OIL PAN
Old Mar 30, 2011 | 02:45 PM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
OIL PAN
has anyone use this oil pan on there swap
http://paceperformance.com/i-6255531...-nova-etc.html
Old Mar 30, 2011 | 03:15 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: OIL PAN
Only use a Fbody pan!!!!!!
Old Mar 30, 2011 | 03:59 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: OIL PAN
I believe the problem with that pan is that it's too deep and sticks down below the crossmember.
Old Mar 30, 2011 | 04:58 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: OIL PAN
this question comes up at least once a week.
fbody pan is the only one that does not hang lower than the kmember. stick with that one if you don't want issues with speed bumps and potholes.
Old Mar 30, 2011 | 05:05 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: OIL PAN
Not just that. On some, the part in front of the sump is too deep and gets crushed against the kmember, and the sump could stick too far forward blocking where your y pipe should go.
Old Mar 22, 2020 | 01:19 PM
Anderson84's Avatar
Car: 1984 Camaro Sport Coupe
Engine: SBC 355
Transmission: Turbo 350 w/shift kit
Axle/Gears: 10 bolt 3.55 gears, locker
Re: OIL PAN
Streetstuff
Apr 28, 2017 11:36 AM
GND-646
May 31, 2010 09:42 AM
mw66nova
Apr 7, 2010 12:04 PM
five7kid
Sep 22, 2009 08:52 PM
techrunner
Apr 14, 2009 07:02 PM
