front spring
Old Jun 25, 2012 | 02:17 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
front spring
What is everybody using for front springs in there lsx swap? I have stock springs and tubular kmember with an aluminum ls1 i have noticed that the front sits higher then before. Will v6 springs work? I perfer to stay away from lowering springs, I like the stock height. Any Inputs?
Old Jun 25, 2012 | 03:18 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
Re: front spring
I chopped my stock Iroc-z spring 1/2 coil and my car is absolutely straight/level with the ground. The ride/handling is good too.
Old Jun 25, 2012 | 07:47 PM
kevinc's Avatar
Car: 1982 Z28
Re: front spring
Cutting 1/2 coil seems to be the trick, I have used both Moog 5662 as well as GM WS6 front springs on mine...both minus 1/2 coil to set the ride height.
The Moogs are significantly stiffer and not very pleasant on bumpy streets, but are excellent on road courses. The WS6 springs are a good compromise but the car nose-dives during really hard braking.
Old Jun 26, 2012 | 04:02 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Re: front spring
I was running Eibach Sport-line lowering springs on mine when I had the old L98 engine in it. And I did a lot of searching here on tg.org on what to do with the springs when an LS is in the car, so I cut my Eibachs 1/2 coil as everybody (including me now) were saying, but with those springs cut 1/2 coil the car was almost on the ground and totally undriveable , so be aware of what type/brand of spring that you cut. But as I mentioned before, my stock Iroc-z spring cut 1/2 coil made it super nice
Old Jun 27, 2012 | 06:02 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Re: front spring
did anyone try v6 front springs?
Old Jun 27, 2012 | 07:12 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
Re: front spring
A little older thread that might be of help:
https://www.thirdgen.org/forums/ltx-...uspension.html
Old Jun 27, 2012 | 07:35 AM
Rpk250's Avatar
Car: 91 Camaro RS - 87 Buick GN
Engine: LS6 - Turbo Buick
Transmission: 4l60E - 200R4
Re: front spring
I had to cut a half coil off of a set of Bell Tech 2" lowering springs to get it down just under stock ride height.
Old Jun 27, 2012 | 10:25 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: front spring
Eibach sport springs. Used from a member here. Height and stance are perfect for me. No cutting or removing isolators at all.
Tho...we'll see what it looks like with the iron 6.0 vs the LS1. I think I have a LITTLE room for the front to drop so should be ok.
J.
Old Jun 27, 2012 | 03:36 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Re: front spring
Yeah I wish I´d kept my Eibachs uncut just like Ghettocruiser...;-)
Old Jun 27, 2012 | 07:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
Probably not the best view, but it sits a little high with V6 springs.
Not so bad on the launch, though...
I cut half a coil off of V8 front springs for the LS1/4L60E car. It sits pretty much like it did with the Gen I SBC with iron heads and TH700.
Old Jun 28, 2012 | 01:14 AM
nhra-trans-am's Avatar
Re: front spring
I'm using a tubular k-member with v6 springs
Old Jul 14, 2012 | 07:54 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Re: front spring
i was thinking to go that route. does the car sit level now?
Old Jul 14, 2012 | 10:17 AM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: front spring
I'm running Eibach Sportlines in the front and new stock springs in the back. Tubular Kmember and spring isolators all around. Sportlines in the rear had the car almost raked the opposite way.
Old Jul 14, 2012 | 11:51 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Re: front spring
car sits nice!
Old Jul 14, 2012 | 12:01 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: front spring
Hotchkis springs here with tubular k and an iron block. I will post a pic later but it doesnt sit higher than the rear, pretty even. I love the look.
Old Jul 14, 2012 | 05:42 PM
Re: front spring
Yes it sits level, I can take a pic if you'd like.
Old Aug 4, 2012 | 11:56 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Re: front spring
Yes take one if you don't mind.
Old Aug 8, 2012 | 10:39 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: front spring
This is how mine sits with one whole coil cut off
A inch or so drop in the rear would look good imo, but its fine for now.
Old Aug 9, 2012 | 06:20 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Re: front spring
So I ended up cut a coil off the front and 1&1/2 off the rear. These are new spring btw.
Old Aug 9, 2012 | 04:15 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
Re: front spring
Jimmy92rs. What size tires you have on that?
Old Aug 9, 2012 | 10:02 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Re: front spring
245/ 40r18 in the front and 295/30r19 in the back
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
