2010 Camaro long tubes
Old Oct 10, 2010 | 08:01 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
I bought a set of painted pacesetter 2010 camaro headers to see if they would fit. If your car is stock height, these will probably work for you. They hang down a little too low for my car. I only fit the driver side, but I don't see why the passenger wouldn't fit. I have a tubular k member, so I don't know if they will fit a stock kmember...looked like it had plenty of room though. I'll be selling these if anyone is interested. Here are a few cell phone pics.
Old Oct 10, 2010 | 08:38 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 2010 Camaro long tubes
Those hang LOW
Thanks for the pic, it confirms the 5th gen shorties/mids will fit
Old Oct 10, 2010 | 09:03 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
They look like they hang about as low as the hooker sbc headers for these cars. But it's been a while since I've seen that.
Old Oct 10, 2010 | 10:17 PM
bigals87z28's Avatar
Car: Check The Sig
Little low, but clear everything else pretty darn good!
Old Oct 10, 2010 | 10:28 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I agree, I think they'd be too low once the car in on the ground. My car is not high enough to fit my floor jack under the kmember without lifting the front end manually, and those look lower than the kmember by a couple inch's. Got any pics on the ground?
Old Oct 11, 2010 | 12:10 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yea, verify the passenger side if you can. As well as getting a snap of the K member area by the oil pan to verify the stock K member distance if possible.
Old Oct 11, 2010 | 07:48 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
No pics on the ground. Once I saw how low they hung, I took them off. With how low my car is, there was NO chance of them working.
I just built my exhaust and got everything hooked up, so I won't be doing any more fitting. The passenger side is a bit of a bear to remove in my car anyway. I would be happy to sell these and let someone else try though.
Old Oct 11, 2010 | 07:58 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that's EXACTLY what i was thinking...so not really bad at all in my opinion. this may be a viable option for the little brother's car....
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
Street Lethal
Aug 13, 2015 08:28 PM
