This air intake setup work for ls1 swaps?
Old Jun 21, 2011 | 12:45 AM
daddy33's Avatar
Car: '85 Camaro
I've heard some people use a GTO air intake setup for there cars. Well eBay has there cheap set ups in my price range lol. Anyways you think this setup will work? Here is a link:
http://cgi.ebay.com/ebaymotors/PONTI...#ht_3099wt_830
Old Jun 21, 2011 | 12:53 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: This air intake setup work for ls1 swaps?
the only thing id be concerned with is clearing the upper rad hose but besides that it looks good...BUT remember that the filter being open is just sucking in hot air from the engine bay...can do what i did
cut a hole in the battery tray on the side that your canister is on and run the filter in front of the tire right under the tray...cold air from outside thus making a cold air intake..
made a noticeable difference for me and it sounds cool..can hear the air being sucked in..haha
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
looks like itll work. whichever random radiator hose the we picked out drops down and then goes into the block. which i kept the part number for you guys.
Old Jun 21, 2011 | 01:03 AM
daddy33's Avatar
Car: '85 Camaro
Yeah I was thinking cutting out that tray area and run it down lower for the cold air like you said.
Intimidator Z, do you have those hose part numbers?
Old Jun 21, 2011 | 01:04 AM
daddy33's Avatar
Car: '85 Camaro
Oh and itsMikey, do you have a pic of your intake setup if it's similar to this?
Old Jun 21, 2011 | 01:52 AM
Car: 1987 IROC
here it is right here. its dayco part number e72077 the only issue i had was the hose is a little bigger then the neck but i just put 2 hose clamps and it works fine.
http://www.autozone.com/autozone/par...ntifier=885202
heres how it sits on my car.
from a little different angle:
Old Jun 21, 2011 | 10:15 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i bought this exact kit but couldnt use it due to the size of the tb i had on my ls3 intake (90mm too big for their kit). when i get my new parts, I'll do a mock fitting for ya to see how it fits otherwise.
Old Jun 21, 2011 | 06:25 PM
daddy33's Avatar
Car: '85 Camaro
1aDan if you have pic of the intake setup that would be sweet, just to see what I'm working with. I have a stock TB so it shouldn't be a problem fitting there.
Old Jun 21, 2011 | 07:09 PM
Pocket's Avatar
Car: 91 Trans Am
93-95 3.4 V6 upper hose. Put the long leg on the radiator and the short on the WP. Intake will fit underneath perfectly
Not a bad deal on the kit, quick glance looks like it may fit both the 3 wire and 5 wire MAFs. Mine was about $120, $30 x2 for the bends, $30 filter, $8 x2 couplers, $4 x5 clamps
Heard mine too, always a loud "shhhhhhhhh" when the car was shut off
Old Jun 21, 2011 | 08:03 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
looks good ^
Old Jun 22, 2011 | 05:27 PM
daddy33's Avatar
Car: '85 Camaro
Well maybe next week I might just order it and try. Just waiting for a few more parts. I'll be going speed density so I hope it won't be different not having a MAF
Old Jun 29, 2011 | 11:17 PM
daddy33's Avatar
Car: '85 Camaro
Got that kit from ebay today. Fitment is pretty good actually, maybe a little tight though near the p/s lines. But $70 for everything I guess you can't go wrong. I eventually wanna get about 6-8" more of the piping and kick it out toward the fender a little more, then cut the tray area and extend it down there. Just kinda mocked it up for now though just to show you guys how it looks....
Old Jun 30, 2011 | 12:50 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i grabbed my new DIY intake from siliconeintake.com for a reasonable price, may be worth checking out if you're just looking for tubing. looks to fit pretty well for ya. between the rain and sprained ankle, I've been a failure at anything photo & car related.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
