optispark?
Old Feb 3, 2011 | 07:31 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
optispark?
might be gettin a z28 soon with a lt1 but it has a bad optispark? what is this and how hard is it to replace?
-Tim
Old Feb 3, 2011 | 08:30 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: optispark?
-Tim
http://www.carcraft.com/howto/ccrp_0.../photo_11.html
^^This is an optispark and they are very expensive. Its the LTx's spark distributor and its located on the front of the motor behind the balancer and water pump. Have fun
Old Feb 3, 2011 | 09:06 PM
Car: 1990 camaro rs
Engine: 305 tbi
Re: optispark?
thanks, looks like I can get one from summit for $250 v the $375 from gmp and its more other places
Old Feb 3, 2011 | 10:24 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: optispark?
its really not that hard.. u can get to it with out removing the rad if ur good.. but removing that will make it easyier.. check out ltxtech.com lotta good help there
Old Feb 4, 2011 | 04:50 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: optispark?
I have never had to replace mine it's a GM one, and from what I've read thats the best way to go.
Old Feb 4, 2011 | 07:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: optispark?
the earlier versions weren't vented and were more prone to failure than the later revisions. depending on what you're doing, you may want to look into upgrading to later style
Old Feb 4, 2011 | 11:52 AM
Firebat's Avatar
Re: optispark?
Some on LTXTECH.com would recommend the Chandler motorsports optispark for about 100 or less off eBay. CMS is trying to get off of eBay and last I heard they are working on a website.
Other recommendations are the Dynaspark, which is supposedly the best optispark and most expensive at $600. Also the GM unit, or the GM unit with a MSD cap/rotor.
I would look into if its actually the optispark though. Could be just the cap and rotor. Could be something else like a fuel pump. People tend to jump to conclusion right away that the optispark is bad, replace it, and then find they still have a problem because they didn't check on other things first.
Old Feb 4, 2011 | 12:16 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: optispark?
100% with firebat^^^^^^^^^
If you have some cash its also a great idea to go OPTILESS by using the Ls1 pcm conversion from www.eficonnection.com thanks Mike......
Old Feb 4, 2011 | 01:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: optispark?
The aftermarket ones are junk, and are most of the reason that people think the Opti is junk. My '97 Z28 has only had two in its whole life (210k on it right now). The original one lasted to about 170k, till it failed when the water pump started to leak all over it. I replaced it with a new one from GM and haven't had any problem with it. The optispark is actually a very GOOD ignition system - its much more precise than anything the Gen 1 motors came with, and is far more accurate at high RPMs too.
Its located on the timing chain cover, just behind/below the water pump. You can get it out and the new one in without removing the balancer, but you will have to take out the water pump for sure. Before you put your new opti in, if its the vented style ('95-97) then use a thin bead of gasket silicone to seal up between the plastic 'distributor cap' and the distributor body, just as extra insurance agaist water damage. I did this and it helped - I even clean the engine with the wand at the carwash and don't worry about it at all. I never had a problem.
Old Feb 6, 2011 | 10:09 AM
Car: 1990 camaro rs
Engine: 305 tbi
Re: optispark?
Is there any way that I can check to see if its the cap and rotor vs the opti? also i dont think its a fuel problem. I was told that is the optispark from my friend who has the car currently. Either way I'll be getting the car I'm just trying to figure out what to buy first, appreciate the help everyone.
Tim
Old Feb 6, 2011 | 12:54 PM
Firebat's Avatar
Re: optispark?
This is a way to test the optispark in the car or with 12 volts. It requires a $10 or so voltmeter:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Feb 6, 2011 | 01:30 PM
Car: 1990 camaro rs
Engine: 305 tbi
Re: optispark?
thanks for the link
midge54
Dec 27, 2019 04:14 PM
L0tuS
Sep 4, 2015 11:16 PM
19irocz85
Aug 26, 2015 07:54 PM
Redwhisper
Aug 26, 2015 05:02 PM
Thirim
Aug 13, 2015 03:09 PM
