Took a big step forward
Old Dec 1, 2010 | 11:03 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
After some annoying set backs, I fired the engine up. This was a brand new block with my first heads/cam/intake swap. It literally wanted to run instantly.
After a short run and flames out the passenger header I shut it down. Super rich on one side and squeeky clean on the other. A check of the DTC's showed no MAF or MAP voltage. A quick look reveiled no voltage on the drivers side coils either! A quick wiring change gave me 12V on all three.
This is what I was rewarded with:
http://www.youtube.com/watch?v=lnQz80Cwogk
Old Dec 1, 2010 | 01:22 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Took a big step forward
Awesome. The first fire is always a great feeling of accomplishment
Amazing how much can be wrong with the engines and they still run too. A LSx engine can actually run on only 2 cyls
Old Dec 1, 2010 | 03:21 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
congrats in making some progress on your swap. still waiting to hear that sound on my setup, someday....
Old Dec 1, 2010 | 03:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I know all about running on only a few cylinders. When I fired it up for the first time I'm like yay sounds good to me and my buddys like dude, does this white connector need to be plugged into all the coils on the passenger side? I was like WTF. Plugged it back it fired it up and it sounded even better lol
Old Dec 1, 2010 | 08:57 PM
Omega's Avatar
Engine: LS1 / LS3
Well I'm glad I'm not the only one! Thanks for the kind words.
My new task is to stuff a 4" intake into the left or right side and make the Y-pipe.
Old Dec 2, 2010 | 07:12 AM
Pocket's Avatar
Car: 91 Trans Am
4" is some huge tubing. Drivers side is tight with the rad hoses. Pass side is better assuming you dont have a batt there
Old Dec 2, 2010 | 11:49 AM
Omega's Avatar
Engine: LS1 / LS3
The battery made it to the trunk to unclutter the engine bay... It was on the drivers side.
I did have my old intake on the passenger side, but the port I used for the steam vent interferes. I think I can plumb that back into the water pump without issues.
Old Dec 2, 2010 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Magnaflow spun cats?
Old Dec 3, 2010 | 04:38 PM
Omega's Avatar
Engine: LS1 / LS3
No, SLP high flows. I have a set of 3" spun cats as well, but they are reserved for the G8
http://cgi.ebay.com/ebaymotors/SLP-3...item4aa3224fa5
Old Apr 12, 2011 | 04:08 PM
Omega's Avatar
Engine: LS1 / LS3
It seems I have taken a few steps forward and a huge one back. The 4" aluminum tubing was a total PITA to MIG weld but with several hours of cleanup grinding it's a lot more clean looking.
Although low, the y-pipe is a snap to remove since I used v-band connectors.
Tuning is becoming a headache. The last time I started the car it wasn't running well. This time it refused to start.. for the entire day I worked on it. It seems the start up tune is/was/has been waaaay too rich which has totally fouled the plugs. After cleaning and regapping them and a ton of WOT cranking I had 2 of the cylinders lighting off. Not happy. I ordered new plugs (buying NGK TR55's locally is a joke). I'm going back to my start up tune using the MAF/MAP and hopefully it will be ok. Ive been using a SD only file for awhile as I tinker with it.. unsuccessfully it would appear.
Old Apr 12, 2011 | 09:48 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I actually re-did my 4" intake and it doesn't hit the radiator at all anymore, and it's on the driver side. I'm gonna make a thread on it because I think some of you might find it useful.
Old Apr 12, 2011 | 11:57 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
great build right there !
Gunner242
Dec 25, 2015 04:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
