tips an tricks for my 89 iroc + 2000 ws6 =
Old Nov 16, 2010 | 04:10 PM
NotTyler's Avatar
So I bought a 2000 ws6 w/ 72k on it as a donor car for my iroc. I have read all the stickes an researched it but I still would like to hear some tips an tricks on doin. This swap. I do plan on runnin a/c an notching my k member. So let's here tips from you guys who have done this, stuff you wish you would have known before you sttarted. Any help is appreciated! Ill get y'all some pics up tonight.
Tyler
Old Nov 16, 2010 | 04:44 PM
Z28FAST1's Avatar
Re: tips an tricks for my 89 iroc + 2000 ws6 =
1. Make sure you have sufficient oil pan to cross member clearance.
2. Replace motor mounts with polyurethane mounts while the engine is out.
3. If you run hawks long tubes, make sure you get them wrapped or coated because they dissipate a lot of heat into the interior.
4. If possible have your harness extended so that you can mount the ECM in the stock location.
5. It’s easier to lift the car’s body and drop the entire cross member with engine and trans, etc.
6. Use everything salvageable from the 4th gen, fuel tank, fuel lines, radiator, fans, etc.
7. Post a thread on LS1tech parting out the unused parts to recoup some $$$.
Oh and post some pics.
Old Nov 16, 2010 | 05:12 PM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
+1 on taking the motor out of the bottom and offsetting the cost by selling whatever you don't use
Also plan for extra time and extra funds.
Might as well replace the clutch while the engine and trans are out. For that matter, make whatever changes you want to/ can while the guts are out of the car, cause there's no easier time.
Prepare for some frustration but push through it. There's no better feeling than starting it for the first time. Except, of course doing burn outs for the first time!
Keep us posted.
Old Nov 16, 2010 | 06:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
grab an LS6 intake
try the rads and fans, they are awesome at cooling
Old Nov 16, 2010 | 06:45 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
* Do the tubular k-member before the engine is in.
* Don't use a 700r4
Old Nov 16, 2010 | 11:05 PM
NotTyler's Avatar
Well the ls1 I'm putting in has the bbk intake mani. and a bbk 85mm tb. And is the tubular k member that much of a necessity? I was really hoping to notch my k member.
Old Nov 17, 2010 | 07:37 AM
Pocket's Avatar
Car: 91 Trans Am
Tubular K makes life easy from being thin and light (somewhat)
It is not required
Old Nov 17, 2010 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use the Hawks LS1 swap transmission crossmember. It doesn't mount the torque arm to the crossmember, but it'll make exhaust routing a whole lot easier. My LS1/4L60E swap is doing just fine with their crossmember, stock 2000 transmission mount (which has fail-safe provision, unlike 3rd gen or poly tranny mounts), and a BMR adjustable torque arm.
There's no "free lunch" with regard to the 4th gen tank. The 4th gen fuel gauge sending unit is not compatible with 3rd gen fuel gauges. I hear you can use the V6 sender, but haven't pursued it, personally.
What year is your IROC? Electric vs. cable drive speedometer is the issue. If electric, you're golden. If cable drive, you've got decisions to make.
You will need to have the PCM reprogrammed, most likely. If you put ALL of the 4th gen parts in your car (emissions, rear end, instrument panel, etc.) you might avoid that. But, for most of us, something needs to be reprogrammed (tach output, gears, tire size, emissions, etc.).
Old Nov 17, 2010 | 07:05 PM
Pocket's Avatar
Car: 91 Trans Am
Title says 89 which was the last year for a cable
He'd need the $300 cable-x box or upgrade the gauges (usually over $300 total)
Old Nov 17, 2010 | 07:39 PM
five7kid's Avatar
I looked for the model year, and completely missed what he said in the title.
Old Nov 17, 2010 | 07:41 PM
five7kid's Avatar
Got my Cable-X for $249 + shipping off of eBay.
He's got the whole 2000 car, right? Shouldn't cost anything to upgrade the gauges. Just the hassle of swapping the whole 4th gen dash.
Old Nov 17, 2010 | 07:52 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
he dosent have to switch the dash to put the 4th gen gauges in.. just a lil triming behind the gauges
Old Nov 17, 2010 | 07:59 PM
five7kid's Avatar
True. But, I'll have to admit the full dash swap looks a lot better (IMO).
Old Nov 17, 2010 | 08:02 PM
Engine: ls1 soon
yep yep totally agree with u there.. thats what im doing..
Old Nov 18, 2010 | 07:57 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
+2 On that.
Frozer!!!
Jan 19, 2024 04:55 PM
Mickeyruder
Sep 2, 2015 02:45 PM
neekolzun
Aug 24, 2015 04:59 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mustangman65_79
Aug 11, 2015 03:17 PM
