My cam choice
Old Mar 16, 2011 | 01:36 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
My cam choice
Hey guys, I got a quick question about my lq4 and cam decision. Heres my specs so far:
1984 Trans Am converted to 1988 Formula
3.45 geared 9 bolt for now
2003 lq4 short block
factory dished pistons
TEA stage 3 5.3 heads with 58cc chambers
.650" lift springs
ls7 caddy lfters
Hardened pushrods
T56
spec 3+
I currently have a ms4 and a tr224 sitting on my shelf. Everyone tells me that the ms4 will give me piston to valve clearence problems.
What will the power differences be between the two cams?
Should I get my pistons fly cut so I can run my big cam?
I plan on running about a 100-125 shot on nitrous
Should I look into buying a new set of pistons for the spray taht are already fly cut?
What would you do in my situation?
Old Mar 16, 2011 | 05:59 PM
Pocket's Avatar
Car: 91 Trans Am
Re: My cam choice
Sounds like a good question to post in LS1tech. Alot more of the LSx community rolls through there than here. I will say its always good insurance to use the clay to check PTV clearance vs listen to online help. Same for measuring PR length vs guessing with aggressive cams
It does sound like a nasty 6.0 though
Old Mar 16, 2011 | 07:22 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: My cam choice
I can't help you on the PTV clearance question, but the power difference can potentially be between 35-50hp difference.
Texas Speed's site claims a 30-35hp gain over a stock motor with the 224R, and up to 80hp gain over a stock motor with the MS4.
Old Mar 16, 2011 | 08:15 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: My cam choice
MS4 is too aggressive a cam for your gears. I wouldn't use it unless you go to 4.xx gears. If not then you'll have a lot of trouble getting the car rolling in first gear with the T56 and the car will be pretty slow until you get revved up to about 4500 RPM or more.
Old Mar 16, 2011 | 08:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: My cam choice
Put the ms4 in and check for PTV. Its a decent sized cam and would be better with steeper gears but it should work ok well tuned.
MS4 will make a good bit of power over the 224 and the MS stuff loves spray. I wouldnt fly cut and spray but some guys have done that just fine. If you had an idea how much PTV you had, i'd sell the 2 cams you have and get a custom grind with a tad bit less duration than the MS4 and maybe a tad bit less lift as well.
Old Mar 16, 2011 | 09:40 PM
BlueZee28's Avatar
Re: My cam choice
Thats not entirely true. I agree to some extent but I have been driving mone with the MS4 with t56 and 3.42 gears for a year now and it's not as bad as you'd think. There's a bit of cam surge or "bucking" at low speeds/rpm, but it's doable. It might be annoying in a daily driver but certainly wouldn't keep me from going with that cam over the 224. I'm swapping for 4.10's in a couple of weeks which will help get rid of most of that issue though. The thing I love about this cam is it's an absolute screamer in the upper register.
Old Mar 16, 2011 | 10:12 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Rear gears aren't an issue because I'm going to upgrade to a stronger rear end with 4.10, 4.30 or 4.56 gears depending on tire size. I'm just worried that I'm going to under cam my engine. I guess I could buy new speedpro pistons and scat rods for 600$ or so. I'm just not sure what way to go.
Old Mar 16, 2011 | 10:14 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
That the exact situation I'm in right now. Can I run a thicker head gasket for more space??
Old Mar 16, 2011 | 10:25 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Old Mar 16, 2011 | 10:30 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: My cam choice
Does this car need to be reliable or is it a toy? Hard decision with a set of nice heads that could be destroyed.
Old Mar 16, 2011 | 11:00 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Needs to be a reliable toy it's just a weekend drag car toy
Old Mar 17, 2011 | 07:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: My cam choice
Unless you can find someone running this exact combo, you wont know if that cam will fit or not til you try it. It certainly wont be undercammed with the MS4.
Old Mar 17, 2011 | 06:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: My cam choice
All you need to do is call Texas Speed and ask them what heads you can use with the MS4 on a stock LQ4 short block. They've put enough engines together to know. No need to use exactly the heads you have in mind. There are other good options out there.
Old Mar 17, 2011 | 11:56 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
I can't find a single person with a lq4,ms4 and 58cc heads.
Old Mar 18, 2011 | 12:03 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
I called them and they won't tell me anything for whatever reason. The 58cc heads aren't heads I have in mind. They are new tea stage 3 5.3 heads that I already have.
Old Mar 18, 2011 | 07:13 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: My cam choice
Sure they will. You just asked the wrong question. Tell them you have an LQ4 short block and you're wondering if you can use their 5.3 heads with the MS4 cam. If they say no, then ask if any heads can be used with stock pistons. Believe me, they will be quite helpful if they think you are shopping for a set of heads with that cam.
If both answers are no, then you should consider the MS3.
Old Mar 18, 2011 | 08:33 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
I tried twice now. First time I said tea and matt wouldn't say anything. Second time I tried I said I wanted 58cc to up my compression to 11:1 and said not possible with a ms3 but wouldn't say how much needed cut.
Old Mar 18, 2011 | 12:40 PM
BlueZee28's Avatar
Re: My cam choice
Why not get some 317's if you want to run that cam? You can pick up a bare set of those heads for around $100.
Old Mar 18, 2011 | 01:01 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
I have a set of 317, but I have a amazing set of tea so why not use them
Old Mar 18, 2011 | 01:46 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: My cam choice
The problem also lies int he head itself man, the TEA heads actually drop the valve height outward towards the piston, losing even more PTV. A set of 243 heads would have been the way to go. See if you can find someoen to trade you, ported for ported or the 243s and some cash your way, 243 heads milled .030 wil clear with the MS4, mt Trex clears with .110 with 317s and the 243 and 317 have the same valve height.
Old Mar 18, 2011 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: My cam choice
Just run a smaller cam then with the heads you have. If they still have good port shape and flow well, you wont give up much with a cam with less lift and duration. These motors do well with mild cams because of the intake/head flow.
Old Mar 18, 2011 | 03:59 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Smaller like ms3 that won't need as much ptv?
Old Mar 18, 2011 | 06:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: My cam choice
exactly, something like that. If you had an idea of the valve opening/closing points you can kinda measure the lift til you hit the piston at various degs after the valve begins to open until it closes. It can give you an idea what cam profile will fit. You can just hang the valve on the head with the valve locks only with dial indicator on valve stem, and rotate the motor with deg wheel til you contact the valve and then sweep the range, getting an idea of the lift curve and duration points on the deg wheel for each valve.
example, Comp 285ls hr13.... it opens 32 deg BTDC and closes 72 deg ABDC advertised. you will have most of the lift coming in between 32 deg btdc and like 70 deg ATDC.
Exhaust valve opens 88 deg BBDC and closes 30 deg ATDC. So most of your lift concerns will be between that 30 deg ATDC closing point and something like 70 ABDC. Just rough figures i'm not exactly sure what numbers it will be.
Old Mar 18, 2011 | 09:23 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
You sir are very smart. I'll try that. On a plus side I hear the ms3 loves spray lol.
Old Mar 18, 2011 | 09:59 PM
BlueZee28's Avatar
Re: My cam choice
Both of the magic sticks love spray, you can't really go wrong with either one.
Old Mar 18, 2011 | 11:09 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Did you lay down 420whp on stock heads?
Old Mar 18, 2011 | 11:26 PM
BlueZee28's Avatar
Re: My cam choice
317's
no porting and polishing, stock valves, just enough shaving of the deck to get a smooth surface
Old Mar 19, 2011 | 03:09 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My cam choice
LS engines love spray, you can't really go wrong with either one.
Fixed it for you
Old Mar 19, 2011 | 06:07 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
317's
Wow thats pretty impressive. My buddy has a 02 and either a magicstick 3 or 4 and made 420 with evey bolt on and tsp ls6 heads. How much extra power is the .3 liters worth lol
Old Mar 19, 2011 | 06:08 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Originally Posted by ZONES89RS
Fixed it for you
Good call
Old Mar 19, 2011 | 08:25 AM
BlueZee28's Avatar
Re: My cam choice
Most of the gains in the extra few cubes is in the torque from what I've seen and heard. It takes a LOT to get the 5.7 over the 400 ft/lbs mark.
Old Mar 19, 2011 | 01:36 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My cam choice
Well, IDK what my 89 is making at the back tires, but pulling the tires off the pavement and turning 7.1 at 97 at 3450 race weight is doing something right, stock 317s milled ,030.
Old Mar 19, 2011 | 04:37 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: My cam choice
I have tea 317's and love them. For a good all around camshaft if you were to buy one id look in the 230-240 range... Bigger isnt always better.
Old Mar 19, 2011 | 04:39 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
What does that convert to in the 1/4?
Old Mar 19, 2011 | 06:11 PM
BlueZee28's Avatar
Re: My cam choice
31 @ 24mph...
It snapped the driver side axle first time out in the water box.
Edit: nevermind. I just re-read the post and I originally thought you were shortening convertible to convert. LoL
Old Mar 19, 2011 | 06:32 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Lol it's cool. A guy on ls1tech said the most you can fly cut stock pistons is .120. Can anyone tell me if I will for sure be able to clear a ms3 cam? If I can find out I'll buy the cam and have my buddy check my ptv for me so I can get my stuff cut.
What y'all think? Also any hp guesses?
Old Mar 19, 2011 | 08:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: My cam choice
Can you assemble it with the MS4 you have now and see what happens with PTV? You will need to make a makeshift solid roller or use a very lighweight checking spring to measure everything
Old Mar 19, 2011 | 09:22 PM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Can I use a little thicker head gasket to give me some extra ptv clearance?
Old Mar 19, 2011 | 10:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: My cam choice
Yeah you can but watch your quench height...too much will hurt performance alittle, and may be detonation prone. You can also try advancing the cam on the install to get some clearance here and there...depends on how much you have to begin with. Atleast check with that cam first to get a starting point on how much room you have
Old Mar 20, 2011 | 10:31 AM
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
Am I correct in thinking that a thicker gasket will help me clear a ms4? Speed Inc has cometic gaskets from .040 to .120 thick. How thick should I need?
Old Mar 20, 2011 | 11:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: My cam choice
yes a thicker gasket will help gain clearance but how much is needed is not easily known unless you had an idea how much clearance you have to begin with. I'd rather see proper gasket thickness for the engine and have a cam made to fit instead of trying to fit a cam by throwing gasket thickness at it.
Old Mar 20, 2011 | 09:25 PM
  #42
1badeagle's Avatar
Engine: 370 LSX
Re: My cam choice
I'm gonna try to put the cam in this week.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
