Ls6 Swap Question
Old Jan 31, 2011 | 07:41 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Ls6 Swap Question
I wanted to know whats the best choice of a harmonic balancer for swaping my ls6 into my 1991 camaro rs
Old Jan 31, 2011 | 10:15 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Ls6 Swap Question
the harmonic balancer will depend on which accessory setup you go with. If the engine's otherwise stock, just go with a stock replacement.
Old Feb 3, 2011 | 06:38 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Its going to have stage 2 heads and cam and mostly bolt ons
Old Feb 3, 2011 | 08:28 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
He is talkin about your pulley set up. Is it an f body or vette system?
Old Feb 4, 2011 | 06:15 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Corvette
Old Feb 4, 2011 | 07:24 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
unless you're going for very big power or are doing a blown setup, I don't personally see any reason to change the balancer. what are we talking about for bolt ons?
Old Feb 4, 2011 | 08:40 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
85mm to 90mm fast intake E3 sparkplugs msd ignition coils and spark plug wires and duel flow master exhaust
Old Feb 4, 2011 | 08:49 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
definitely no need to change the balancer then
I'd skip out on the E3s and go for some delco or ngk plugs.
msd coils seem to be hit or miss - most opt to stick with the factory pieces with good luck
check around ls1tech, you may be able to get more advice on better places to spend wisely on upgrades
Old Feb 4, 2011 | 08:51 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Ok thanks for the help
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
