5.3 cam?
Old 12-27-2010, 11:13 PM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
5.3 cam?
whats a good cam to run that wont effect the power accesorys..Lift .581 /.588 Duration .050 224° /230° RPM Range 2000-7000, i want a lopey cam, if i have to get different springs thats ok.i dnt want to have to do any machine work, im tryin to do this swap on an extremly low budget, thank you guys for all the help.
Old 12-27-2010, 11:15 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: 5.3 cam?
call comp or one of the other company's and ask them there really helpful and almost always give good input
Old 12-28-2010, 04:29 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 5.3 cam?
That cam you listed will have a fast lope, very racys and not hard, the motor will have ultra snappy low end throttle response as well. If that sounds like it would make you happy then go for it. If you are not looking for full out max power, you might have nailed the grind you will be satisfied with. Otherwise, a custom grind is about the best way to go.
Jorlain
10-08-2015 01:57 AM
customblackbird
10-01-2015 04:30 PM
Amillionoh7
09-11-2015 11:36 AM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: 5.3 cam?
