ls motor mount adaptor
Im swapping a 5.3 into my 85 transam, Im doing this on the cheap. Im looking for the adaptors to put the ls to my trans. I want to keep everything behind the engine stock.
So im looking for mounts that will put the ls motor to the stock trans.
Sorry im having a hard time explaining this.
Any help would be awesome
Thanks tim
Thanks tim
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: ls motor mount adaptor
use a crank spacer if using pre-ls1 trans and the spohn engine mount
http://www.summitracing.com/parts/TRD-4592/
Also never heard of a crank spacer. Where can i get one? and which one? Links would great
Thanks again
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Cannot find them on Ebay right now, but i used the 30$ swap plated in my 89 and they were straight up like what i s in that link you posted, it works, but the 1 inch set back i just got for my 86 TA will be better, they were about 45$, so be patient and watch Ebay for them to pop up unless you want to spend 55$ or so. But they work great.
Engine: ls1, LB9
idk if those will work, I know the old style wont the spohn ones do fit. the spacer is from gm and i think a few other company's use them too. gm used the spacer on 4l80e and the 6.0 on 2000? and newer trucks honestly this stuff is asked every 2 weeks
http://www.enginebuildermag.com/Arti...ankshafts.aspx
which one should i get if i want to use my stock trans crossmember?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The 1 inch set backs are supposed to retain the actual stock trans location. So that would be your best bet, you doing EFI or carbed?
If carbed, my budget thread i did the other day can give insight on new and used:
https://www.thirdgen.org/forums/ltx-...t-ls-swap.html
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
here's exactly what you are looking for to hook up your transmission: http://advanceadapters.com/product/3741/712500A.html
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
These are the mounts you want and are some of the best priced one around. The 1" setback mounts will keep your transmission very close to the stock location.
http://carshop.carshopinc.com/produc.../98457/CSP2370
The bellhousing of your stock transmission will bolt right up to your 5.3, but it requires a change for the torque converter to bolt up correctly. The truck motors came with two different flexplates, one is flat and one is curved (i think most 5.3's came with the curved flexplate). If you have the curved one you can just buy this hughes adapter and press in the rear of the crank. You will also have to egg out the torque converter bolt holes in the flexplate to make it work with the old style converter.
http://www.jegs.com/i/Hughes%20Perfo...0002/-1?CT=999
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
