T56 crossmember that works with long tubes
Car: '89 Firebird
Engine: 7.0L
What trans cross member, with torque arm relocation, will accommodate long tube headers? BMR?
Also, is there any different between torque arms from LT1 swaps vs. LS1 swaps? I assume they are all the same and I can look at any of these for my LSx project.
Car: '89 Firebird
Engine: 7.0L
Re: T56 crossmember that works with long tubes
I don't think that will clear the exhaust on both sides. It needs to have a double hump.
It doesn't have a torque arm relocation either. I will break my trans if I leave it on the tailshaft.
Car: 1991 Trans Am
Unfortunately there isn't an option like what you are looking for. You can either have the crossmember mounted tq arm or exhaust clearance. A couple have taken the Skulte/Hawks mount and welded a tq arm mount to it then recoated everything.
I wish there was something but I think if I get that far I will run a body mounted tq arm instead. Much better IMO
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You or a friend can buid one, that is what i did. Not pretty butit sirvives launches at the track at 6000, i dont have pics of the TQ arm relocation mount i cut off the spohn trans swap crossmember:
Transmission: 4L80E/4L80E
The Hawks crossmember has the double hump. But, as stated, it doesn't relocate the torque arm mount. Zone seems to be the only one who has done both.
Car: '89 Firebird
Engine: 7.0L
Uhg. Another reason I can't believe I'm pulling apart an 11 second 4th gen to make my '89 run. That's what happens when you can't bring yourself to part with something.
Thanks for the info, guys.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Good job man, any plans on removing the TQ arm from the trans? Or are you not worried about it? The severe duty of my car at the track made me glad to jump on a tubular setup.
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Thanks. I'm not quite finished a little grinding and some paint and it will look a lot better. At the moment only 2 1/4-20 bolts hold the mount up.
I had considered it but I just want to get the car roadworthy. If I find an aftermarket TA for cheap ill probably move the mount.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Ok cool, even with the stock TQ arm on my 86 TA, when i build the crossmember, i will be relocating the TQ arm from the trans, not only because it wont work for the TH400, i just dont like them tanking on my trans with a stall and cammed engine.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
My Spohn unit did not allow exhaust to clear without banging the ground...EVERYWHERE.
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
I have the Spohn one with TA relocation aswell, and I can´t believe how they built/designed it...Did they think our LS/T56 swap cars don´t need exhaust at all or what? There is just no way to route the drivers side exhaust tube with decent clearance. I´m even starting to think about cutting out a half moon shape out of the fram rail to route the tube there. I´m trying to find oval DR Gas 2x4" exhaust tubing here in Europe, but as usual, no luck. That would help some at least.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I tried that, the clearance still sucked.
Car: '89 Firebird
Engine: 7.0L
Spohn isn't the way to go for LS swap. And that goes for engine crossmember, too. The lack of good fit has been so well publicized that I can't believe he hasn't taken any corrective action. Hawks is blowing him away in that department.
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
Will this one work on ls1 with t56 & long tubes?
http://www.hawksthirdgenparts.com/tr...t566speed.aspx
Thanks,
Robbie
Thanks,
Robbie
Yes. It's what they say in the description, and what we're saying. It doesn't relocate the torque arm mount from the transmission, though.
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Im curious if that crossmember will hold the torque arm??
Engine: Cammed 6.0L LSX
I don't have any complaints with my Spohn k member. The cross member is a different story though.
Car: 1986 camaro
Engine: ls2
BlackphantomZ28
Aug 31, 2015 10:29 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
