Gm oil pan?
Old Feb 13, 2011 | 01:08 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Gm oil pan?
Hey guys, I just saw this new oil pan for a ls1 in the new jegs magazine. Part number is-#809-19212593. I drove up to jegs today to check it out and buy a roll cage. It looks really similar and fits 55-02 or something like that but doesnt tell me much. The part im really liking is that it includes oil pan/pickup/dipstick/gasket/windage tray. Its only $159.99 and tahts alot better than paying more than that for used ****. Anyone know if it will fit?
Old Feb 13, 2011 | 02:10 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Gm oil pan?
Buddy of mine got one, it is a bit shorter than a truck pan and looks like one, i wouldnt try it.
Old Feb 13, 2011 | 01:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Gm oil pan?
It's about the same length as the aftermarket old school gen 1 deep sump sbc pans, which means if you hit something the kmember is higher than the oil pan and the pan will take the hit
Old Feb 13, 2011 | 03:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Gm oil pan?
That pan id the LH8 pan (also know as the hummer or muscle car pan). It is shorter than the truck pans but longer than the f bod pan. Its a no go for 3rd gens.
Old Feb 14, 2011 | 04:14 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Gm oil pan?
That is what i was thinking.
Old Feb 14, 2011 | 01:04 PM
1badeagle's Avatar
Engine: 370 LSX
Re: Gm oil pan?
I wish gm would make a affordable fbody pan for is.
Old Feb 14, 2011 | 01:19 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Gm oil pan?
Well, they just make what they need and we use what works, the F body pan does fit our older F bodies.
Old Feb 14, 2011 | 01:52 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: Gm oil pan?
Just get the f body pan from ebay or go around the ls1 forums.
Old Feb 14, 2011 | 02:47 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Re: Gm oil pan?
GM parts direct still sells the F-bod pans for ~$170, and they can be had used for around $100. That kind of prevents anyone from getting into the market, since whatever some one came out with would be hard pressed to compete against that with initial design and manufacturing costs.
Old Feb 16, 2011 | 10:23 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: Gm oil pan?
Ran across this.. I wonder how much these cost.http://blogs.carcraft.com/6735669/ed...pan/index.html
Old Feb 17, 2011 | 08:58 AM
RockJay81's Avatar
Re: Gm oil pan?
No get the F BODY OIL PAN. your just gona end up wasting money
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
