tossing belts like its my job
Old Aug 7, 2011 | 02:12 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Been tossing belts lately non stop, seems the tensioner spring can't keep up with how quick the motor revs and the belt gets slack for a second and then the pulley bends forward and the belt walks right off. Bought a speed inc solid tensioner and the buick 3800 supercharged idler pulley dayco #89009 which has higher grooves cut into it and haven't had an issue since, hopefully it stays that way. Did have to add 2" total length to run that new pulley as its larger diameter. Anything over 7000 rpm and off it went, hopefully now that's all done
Old Aug 7, 2011 | 07:36 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: tossing belts like its my job
7k's pretty high, but glad to hear you've got things under control. i never liked the idea of pulleys without shoulders (like the giant bell we have for a water pump). I had my belt fly off in my GTP (similar water pump pulley) because I hit a puddle, no fun.
Old Aug 7, 2011 | 07:41 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went with a Katech tensioner. Zero issues as well now.
Old Aug 8, 2011 | 09:25 AM
Pocket's Avatar
Car: 91 Trans Am
Solid mount idlers are not tensioners. Serp belts are designed to stretch as seen with the tensioner being on a spring. When its static. Ask the SC guys about that who havent added a blue million high ridge idlers
To the OP, make sure your pulleys are lined up and bearings good. Bad tensioners and bearings are the most common reason for belt loss on LSx engines
Old Aug 8, 2011 | 12:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Tensioner is brand new as was the pulley. Apparently they don't have a very long shelf life above 7k. I know that after 50 miles or so you're supposed to redo the tension on the belt, then check it periodically with a solid one, no different than sbc engines for the past 25 years.
Old Aug 8, 2011 | 01:43 PM
Pocket's Avatar
Car: 91 Trans Am
If you converted it to a V-belt then set a static tensioner, the problems wouldnt be here. Its a serp belt and they're designed to stretch
Old Aug 8, 2011 | 02:17 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Same. Season five now 7K RPM and never even checked the belt tension to see if it had changed. I spit belts like crazy with the stock tensioner
Old Aug 8, 2011 | 02:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Glad I'm not the only one cam
Old Aug 8, 2011 | 02:32 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I started shredding belts after a round of mods... I blamed it on my p/s pulley being out of alignment.
I put the supercharger pulley on, and adjusted the belt size (car came with an ASP underdrive and the belt was too long). I havent had an issue since and Ive touched 7k on occasion. Though I was throwing them way before that.
You should be fine with the new pulley and everything else in check.
J.
Old Aug 8, 2011 | 02:35 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I hit 7K daily.... at least once or thrice. Gotta love the sheer terrifying WAIL of LS1 fury roaring through a single Aerochamber at 7K....
Unparalleled
Old Aug 8, 2011 | 10:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Not sure I like the sound of my gen 3 motor compared to my gen 1 built motors. Something from the tone is missing, can't put my finger on it, maybe the new one is too raspy, not really sure.
Old Aug 8, 2011 | 10:15 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
We just finished a custom 3.5" stainless exhaust through a single in/out Aerochamber on my nephews car.... Pure horrifying TERROR wailing out of that thing now. Its one of the scariest sounding street cars Ive ever heard
Old Aug 9, 2011 | 06:43 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i get alot of the typical, "what are you running?!?!?" comments when i'm at the track cause of the cars tone through 3" dual x-piped exhaust with bullets. anything over 4,000 rpm sounds like the world is coming unhinged.
i'm running a stock replacement tensioner and pulley. steve, i know you're not running ps, how do you have the belt routed from the alternator to the water pump? do you have the factory smooth idler with the belt going under the pulley (similar to stock) or are you running a grooved pulley with the belt going over the pulley? (this would give more wrap around the water pump) i'm running it the second way and don't have any problems.
here's an old picture, but it'll give you an idea:
Old Aug 9, 2011 | 08:33 AM
xpndbl3's Avatar
Car: 1984 Z28
Just the water pump, crank pulley, alternator and the new solid tensioner now. No extra pulley like you run, probably because with the smooth pulley it wouldn't work, never thought about adding the grooved pulley to flip where the belt is routed. I'm taking it out to another car show tonight, we'll see how it ends up doing, luckily I have another spare $32 belt in the back of the car now in case something happens, but had no issues putting 60 some miles on it the other night so hopefully it's all done.
Old Aug 9, 2011 | 08:46 AM
mw66nova's Avatar
Engine: 7.0L
that's why you're throwing belts. i've done 7500rpm burnouts in high gear with no issues with throwing belts. (that's why my hoosier only lasted 2 months, lol)
Old Aug 9, 2011 | 02:14 PM
xpndbl3's Avatar
Car: 1984 Z28
eh tons of people run it the way I am without issues from what I've seen online, not sure I want to buy more belts this season What's that another 2" of belt length....sheesh. I better buy stock in dayco.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
