tpi same wiring on lt1
Old Sep 11, 2012 | 03:10 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
I was wondering since I have a maf tpi could I use the maf change the intake and heads and new bigger block and tune the maf and ecu to it?
Old Sep 11, 2012 | 04:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi same wiring on lt1
Originally Posted by 87hellbird
could I use the maf change the intake and heads and tune the maf and ecu to it?
If you just want to mod a MAF TPI engine , then the stock ECM can be tuned for almost any mods
No idea what you are talking about comparing LT1 to a TPI
Completely different ECM and wiring ,LT1 engine requires LT1 controls ( and you don't want to be putting LT1 heads on a Gen 1 block)
Old Sep 11, 2012 | 06:36 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
To use an LT1 long-block, you'd still need to mod the intake for a distributor and account for EGR delete in the tune. To use the heads and intake manifold only, water passage differences at the deck need corrected.
With the higher compression ratio of the LT1, a cooling effect of the EGR system is going to gain mileage and do nothing bad to power.
Personally, I'd do the full LT1 swap. Or if you have the LT1 engine only, do the coil-per-plug 0411 PCM swap.
Lots of information in the Engine Swap forum.
Old Sep 11, 2012 | 08:04 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can't marry an optispark to a '165 or '730 ecm?
-- Joe
Old Sep 20, 2012 | 11:28 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
What I was talking about was putting the lt1 engine in and still use the tpi ecu and wires and maf
Old Sep 20, 2012 | 11:43 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
We know, but the issue is you need to be able to pick up distributor ref pulses, and fire the coil. The optispark on an LT1 probably speaks a different language than the HEI on a TPI car.
-- Joe
Old Sep 20, 2012 | 01:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You would have to mod the intake to take a TPI distributor and eliminate the Opti entirely.
(Did someone already say that?)
Old Sep 20, 2012 | 06:16 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
You would have to machine (drill) a hole for the distributor, make a spacer for the distributor, buy the GM optispark blockoff plate (http://www.summitracing.com/parts/NAL-12367600/), use the TPI throttle body and keep the factory TPI wiring harness and 165 computer.... you can't use the LT1 EGR anymore either.
I did it to a 1996 Corvette Grand Sport LT4 in my GTA.
Kevin
Old Sep 20, 2012 | 08:17 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What is the difference in signals from the opti to the dizzy?
I've read some info about a megasquirt working with an opti by using two of the 4 pins. You can't change the constants in the bin to work with opti?
-- Joe
Old Sep 20, 2012 | 08:40 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I did just that. Welded my lt1 timing cover holes shut.. running an ewp
Drilled the intake welded a spacer to intake. Dropped in a MDS Pro Billet distributor.
Im running my stock 1992 TPI 7730 harness and ecm. ($59 code for boost)
Thinking of swapping to a 411 pcm swap but using a vortec distrib. for ref. signal. vs the 24x setup.
OP, just redo your harness for a compete LT1 swap and save your bucks for a 24x / 411 pcm swap.
This is what I should have done from the start
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
