92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress
Old Jan 26, 2012 | 05:48 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Ah, so it's been a great ole time this winter in my one car garage doing everything. Anyhow, I'm selling the 5.0 motor which ran perfect, just wasn't enough power for me. I just sold the wc trans with a bunch of stuff for $750, and pretty much this has been quite the experience.
The stickies written are outdated and many of the questions remain unanswered like.... there's no clear description or example of WHAT you need to do in order to make your fuel lines work.
There's also no clear indication on what kind of fuel pump people have used. Fuel pump isn't even listed in the sticky, it's just known that you can reuse a tpi fuel pump, not a tbi becuase of the low pressure.
People are also very confused about what radiator hoses. I will figure that out personally and provide pictures with what part numbers I used and what I did if I modified them.
The list below is for reference, for my records, and for anyone that is wanting to attempt this swap. Some things I bought that weren't "necessary", but might as well change them since the engine is out.
I need: (about $1990.89~ remaining not including rear end parts)
Engine
- LT1 (pending sale atm...70k slp motor for 1300 shipped)
- obd1 computer matching engine
- A way to manually tune the engine myself, as I may go with a lt4 hot cam
Clutch Hydraulic Primary Rod Length
- To modify hydraulic primary rod length as it's too long = reduce length somehow
Fuel Pump
- 255lph ($150~?)
- ?Unknown right now?
Fuel Pressure Regulator
- ?Unknown right now? Would prefer one that's a dial under the hood
- ($25-$100?)
Fuel Lines
- ?Unknown right now? I'm not going to use tommy (z28ricer), stole people's money before.
- ($..no clue)
PS Lines
- For the HP Line - 95 Impala SS
- AdvanceAutoParts - 91780 - $36.99
- For the Return Line - PS line, it sells by the foot
Radiator Hoses
- For the Lower Hose - Buy a 87-93 Mustang 5.0 upper hose (~$12)
- For the Upper Hose - 95 roadmaster upper / 95 camaro Z28 (~$10)
- Y-Pipe - Hedman - 17478 - http://www.summitracing.com/parts/HED-17478/?rtype=10 - $125.95
- Headers - Hedman - 68479 - http://www.summitracing.com/parts/HED-68479/?rtype=10 - $255.95
Rear End (Still contemplating)
- Spacer - http://www.summitracing.com/parts/MGR-075050/
- Install Kit - http://www.summitracing.com/parts/RAT-308TK/
- Bearing Spacer - http://www.summitracing.com/parts/RAT-4111/
- Marking compound - http://www.summitracing.com/parts/RMG-5500011/
- Support Cover - http://www.summitracing.com/parts/SME-8510400/
- 4.10 Gears - http://www.summitracing.com/parts/SUM-741015/
I have: (spent $1521.62)
Transmission
- T56 - 50k miles, 5.0 pro shifter (from 96 camaro) - $1150.00 shipped
- Bellhousing t56 to lt1 (from 96 camaro) - Inc w/above
- Hydraulics (master and slave) (from 96 camaro) - Inc w/above
- Crossmemeber w/ new hardware - Spohn T-56 - #T56XMR - $125.65
- Trans Mount - Spohn - #D-7-1604 - $25.95
Torque Arm Bushings
- Spohn Polyurethane - #D-7-1609 - $21.07
Wiring Harness
- Made by pocket - $150 shipped
- Purchased from 1badeagle
- Prewired for lt1 for a 94 ta
- Currently working on repinning...
Engine Motor Mounts
- Polyurethane Motor Mounts - #D-7-506 - $48.95
Old Jan 26, 2012 | 05:49 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Re: 92 Camaro RS 5.0 T5 - LT1/T56 Swap Thread Progress
Reserved for pics #1.
Attached Thumbnails 92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-dscf1250.jpg   92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-dscf1254.jpg   92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-dscf1276.jpg
Old Jan 26, 2012 | 05:50 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Reserved for pics #2
Attached Thumbnails 92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-dscf1277.jpg   92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-img_1167.jpg   92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-img_1169.jpg
Old Jan 26, 2012 | 05:52 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Reserved for pics #3
Attached Thumbnails 92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress-kgrhqz-qee63z2hzgebp-sy7jtl-60_3.jpg
Old Jan 26, 2012 | 05:53 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Reserved for pics #4
Old Jan 26, 2012 | 05:54 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Reserved for pics #5
Old Jan 29, 2012 | 05:21 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Re: 92 RS 5.0TBI T5 - LT1/T56 Swap Thread Progress
Guess no one is interested in swaps anymore unless it's a LSx. :-\
Was hoping to finally put to rest some of the most questionable things, like hydrualics, hoses, etc.
Will update as I progress
Old Jan 30, 2012 | 10:44 AM
TexasLT1's Avatar
Car: '92 RS
All of your questions in your first post were answered in my LT1 swap guide which unfortunately no longer exists.
1. There are a number of different ways to do this, up to you. I ran a barbed fitting on both lines with adapter fittings to get to whatever the 3rd gen fuel fittings are, then heated/pressed the plastic LT1 fuel lines onto the barb fittings. Never had any problems with it. Someone made a set of nice fuel lines for a while but I haven't seen them recently, don't know if they're still being made.
2. "TPI fuel pump works" is a pretty clear indication. Any replacement pump for a TPI car will work. Walbro 255 is the most popular.
3. LT1 Corvette upper and F-body lower if memory serves correctly. Been too long since I've done it. I used cut-to-fit hoses for a while with no issues.
As far as your list:
Clutch hydraulics - don't modify anything. You're doing something wrong if you are changing the rod length.
Fuel pump - covered
FPR - stock LT1
Fuel lines - that's who I was thinking of. not surprised.
Everything else looks pretty good. Honestly I'd stay away from 4.10 gears though. They're fun, but I took mine back out and went with 3.73's.
Old Jun 30, 2012 | 09:46 AM
blackjack12982's Avatar
Anymore progress on this? It's looking like I'll end up selling my other toy, so I'll have a bunch of money to dump into my 92 RS.
TheFool
Mar 7, 2014 04:04 PM
dippin88
Feb 8, 2010 08:34 PM
Motopsyco
Nov 24, 2009 03:19 AM
Dante93GTZ
Dec 28, 2001 03:40 PM
90FFBird
Nov 16, 2000 10:33 AM
