Fuel rail to use truck injectors on car intake?
Old May 13, 2012 | 06:40 PM
croozer's Avatar
Ok, so I had the idea of trying to look around for a fuel rail, possibly one of the billet aluminum ones, that can use a truck style injector with a car style intake. Specifically the LS1 intakes. What issues would I come across while trying this? Any suggestions on where to start?
Croozer
Old May 14, 2012 | 06:43 PM
southbay08's Avatar
Re: Fuel rail to use truck injectors on car intake?
which injectors are you looking to use?
Old May 14, 2012 | 07:57 PM
croozer's Avatar
The stock truck style injectors from an '01 tahoe. I bought a used LM7 last june and was curious if it would even work to use an aftermarket aluminum extruded rail. I don't know if the top part of the injector is the same on the truck and car style injectors. They are a 22lb injector, pn 25326903 non flex fuel.
croozer
Old May 14, 2012 | 08:18 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
You would need an injector spacer. The stock injectors are very short.
Old May 14, 2012 | 08:29 PM
croozer's Avatar
This is the Truck style injector I am talking about.
I need a spacer for this style? I thought that it was the car style ones that needed spacers when being used on a truck rail. I want to do away with the car style rail and injectors, and use the truck injectors with a different aftermarket rail if possible.
Croozer
Attached Thumbnails Fuel rail to use truck injectors on car intake?-746-resize.jpg
Old May 15, 2012 | 08:27 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
I am talking about spacers to make the injector taller.
The spacers for the car injectors are to space the rails up.... just the opposite to what you are doing.
Old May 16, 2012 | 08:49 PM
croozer's Avatar
Ok, I think I understand where you are coming from. If I used a fuel rail like the one attached that vejatabul posted, then I would also need a spacer correct? If this is correct then where is a place where I can look for a place to buy these spacers? The reason why I want to go about it this direction is to try and do something out of the ordinary.
Croozer
Attached Thumbnails Fuel rail to use truck injectors on car intake?-vejatabul.jpg
Old May 28, 2012 | 01:37 AM
croozer's Avatar
does anyone know where I can find these spacres to use truck injectors on a car fuel rail?
Croozer
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
92projectcamaro
Aug 6, 2015 01:20 PM
