LOOK HERE!!! cheap source for new LS1 fbody oil pans
Engine: Cammed 6.0L LSX
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: LOOK HERE!!! cheap source for new LS1 fbody oil pans
woot! it's about damn time!!!!!
Engine: 7.0L
you can get all that for under $60 though, and you're still $40 cheaper than summit for the SAME P/N!
Exactly
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
Engine: 7.0L
Car: '89 Firebird
Engine: 7.0L
I thought everybody knew about that.
That's the pan I put on my engine. Just FYI, it uses a LS3 oil filter (example: 2010 Camaro). You'll also want to remove the windage tray and clean out metal filings from machining. They do a pretty sloppy job and you don't want that crap in your oil.
Car: 1988 RS Camaro
Transmission: TH400
Axle/Gears: Stock
Thanks for the heads up on the taking it apart and the oil filter.
Just do a search for oil pan in this section of the forum, you're bound to find numerous threads about different oil pans that won't work and why this is the only one that fits our cars.
Engine: 7.0L
i found this in 10 secs using our search function:
https://www.thirdgen.org/forums/ltx-...erent-oil.html
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
you do not need the windage tray, that is the baffle that is talked about in the description according to their parts department. great people to deal with. they will be getting a sizeable order from me shortly on my 6.0L build.
The "baffle" is an entirely different part than the windage tray aka crankshaft oil deflector.
You can see what i'm talking about here (this is a baffle):
http://vorshlag.smugmug.com/gallery/...17898397_RG3eX
Car: 91 Z28
Engine: 6.0L LQ9
i'm well aware of the difference thank you, not looking for a pissing match...just passing along the information that i was given over the phone. i will make sure and double check with them before ordering.
It was an informative post, not a taunt.
It would definitely be a good idea to double check with them as I had to order my tray separate as well as the pick-up tube. The baffle came tightened down onto the pan.
Car: 91 Z28
Engine: 6.0L LQ9
just put my order in guys...here is what you need to make it a complete swap:
12628771 - Oil Pan
12558251 - Pickup Tube
12551581/12551577 - Dipstick & Tube
12558253 - Windage Tray
11609746 - Nuts for windage tray (Qty 9)
All for less than $270 shipped to your door. Most of the pans I've seen on tech are going for $200 used with just the pickup.
You probably won't find a better deal on GM parts from anyone.....
12628771 - Oil Pan
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
im gonna keep saying it...
use Search Tempest..
Found my LS1 oil pan kit used from a guy in FL for $75 shipped.
Car: 91 Z28
Engine: 6.0L LQ9
cool site(thanks for the info, i used to use craiglook.com before they shut it down), i'm more comfortable using a new pan on this build however.....
So what's this about "pan DOES NOT have provisions for a dipstick tube"? I just ordered the pan. Will I not be able to check oil quantity when the engine is in the car? Also, I ordered the windage tray and pickup tube. Do I need to get the nuts for the tray too? Thanks
Engine: 7.0L
the dipstick hole is in the block smart guy
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I have had this site bookmarked for a few months now, starting to get the feeling I should buy this before they raise the prices!
Jay
Jay
If you already have a truck wind age tray, simply cut the front off and it will fit a fbody pan
Saves a few bucks
Saves a few bucks
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Was it always $198 for just the pan? Whew
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
If cost matters, then modding the common, virtually free truck pans are a valid option. And modding the tube to move the screen up is also proving cheap and easy. Likewise the truck dipstick just needs shortened and re-marked. I'll give measurements on all these details in my own thread as soon as practical. But my total investment in this is a cutter wheel for my angle grinder, though a hacksaw could work if you have more time than money, plus a small plate of aluminum, and a small tube of that metallic epoxy. Heck, even if you include details like masking tape, a sharpie, a tap, a drill bit, and 4 1/4" bolts, you're still under $50.
After much measuring I'm only 5/8" at most above the Spohn mounting, and the Trans-Dapt 4536 mounts on new stock V6 rubber mounts saved me well over $ 100 over Spohn's stuff, and all stock cross-members are factory pre-drilled for the V6 rubber mounts. The rubber is captured in steel, so it should hold plenty of power.
I have at least 1/4" of clearance between my pan and my cross-member, and there's only one little place where it's that close.
Bolt-together is nice, but it'll end up at least $ 300 more than my way. That $ 300 will get you a new 216/220, 560/560, 114 cam from Summit, including shipping and handling.
Or $ 300 will get you a new pair of the cheapest headers, delivered.
So why put money in something that doesn't make the car perform measurably better?
I should add that I do regret not buying the oil filter before final-cutting the pan, and the feed tube. I have spares, so no disaster, but still. I went with the AC Delco PF46E / Fram 3506. As fragile as an aluminum pan may seem, the filter is far more fragile. So don't let it hang below the pan.
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
