Using '98 coolant temp sensor sender for autometer gauge
Old Jul 14, 2011 | 06:08 PM
daddy33's Avatar
Car: '85 Camaro
Kinda like the title says. I bought an AutoMeter electric gauge and of course it comes with the sender. Now on my ls1 I am using a '98 coolant temp sensor. So instead of putting the autometer gauge sender, can I just tap into the ls1 CTS wire and use that as the "sender" wire to the autometer gauge? I hope this doesn't sound confusing. I just don't want to put another plug/sensor into my cylinder head lol. Thanks in advance!
Old Jul 14, 2011 | 06:40 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Using '98 coolant temp sensor sender for autometer gauge
remove the plug on the opposite cylinder head and buy the autometer adapter then screw it in
Old Jul 14, 2011 | 07:29 PM
daddy33's Avatar
Car: '85 Camaro
That's my thing, I really dont want to put in another sensor/sender if i dont have to.
If the 98 CTS has 3 wires and I'm sure one of them has to be a signal wire reading the temp. If so, I would just like to splice into that wire and run it to the back of my autometer gauge that requires the "sender" wire.
Old Jul 14, 2011 | 07:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How sure are you that the 98 sender is compatible with an aftermarket gauge?
Old Jul 15, 2011 | 02:34 PM
Pocket's Avatar
Car: 91 Trans Am
If the ohm range of the autometer sender is similar to the range of the 98, why wouldnt it work?
Old Jul 15, 2011 | 02:46 PM
daddy33's Avatar
Car: '85 Camaro
Thanks pocket for the GM ohm specs. I checked out autometer's gauge ohm reading and the slightly differ from the GM cts. Guess I'll just run the sender where the plug is in the passenger head.
Old Jul 15, 2011 | 04:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In the LS1/T56 car, I used an Autometer sender in the passenger side head for my Equis temp gage, and it works just fine.
In the other car, the Autometer sender did NOT work properly with a stock gauge, while the '98 factory type sender works fine with the stock gauge.
For what that's worth...
Old Jul 16, 2011 | 05:38 PM
daddy33's Avatar
Car: '85 Camaro
This s starting to **** me off. I bought an electrical gauge to ditch the hassle with the mechanical one. Now I bought the adapter 2277 that was told to use for the autometer sender but now that doesn't work! The adapter will screw into the head but the sender doesn't fit all the way into that 2277 adapter.
Now what???
Old Jul 18, 2011 | 11:25 PM
five7kid's Avatar
I drilled out the adapter so the sender would fit through it. Just don't over-do it.
Old Jul 18, 2011 | 11:42 PM
daddy33's Avatar
Car: '85 Camaro
I'm starring at the adaptor and thinking of the same thing lol. I was just told I need the sender #2259 which I'll have to spend another $10 for this. Stupid, almost $20 just in fittings.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
85Special
Sep 3, 2015 04:21 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
