what is needed for lt1 or ls1 dual fan setup?
Old Jan 13, 2011 | 01:05 PM
92Camaro350TPI's Avatar
Car: 92 Camaro RS
Transmission: 350
currently i have a 92 camaro rs that was a v6 and was swapped for a 350 tpi from previous owner. at the moment it only has a single fan setup that isnt wired right, its wired to be on constantly and i dont know where to look for the stock wiring setup. so my main thing is, what is needed for a lt1/ls1 dual fan swap and where do i begin to look for the fan wiring? haynes manual kinda vague on electrical side of camaros :P, well at least to some1 that is learning electrical at the moment on my camaro :P. any help would greatly be appreciated
Old Jan 13, 2011 | 01:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: what is needed for lt1 or ls1 dual fan setup?
Your coolant fan switch in the passenger side cylinder head is likely broken causing the fan to run all the time. This is it's fail safe mode. There are numerous dual fan kits and wiring out there that can be ordered from any performance parts place. Many use the stock single fan since the LS1 runs a little cooler than the old full iron 3rd gen motors.
Old Jan 13, 2011 | 04:03 PM
Car: 92 Camaro RS
Transmission: 350
well i didnt have anythin on the passenger side in the head between cylinders 6 and 4, i have something between 3 and 5 on the opposite side though, would that be it? and i was tryin to get a setup from a salvage yard :P
Car: 92 Camaro RS
Transmission: 350
and im tryin to do a ls1/lt1 fan setup on a 90-92 tpi engine
Old Jan 13, 2011 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm trying to understand exactly what you're asking here. If you're asking how to get 4th gen LT1 or LS1 fans to work with TPI, my question is, "Why?" Do you have access to a 4th gen fan pair? I can tell you they physically mount differently, so IMO, it's not a good place to start.
It makes more sense to get a 3rd gen dual fan set-up (in fact, I got 3rd gen dual fan set-ups for both of my LS1 swaps). Use the 3rd gen TPI system stuff to control them.
Old Jan 13, 2011 | 06:03 PM
one92rs's Avatar
Car: SOLD!!!!!
i put a set of 4th gen fans on my 92 rs. made some aluminum brackets to mount it and a flexalite controller. when i do my ls swap it will be ecm controlled.
Old Jan 14, 2011 | 12:40 PM
Firebat's Avatar
I modified the 4th gen LT1 plastic shroud with a dremel by cutting it in half length-wise and used a 4th Gen LT1 radiator. I cut the "tabs" on the back of the radiator so the 3rdGen condenser would fit. The "tabs" are for the 4thGen condenser and are solid not hollow, so can be easily cut off.
Old Jan 14, 2011 | 02:53 PM
five7kid's Avatar
Yeah, but 3rd gen dual fans bolt in...
Old Jan 14, 2011 | 07:23 PM
one92rs's Avatar
Car: SOLD!!!!!
but dont pull as much air nor are they shrouded. and the only bolt in if all the parts are there.
Old Jan 15, 2011 | 06:39 PM
five7kid's Avatar
It's fairly easy to find all of the parts. I bolted in 3rd gen dual fans to both of my '82's, both of which came with mechanical fans from the factory.
3rd gen fans may not be shrouded, but they don't need to be. Unshrouded makes the cooling system more efficient when the fans aren't on.
Old Jan 15, 2011 | 06:46 PM
one92rs's Avatar
Car: SOLD!!!!!
dont tell that too all the manufactures then. i believe 99% of all cars have some kind of shroud on them.
air will move thru a radiator whether or not a shroud is present.
Old Jan 16, 2011 | 12:57 AM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Regardless of which system cools better, they both work fine. Your best bet is to find 3rd gen dual fans as they will be slightly more readily available, and you could just cut all the wiring for them out.
And choice #2 get either pair of fans or some aftermarket, whatever, get connectors for the fans and a painless electric fan kit. Reasonably priced and will come with all the directions you will need, very simple.
Old Jan 16, 2011 | 03:31 PM
Car: 92 Camaro RS
Transmission: 350
should i just get a set up like this? http://cgi.ebay.com/ebaymotors/2-12-...ht_3596wt_1165.
and if my fan runs constantly would the CTS be bad? cuz the relay has 4 wires... one goes to fuse box, one hot at all times, one to fan, and one wire that goes to ECM since the fan switch and CTS is wired to the ECM. So should i just cut the wire that leads to ECM from the fan relay and install a fan pressure switch to turn on both fans at once as if the were one?
Old Jan 16, 2011 | 07:15 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
should i just get a set up like this? http://cgi.ebay.com/ebaymotors/2-12-12-VOLT-ELECTRIC-SLIM-PULL-RADIATOR-FAN-MOUNTING-/150546475753?pt=Motors_Car_Truck_Parts_Accessories&fits=Model:Camaro|Make:Chevrolet|Year:1992&hash=item230d44eae9#ht_3596wt_1165.
Those fans would work fine you would just have to deal with them being attached to the radiator, and possibly being chinese junk. You could either run ignition power to the lead that goes to the ecm so they would come on when the key is on, or you could just run it to a 12volt switch.
And like I mentioned before the 3rd option is to buy a painless wiring kit and they will come on at 185 degrees and you never have to worry about forgetting to hit the switch.
http://www.summitracing.com/parts/PRF-30103/
Old Jan 16, 2011 | 10:21 PM
Car: 92 Camaro RS
Transmission: 350
but would it still work if i just cut the wire at the relay that goes to the ecm and install a fan switch to hook it up to? just want to make sure it wont make the check engine light pop up. cuz tomorrow ima prep it to hook up to the fan switch but ill just have to buy a connector for it later. im also gonna drain my coolant since it has 70/30 and ima make it back to 50/50. then im goin to make sure all the fins are straight on the a/c condenser so then ill know the fan is pulling all the air it can. then hopefully sometime this week i can get a timing light from my cousin and set the correct timing. if im missing my label, would i just set timing to 0 degrees?
onefreakz
May 14, 2018 12:15 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
