LT1 Engine mounts needed
Old Aug 25, 2012 | 04:54 PM
Chumnums's Avatar
Car: 1992 Camaro Z28
Engine: lT1 383
So, Im putting doing an LT1 swap. engine from 93 vette into 92 z28 camaro. the mounts do not fit the chassis mounting holes but fit the block. the drivers side is like a triangle shape an the other is rectangular. any suggestions or help?
http://s-seriesforum.com/albums/Part...0560.sized.jpg
Old Aug 26, 2012 | 09:37 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Engine mounts needed
Your stock v8 clamshell mounts will bolt on the lt1 block.
Old Aug 29, 2012 | 05:08 PM
Chumnums's Avatar
Engine: lT1 383
Re: LT1 Engine mounts needed
will they handel 500 hp?
Old Aug 29, 2012 | 05:26 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
the next step would be motor plates, wouldn't they? I'm doing poly mounts w/ stock clamshells. Mine is supposed to be at about 425 RWHP once it's back together.
Old Aug 31, 2012 | 05:13 PM
Chumnums's Avatar
Engine: lT1 383
awesome sounds good man. thank you. i apreciate it
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Elliswon
Aug 10, 2015 12:33 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
