX8 : ENGINE, DIESEL, 4 CYL, 2.OL TURBO
LX9 : ENGINE, 6 CYL, 3.5L, SFI
LY2 : ENGINE, GAS, 8 CYL 4.8L SFI
LY5 : ENGINE, GAS, 4 CYL 1.6L 2BBL REGULAR FUEL
LY5 : ENGINE, GAS, 8 CYL 5.3L
LY6 : ENGINE, GAS, 8 CYL 6.0L SFI
LY9 : ENGINE, GAS, 3 CYL 1.0L 2BBL OHC, SUZUKI
Drew's Avatar
And now here's a long list of B codes...
B01 : HEAVY DUTY BODY
B02 : EQUIPMENT, SOUTH AFRICA
B05 : BODY EQUIPMENT ARMORED
B07 : EQUIPMENT, INDIA
B09 : EQUIPMENT, EGYPT
B18 : ORNAMENTATION, INTR, DELUX
B19 : ORNAMENTATION, INTR, CUSTOM
B1A : PORT OF ENTRY CAMI
B1B : MODIFICATION FOUR SEATER
B1J : LINER FENDER
B1N : TIRE ALL, P165/65R13 BL R/PE ST TL AL3
B1R : TIRE ALL, P185/60VR14/N BL R/PE ST TL AL3
B1Y : MERCHANDISED PKG, SPECIAL COMPONENTS
B20 : ORNAMENTATION, INTR, LUXURY
B22 : ORNAMENTATION, INTR, EMBLEM, DR INNER PANEL
B23 : ORNAMENTATION, EXTR WHEEL OPG SPOILER
B24 : ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEALS
B25 : TRIM EQUIPMENT LUGG COMPT, DELUXE
B26 : ORNAMENTATION, INTR, DR PULL HANDLES, FRT
B29 : ORNAMENTATION, INTR, DR PULL HANDLES, RR
B2E : SALES, SPRING SPECIAL PACKAGE
B2K : CALLOWAY TWIN-TURBO
B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B2M : POWER STEERING DELETE
B2Q : PANEL, RR ROOF, BLACK ---DELETE
B2S : SPRING , REAR LEAF TRANSVERSE (LH)
B2U : SPRING, REAR LEAF TRANSVERSE (RH)
B2W : TIRE ALL, P205/75R15/N R/PE 0WL TL 00R (TRACKER)
B2Z : MERCHANDISED PKG, DELUXE VAN
B30 : COVERING, FLOOR CARPET
B32 : COVERING, FRT FLOOR MATS AUX
B33 : COVERING, REAR FLOOR MATS AUX
B34 : COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS, CARPETED INSERT
B36 : COVERING, FLOOR MAT, LUGG COMPT
B37 : COVERING, FLOOR MATS, FRT & RR AUX
B39 : COVERING, FLOOR CARPET, LOAD FLOOR
B3D : EQUIPMENT, SCHOOL BUS
B3H : COVERING, FLOOR CARPET, LOAD FLOOR ---DELETE
B3J : EQUIPMENT DIESEL
B3K : TIRE ALL, P145/BOR12/N BL R/PE ST TL ALS
B3M : EQUIPMENT, SCHOOL BUS, DELUXE
B3S : TIRE ALL, P205/50R15/N BL R/PE ST TL HW4
B42 : COVERING, FLOOR MAT, LUGGAGE COMPARTMENT FITTED
B43 : COVERING, LOAD FLOOR, TEXTURED SURFACE
B44 : COVERING, LOAD FLOOR, LOOSE
B46 : TRIM EQUIPMENT, SPECIAL ORDER
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B49 : DELUXE CARPET FLOOR COVERING
B4A : PANEL ROOF, BLACK --- DELETE
B4C : SALES, SPECIAL SERVICE PKG
B4F : PACKAGE, SECURITY LIGHTING
B4H : MODIFICATION, NOISE CONTROL, EXPORT
B4K : HANDLING CHARGE, TARRYTOWN T0 MIDWAY COACH
B4M : VEHICLE, CUSTOM FEATURE PACKAGE
B4N : HANDLING CHARGE, TARRYTOWN T0 ESSEX MD T0 T & B IN
B4O : MERCHANDISED PKG, ‘GT’
B4P : RADIATOR BOOST FAN
B4U : PERFORMANCE PACKAGE, SPORT
B4Z : IROC PACKAGE
B50 : FOAM RUBBER SEAT CUSHION
B51 : MOLDING, ROCKER, EXTRA WIDE
B53 : COVERING FRT, FLOOR MATS, CARPETED INSERT DELUXE
B54 : COVERING REAR, FLOOR MATS, CARPETED INSERT DELUXE
B55 : DELUXE FRONT SEAT CUSHION
B56 : MOLDING ROCKER,COLORED
B57 : ORNAMENTATION P EXTR DELUXE
B58 : COVERING, FLOOR MATS, FRT & RR, CARPETED INSERT
B5A : PACKAGE, INDY CONVERTIBLE
B5I : PACKAGE, INDY "GT"
B5S : FLEET INCENTIVE, D & K FINANCIAL
B5Z : SALES, EXTR APPEARANCE
B60 : DECAL PACKAGE, 01
B65 : COVERING, FLOOR SIDEWALL TRUNK
B67 : CONTAINER, RADIO CASSETTE TAPES
B69 : CONTAINER, COMPACT DISCS
B6O : DECAL PACKAGE, 01
B6Q : DECAL PACKAGE, 02
B6R : DECAL PACKAGE, 03
B6S : TRAVEL BED PACKAGE
B70 : INSTRUMENT PANEL PAD
B71 : MOLDING WHL OPENING, COLORED
B72 : ORNAMENTATION, EXTR MLDG BELT REVEAL COLORED
B74 : MOLDING WHL OPENING, EXTRA WIDE
B75 : TRIM EQUIPMENT, LUGG COMPT LINING
B77 : ORNAMENTATION, EXTR MLDG W/S REVEAL, COLORED
B79 : ORNAMENTATION, EXTR RR END
B7N : BODY EQUIPMENT, PICKUP BOX PANELS (NON-PRIME)
B7P : BODY EQUIPMENT, PICKUP BOX PANELS (PRIME)
B80 : ORNAMENTATION, EXTR MLDG ROOF DRIP
B81 : MOLDING B/S ---- DELETE
B82 : ORNAMENTATION, EXTR EMBLEM ---- DELETE
B83 : MOLDING ROCKER, NARROW
B84 : ORNAMENTATION, EXTR MLDG, BODY SIDE
B85 : ORNAMENTATION, EXTR MLDG BELT REVEAL
B87 : ORNAMENTATION, EXTR EMBLEM FENDER---DELETE
B88 : MOLDING B/S CUSTOM
B89 : ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL,
B90 : ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
B91 : ORNAMENTATION, EXTR MLDG, DR EDGE GUARD, COLORED
B92 : ORNAMENTATION, EXTR FRT FENDER NAME
B93 : ORNAMENTATION, EXTR MLDG, DR EDGE GUARD
B94 : FENDER EMBLEM, Z28
B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR 1
B95 : REAR PANEL MOLDINGS
B96 : MOLDING WHL OPENING
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
B98 : STRIP BODY SIDE, DELETE
B99 : MOLDING WHL OPENING,---- DELETE
B9K : ORNAMENTATION, B/S MLDG, REAPPLY TO RR DOORS ONLY
B9Q : MODEL CONVERSION, HEARSE
BA0 : ORNAMENTATION, EXTR, DOOR, NAMEPLATE
BA1 : ORNAMENTATION, EXTR HOOD
BA3 : COMPARTMENT, STOWAGE, INSTRUMENT PANEL LOWER
BA5 : ORNAMENTATION, EXTR CUSTOM
BA6 : COMPARTMENT, RR, PACKAGE SHELF, STOWAGE
BA8 : COMPARTMENT, FRT SEAT STOWAGE, PASS
BA9 : COMPARTMENT, FRT SEAT STOWAGE, DRIVER
BAG : PARTS PACKAGE EXPORT
BAK : DIAGNOSTIC SYSTEM, OBD 2 EMISSION REQUIREMENTS
BB2 : TRIM, LUGG COMPT LINING ---- DELETE
BB3 : ORNAMENTATION, INTR, DR POCKET, INNER LINING,
BB4 : ORNAMENTATION, INTR, DR POCKET, INNER LINING, LEFT
BB5 : ORNAMENTATION, INTR, HEADLINER
BC1 : ORNAMENTATION, INTR, I/P
BC2 : ORNAMENTATION, INTR, I/P, WOOD GRAIN
BC3 : ORNAMENTATION, INTR, I/P, DELUXE
BC4 : ORNAMENTATION, INTR, COAT HOOK RETRACTABLE
BC5 : ORNAMENTATION, INTR, LOAD COMPT CARPET PANELS
BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
BC9 : ORNAMENTATION, EXTR, HOOD ---- DELETE
BD1 : ORNAMENTATION, EXTR, MLDG, ROCKER PNL ---- DELETE
BD2 : ORNAMENTATION, EXTR ---- DELETE
BD3 : ORNAMENTATION, INTR ACCEL/BRAKE PEDAL
BF1 : COVERING, REAR FLOOR MATS----DELETE
BF2 : COVERING, FLOOR CARPET, DELUXE
BF3 : COVERING, STEP WELL MAT
BF4 : COVERING, FLOOR CARPET, CUSTOM
BF9 : COVERING, FRT FLOOR MAT----DELETE
BG4 : TRIM OVERRIDE, INTERIOR, BIG FOUR
BG5 : COVERING FLOOR, --DELETE
BG9 : COVERING FLOOR, RUBBER
BGR : BOWLING GREEN PLANT PROCESSING
BNC : Body Mount Cushions
BP4 : RADIATOR BOOST FAN
BPH : APPEARANCE PACKAGE CHEVROLET “OFF ROAD”
BS1 : INSULATION, ACOUSTICAL PKG
BS2 : INSULATION, ACOUSTICAL PKG, ADDED MATERIAL
BS4 : INSULATION, BACK PNL
BS6 : SEAL, DR
BT1 : FLEET INCENTIVE, HAYES -- AVIS
BV1 : FLEET INCENTIVE, LAND O'LAKES (J/L/W-TRK CKMST)
BV2 : ORNAMENTATION, EXTR RR COMPT LID
BV3 : ORNAMENTATION, INTR, I/P, BLACK
BV6 : ORNAMENTATION, EXTR LOCK CYLINDER, PAINTED
BV7 : ORNAMENTATION, EXTR PLR APLQ ---- DELETE
BV8 : ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
BV9 : ORNAMENTATION, EXTR MLDG, BODY SIDE, WOOD GRAIN
BVE : STEPS RUNNINGBOARD, SIDE, BLACK
BVF : STEPS RUNNINGBOARD, SIDE, COLOR KEYED
BW1 : ORNAMENTATION, EXTR RR END
BW2 : MOLDING B/S, DELUXE
BW3 : ORNAMENTATION, EXTR ROOF WINDOW TRIM, PAINTED
BW6 : ORNAMENTATION, EXTR PLR APLQ, COLORED
BW7 : ORNAMENTATION, EXTR PLR APLQ
BW8 : ORNAMENTATION, EXTR, EMBLEM, BODY, RR
BX1 : ORNAMENTATION, EXTR FRT END, SPECIAL
BX2 : MOLDING B/S, LOWER, EXTRA WIDE
BX3 : ORNAMENTATION, EXTR WOOD GRAIN SIDE PNL
BX4 : ORNAMENTATION, EXTR MLDG, BODY SIDE, BRIGHT
BX5 : ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED
BX6 : ORNAMENTATION, EXTR MLDG, APLQ, CAB BACK PNL
BX8 : ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL ----
BX9 : ORNAMENTATION, EXTR FRT END PNL
BY1 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3
BY3 : HEADLINER
BY4 : ORNAMENTATION, INTR, INST PANEL, NAME PLATE
BY8 : ORNAMENTATION, EXTR FRT DECOR PLATE
BYD : TRIM EQUIPMENT, EXTERIOR, RED
BYP : SALES, SPORT EQUIPMENT PKG
Whole lotta engines in the B codes aren't there...
GM groups codes by the first digit... All the G codes are axle related, N codes are typically wheels, L codes are engines, B codes are packages and options.
We know that B2L has something to do with the engine, but it doesn't make any sense for it to be the engine code. Common sense and human logic shows L98 is the engine code.
Old Oct 10, 2010 | 05:19 PM
jayjay23's Avatar
The only thing i am getting at is people say lsx swap and how much harder is it to say ls6 swap, ls7 ls3 ls1 swap. If you had a ls6 and another guy had a ls1 would you want him to say its the same. is a 350sb 383sb a 400 sb 327 all the same. i dont think so. So if you say lsx how about have a LSX. if you read the whole thing that i wrote i wrote that people used it as a x factor but i think it is retarded. if you are going to not specify wich one then just put ls or lt. If you are going to put: ls1 ls2 ls3 ls6 ls7 ls9 or LSX. The other thing is i have a LSX block and it cost as much as a LS swap. not to mention the twin AR70 T4s next to it. Mine is the LSX bored and displaced as a 427 not a LS1 diff of 500hp
Old Oct 10, 2010 | 06:01 PM
five7kid's Avatar
When you get the rest of the world to behave the way you think it should, let us know and we'll apply your desires to TGO as well...
Often, someone will say something to the effect of, "I'm going to do a 2003 Vortec swap...", and wonder if their V6 TH700R-4 will be okay to use. We'll respond, "You're basically looking at an LSx swap, so check out the sticky for the basics of what you're looking at." Or, they know they want the new technology, but aren't sure which displacement to go after, so they say, "I am considering an LSx swap..."
Really, in the grand scheme of things, which is worse? Continuing to use the term "LSx" in a clearly understood although less than a technically correct fashion, or the current state of the federal debt?
Old Oct 10, 2010 | 06:15 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Numbers in place of words came from Counterstrike actually, it's called 1337 sp34k.
Old Oct 10, 2010 | 06:34 PM
Oelmuvun's Avatar
Car: 1986 Firebird Trans AM
Engine: LG4
It pre-dates counterstrike considerably. IIRC it started being used during the 80's on some BBSes or on other similar setups/networks. Possibly earlier but I do not know hard years.
Old Oct 10, 2010 | 06:52 PM
Shift06's Avatar
Maybe so, but I'd say Counterstrike is what made it "popular".
Old Oct 10, 2010 | 09:50 PM
BlueZee28's Avatar
The real question here is why does it make the original poster so uncomfortable that people use LSx instead of dropping one letter off and using LS? It's one letter, is it going to make that bog of a difference? You argue that saying LSx groups them all together and makes them sound like they're all the same, which could make someone with an LS3 mad that someone calls it the same thing as an LS1... But wouldn't calling them "LS" swaps also group them together, keeping them non-differentiated?
I think I'll keep saying LSx because it's funny that it gets under your skin so badly lol
Old Oct 11, 2010 | 10:08 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The LSx and LTx is used on more than just this board alone, it's become a common phrase to use. Even alot of publications are using them and when the reference the mac daddy block, they put LSX since that is the name of it.
Old Oct 11, 2010 | 11:20 AM
Aaron91RS's Avatar
Car: RS
Hey guess where I and a bunch of other people were this weekend!
Hurts don't it?
Old Oct 11, 2010 | 02:46 PM
BlueZee28's Avatar
And I'm going to venture to say that the majority of the LSx powered cars there didn't have the actual "LSX" block too eh?
Old Oct 11, 2010 | 06:14 PM
Pocket's Avatar
Car: 91 Trans Am
The ones you read about actually putting down good times in a 1-2 year old vehicle will
Old Oct 11, 2010 | 07:19 PM
  #42
jayjay23's Avatar
its funny that you think it gets under my skin, im in afghanistan and bored out of my mind. the truth is you did what i wanted, a good argument. thank you and dont change. i know this will not change anyones mind but look at all the posts. injoy
Old Oct 11, 2010 | 07:22 PM
  #43
jayjay23's Avatar
Hurts don't it?
so how was the shoot out and what did you take. i was looking at it and wanted to go but got extended here for another 2 months go fig. put up details of it please.
Old Oct 11, 2010 | 07:28 PM
  #44
jayjay23's Avatar
it sounds like it was me that got under your skin, and im sorry. but i have seen your car and its really clean i like it. nothing personal just wanted to see a reaction. and to make it any better i striped my LSX project (3rd gen) to build a 1st gen. i used the parts from mine to build up my lil bros 88 iroc. i kept the engine to drop in the 67. if you have anymore guestions be sure to ask me, im all about it. even worst ive worked on my 87 for 4 years and never cranked it. injoy that i know you will have a hay day with it
Old Oct 11, 2010 | 09:52 PM
  #45
BlueZee28's Avatar
It's not under my skin lol
I just thought it was grinding your gears that people called them LSx swaps and it tickled me to death lol
It seems like that's not the case though, so nevermind
Old Oct 12, 2010 | 11:09 PM
  #46
jayjay23's Avatar
lol well at least we are both getting injoyment out of it. i didnt want to **** people off, just see what people said. and like i said i dont care. one more thing i think your car is wicked, send me a message and we can talk. like i said i am deployed and dont really want to think about what i do everyday. just like to talk about other things besides flying and dieing.
Old Oct 13, 2010 | 03:07 PM
  #47
five7kid's Avatar
When you put it that way...
Old Nov 17, 2010 | 01:32 PM
  #48
mightymaro94's Avatar
isnt that what all them honda's want for their engine swaps? lol
Old Nov 17, 2010 | 03:16 PM
  #49
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
47 posts about an "x".
Amazing.
Old Nov 17, 2010 | 03:43 PM
  #50
Amazing.
backtothe80s
Sep 5, 2015 12:39 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
86White_T/A305
Aug 17, 2015 12:16 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
