what tubular k-member to go with for lsx swap
Old Mar 11, 2012 | 01:02 PM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
Well I been looking into replacing my factory k-member for a tubular one for my lsx swap and Im not sure which one would work best. I plan to run a coil over setup in the frt and run my stock control arms till I get the funds to buy the tubular ones So I guess the BMR k-member is out of the question since its noted will not work with oem control arms. Let me know what your running on your setup and how you like it?
Thanks.
Old Mar 11, 2012 | 02:07 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Re: what tubular k-member to go with for lsx swap
i have spohn with spohn a arms everything works great! really nice clearance too. I had a bad oil leak ,but fixed now .Name:  IMAG0263.jpg
Old Mar 11, 2012 | 03:08 PM
nhra-trans-am's Avatar
I also have spohn, but with stock A arms. I am happy with it.
Old Mar 11, 2012 | 03:33 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Spohn with stock arms, happy as well.
Old Mar 11, 2012 | 07:54 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
I thought most of the Spohn k members had rubbing issues? I am not done with my swap but i have mounted up my BMR unit with their a-arms and it fits perfectly. Also does the new UMI unit use factory control arms. If so I would definately look at it.
Old Mar 11, 2012 | 08:25 PM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Yea I seen the umi has k-members now, I was looking at them price is t bad to well there on sale right now.
Old Mar 11, 2012 | 08:49 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
Have the spohn lsx crossmember under my car also. It bolted up perfect, looks and fits great but I did have to shim the passenger side motor mount a little.
Old Mar 20, 2012 | 08:07 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have the Spohn too, but there is some contact from the tie rods. Can I flip the center link for more clearance?
Attached Thumbnails what tubular k-member to go with for lsx swap-img_1680resize.jpg
Old Mar 21, 2012 | 11:09 AM
Car: !991 RS Camaro
I had to flip my center link for the same reason. I had a tie rod hitting my a/c compressor is how I noticed the engine wasn't level.
Old Mar 21, 2012 | 11:49 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have a Spohn K-member. The quality of construction is very good and the overall fit is good. My only complaint is that my engine sat crooked with it. I adjusted everything as much as possible but it would not sit level. I had to modify the engine mount on one side to shim it up to make up the difference. The Spohn K-member seems to be hit and miss. If I were going to buy another I would try one of the other companies such as UMI or BMR.
Old Mar 21, 2012 | 12:14 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
X 3294 for spohn
Old Mar 22, 2012 | 08:57 AM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
I'm running a Spohn kmember. Install wasn't too difficult and haven't had as much problems as others have had, but wouldn't recommend it to anyone.
Going with a UMI one for my bros swap, and will replace mine with one as well sometime down the road.
Old Mar 22, 2012 | 10:39 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
run away from Spohn
https://www.thirdgen.org/forums/ltx-...-member-2.html
I have BMR k-member as well as A-arms.
Old Mar 25, 2012 | 10:28 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Does the BMR k member allow for AC in the factory location?
Old Mar 25, 2012 | 03:05 PM
Car: 91 z28
Transmission: 4L60e
Yes, with F-body accessory drive.
Old Mar 25, 2012 | 03:33 PM
Car: 91 z28
Transmission: 4L60e
I have also heard good things about PA Racing, I did not go with them because thier site did not list LS1 application. However, they do offer one.
Old Apr 7, 2012 | 08:07 PM
Pocket's Avatar
Car: 91 Trans Am
Spohn here, wouldnt recommend it to anyone either
Old Apr 8, 2012 | 03:00 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
im going with pa racing for mine.. its the cheapest and i have talked to them over the phone and if there is any short of fitment issue they said they would fix it right away..
Old Apr 24, 2012 | 04:23 PM
LivinLarge's Avatar
Any reviews on the new UMI K member or Racecraft K member?
Old Apr 25, 2012 | 01:37 PM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
I was looking at the umi k-member and right now its a pretty long wait for a k-member and i dont wanna drop 700 bucks and wait 2 monts for one.
Old Apr 26, 2012 | 07:59 AM
Fireball's Avatar
Car: 1984 Camaro Sport Coupe
Engine: RHS/LSx 427
Transmission: Powerglide
Axle/Gears: Fab9 3.00 gears
Whats the consensus on the BMR unit? I want to ditch the OEM steering box in favor of a manual rack, so having that option is nice
Old Apr 26, 2012 | 09:08 PM
Car: 91 z28
Transmission: 4L60e
BMR, $529 + $90 (spring perches), A-arms $ 450, great product, cannot use factory A-arms, offers coil over, and pinto rack options.
PA Racing, $319 + $50 (LS1 motor mounts) + $50 (spring perches, upper), A-arms $270 + $50 (spring perches, lower), great product, will accept factory A-arms, offers coil over, pinto rack, and will custom build to your needs.
Spohn, $540, A- arms $425, horrible product with multiple design issues, will accept factory A-arms
UMI, $620, A-arms $463, new to the market (no reviews), will not accept LS1 AC compressor in stock location, will accept factory A-arms
Quick list, PM with any corrections and I will update.
Old Apr 28, 2012 | 08:08 PM
Rich92 RS's Avatar
Transmission: T56's
One thing I didnt like about the new UMI Kmember is, it will not accept the LS1 AC compressor in its stock location.
Old Apr 30, 2012 | 08:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Spohn here. No issues UMI arms though. Had Spohn arms and threw everything out of whack.
Old May 2, 2012 | 11:06 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
spohn here,had to modify passenger side motor mount to have engine fit,but does sit level,have engine in and trans,and headers mounted no issue visible waiting on harness to mount accersories
Old May 8, 2012 | 09:29 AM
evo-offer's Avatar
what would choose between: pa racing k-member or bmr? for me it doesn´t matter if i can use stock a-arms.
Old May 8, 2012 | 11:55 AM
blakecharles's Avatar
until you decide, just notch the stock K and call it a day.
Old May 8, 2012 | 01:22 PM
evo-offer's Avatar
Did you answer to me?
Old May 8, 2012 | 06:46 PM
rickyzZ28's Avatar
Car: 1990 RS
As I stated above I would go BMR. I have one with their A-Arms and everything is bolted up nice and straight. I do not know about the PA racing one, but know they make some nice stuff.
Old Nov 15, 2016 | 05:31 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Hey guys I've been hunting around wondering this same question that everyone does. My car is an 89 LQ4 swap, will be equal drag/street (half drag use but will also just hurt feelings on the streets when I want to). Here's the conflict, UMI has the double tube on bottom which would help with strength but BMR's is lighter than umi which would help with my goal of getting the car under 3,000 lbs. not worried about ac fitting. Been removed awhile. Prices are negligible (umi $600 shipped, BMR $595 shipped), a arms will be replaced as well. Can anyone suggest the better of the two for my application? Thanks!
Old Nov 15, 2016 | 07:26 AM
indebt's Avatar
I have BMR. Installed perfect with no problems. Running regular springs. Here's a 20% coupon for BMR, SR20. Definitely recommend. Check out my build thread where I have a pic.
Old Nov 15, 2016 | 07:34 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
i have used both and i prefer the UMI road race over the bmr.
the bmr unit has its a-arm mounting points constructed in a way a lot of other a-arms will not fit as an option. also i had an alignment issue with the one i used, the umi has locating pins as the factory k member. the umi allows use of different motor mount options as you bolt the bracket to the k member vs being integral in the bmr case
Old Nov 15, 2016 | 11:14 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Running a BMR, excellent fit, only concern is you cannot use solid mounts due to the fixed motor mounting points.
Old Feb 1, 2019 | 01:39 PM
Soulstis's Avatar
Car: 90 Camaro RS
Engine: LQ4 6.0L
Transmission: 4l65E
I know this is an older thread, but what motor mounts did you use?
i have this bmr - https://www.hawksmotorsports.com/cam...coil-over-kit/
Old Feb 1, 2019 | 07:33 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Keeping my fingers crossed as to the Dan Lemon headers and Moroso aluminum oil pan on my big block all working out...with the UMI K member..New waters for this combo
UMI and I talked about sending a K member to Dan for a jig.. but in the last days...I did the ..Ya it should Fit EYE ball thing...Im a bit nervous...its a money shot in the dark...lol.. if they don't fit.. ill have to go with the make that dan uses for his jig..and ..well.. this one will be up for sale.. but we will see..
Side note: will ask UMI to make me one...($) cash is King! I will be doing a Video on the full set up/install..this has taken 9 years of gathering parts.. test fitting a lot of manufacturers parts..some I sold after test fitting. now I have every thing in the aftermarket to bolt on... I can say UMI makes some Fantastic parts..I like there K member the best out of the 3 that I have had/test fit..
Old Feb 2, 2019 | 12:15 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Went back to stock clam shell with poly mounts.
Old Oct 2, 2020 | 01:08 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Sorry for old thread bump here. But does anyone know what’s different about the BMR that won’t allow the stock arms? Guessing you have to use their a arms then or no? Just wondering as I have the K member with rack mounts going in my Trans Am. Interested in going coil over as well eventually but don’t want to purchase a arms with pockets if I end up going that route.
Old Oct 2, 2020 | 03:22 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
BMR keeps stock geometry (according to them) but the features of the k-member itself bump up against the stock a-arms, so you have to use their a-arms. I've never seen where it bumps, assuming it is in the pockets that they form around the pivots.
You can see a picture of the pockets in Post #104, https://www.thirdgen.org/forums/ltx-...ml#post5438142
Old Oct 2, 2020 | 03:42 PM
CKone's Avatar
Yup I can see exactly what you’re talking about. Looks like I have the same K member as yours perhaps. I need to pull it off the shelf and out of the box. Just wish I had an extra set of a arms I could experiment with and see where they interfere. I’ll get there soon enough I suppose lol
BumpaD82
24
Feb 11, 2013 08:56 AM
bangin96z24
Oct 21, 2012 12:47 PM
Spdsteve16
17
Apr 3, 2011 04:09 PM
HP52TA
Feb 7, 2011 11:02 PM
