5.3 swap
Old Nov 4, 2011 | 04:37 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Transmission: th400 with 3500 stall
5.3 swap
I have couple of questions , and i am sorry if this has been posted before , i searched google and didnt find anything , but i just bought a 2008 5.3 that it came with dbw tb for 200 bucks with out the ecm and the wiring , i just recently went to the jy and found an ecm and complete wiring harness for a 4.8 , the ecm serv.no. 09354896 and hdw no. 16220610 and i was wondering if that would work? i am going to switch it from dbw to cable , but i was just wondering before i purchase that tomorrow. thank you and again sorry if it has been posted
Old Nov 8, 2011 | 11:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I may be wrong about this, but as I understand it the cable vs. DBW was more year related than engine size related.
I would tend toward getting harness/PCM for the type of TB you plan on using, just to keep it simple.
Old Nov 8, 2011 | 12:53 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Re: 5.3 swap
well i went ahead and got the wiring and pcm , but my injectors wont connect and its a cable tb , and i am going to change it so no biggie but , i am wondering why the injectors differ, its off of 06 silverado , and the motor is 08
Old Nov 8, 2011 | 12:59 PM
five7kid's Avatar
I don't know details, but there were several different injector connectors used.
Old Nov 11, 2011 | 09:29 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: 5.3 swap
Your best ecm option is an 0411 which is found in most LSX vehicles (trucks/cars) and i wouldnt even bother messing with the injectors from trucks or the intake, if its complete on the engine you bought, unbolt it complete, huck it on ebay and use that $ towards a complete LS1 or LS6 intake thats loaded and ready to bolt on.
Old Nov 13, 2011 | 06:06 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Re: 5.3 swap
yeah i am trying to sell the intake, a friend of mine is sellin ls1 intake for 125 , it comes with everything.
Old Nov 14, 2011 | 06:24 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 5.3 swap
i had a similar injector setup issue. wiring was from a 00 silverado but the ls1 intake/injector setup i was using had different connectors. chopped off the ends (saved em just in case), soldered in a set from an LT1 caprice. Upgraded to a 6.0 w/ L92 heads and LS3 intake/injectors. Different again (shouldnt have cut off the old ones!). However, was able to find some adapters (did not want to solder again) at a very reasonable cost. only downside - they say ford on em! guess there's a trade off somewhere...
neilb
Oct 4, 2018 12:36 AM
z28addict8490
Sep 5, 2015 03:56 PM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
jharrison5
Aug 19, 2015 05:53 PM
