Craigslist Searching + My Apartment Room + LSx = ?????
Old Dec 23, 2014 | 11:22 AM
  #251
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Craigslist Searching + My Apartment Room + LSx = ?????
Yea I wish it was that easy lol but I got a new harness from pocket and its new from connector to pcm lol
Old Dec 23, 2014 | 11:32 AM
  #252
Engine: 305 to 350
Axle/Gears: 10 Bolt
I think it's the PCM I thing the guy that I sent to mess something up with the computer or the tune is off
Old Jan 2, 2015 | 05:11 PM
  #253
Engine: 305 to 350
Axle/Gears: 10 Bolt
Got it to idle , mess with hptuner for hour or 2
Increase idle to 900 and around 1100 when cold
Adjusted idle air flow
Thinking of getting stock maf sensor to see as I'm running ported ends and no screen and I hear it increases tuning difficulty
All and all it idles then when engine idle drops to 800 and below engine starts to backfire here and there and starts adding fuel well more like dumping fuel
Some pics of narrowband and STFT
During scan engine runs fine till like said above then you see why it starts to backfire some cells are +25 , from what I seeen +/- 3 isn't too bad but damn lol will play with it more but that's where I'm at now
So small step forward and victory lol
Old Jan 6, 2015 | 03:18 PM
  #254
Engine: 305 to 350
Axle/Gears: 10 Bolt
Figured out why I was leaning , don't use Allen header bolts doesnt create a good seal for header , going to dial it in some more in coming days was trying to tune around it so I'm start from scratch to see if it be closer to how I like
Ran from cold to 220 no back firing at all till it reach around 220 and it backfire here and there
Next step is to hit the street and dial in STFT and LTFT ,PE
Old Jan 7, 2015 | 09:53 PM
  #255
Engine: 305 to 350
Axle/Gears: 10 Bolt
Old Jan 8, 2015 | 03:23 AM
  #256
pmcruz781's Avatar
Car: 1986
Transmission: t56
Axle/Gears: Auburn 3.73 posi moser axles
Your car sounds sick man, congrats on figuring out the problem
Old Jan 8, 2015 | 07:15 PM
  #257
Engine: 305 to 350
Axle/Gears: 10 Bolt
Thanks sure got brain working hard lol
Yea it's hooker max flow muffler long tubes and 3in y into 4in still got to finish the rest of exhaust will be 4" still contemplating on getting a cut out
Old Jan 9, 2015 | 08:17 AM
  #258
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
definitely sounds good zach, nice and deep.
Old Jan 9, 2015 | 11:45 AM
  #259
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea in loving it , should souubd little deeper at idle once i try drop idle from 900 rpm in try around 700-800 rpm and see if she idle only had it idle higher so I can get it to idle and gather airflow numbers etc I'm really digging this tuning thing
Old Jan 15, 2015 | 07:53 AM
  #260
Engine: 305 to 350
Axle/Gears: 10 Bolt
So even tho engine sound good just didn't sound right
I still have dead cylinder #6
So plugs look rich and some look lean I think because since O2 sensing a lean condition due pcm dumps fuel then take it out then dumps fuel again then takes it out as when I look at my scan the STIT jump from 0 to -50 to +50 back and forth which didn't seam right and running that is impossible
Going to run this weekend when I get chance hopefully I cured the issue as now I'm getting spark
It was due to the fact that the harness Pin #28 was push in and when harness was plug up it never made contact with pcm so hence no signal I feel like a idiot not checking something so simple lol but I slide pin back down and rep lug to pcm now I get spark sigh was getting really frustrated and took 3 day break to refresh
Old Feb 15, 2015 | 11:39 AM
  #261
Engine: 305 to 350
Axle/Gears: 10 Bolt
Wife is going to be mad at me lol
Should have trans back in Tommorrow
Old Feb 15, 2015 | 06:26 PM
  #262
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Whoa, dude what happened
Old Feb 15, 2015 | 06:29 PM
  #263
Engine: 305 to 350
Axle/Gears: 10 Bolt
I have no idea a installed converter and space it from flex plate according to spec
I'm thinking damage previously kinda should of check it out prior too me getting trans even tho it was rebuilt maybe it was never rebuilt prob just changed out the clutches
Old Feb 15, 2015 | 06:53 PM
  #264
92BLKL98's Avatar
Well to replace clutches kind of dictates a rebuild, This is not a difficult trans to rebuild just a few special tools but the pump rotor could have been cracked. The torque converter snout slides into and drives the pump rotor. I believe that if you push the converter too far you can break the pump rotor. Had the car been driven yet?
I am working on mine now with the intent of using the 4L60E and don't want to have any trans issues. I'm hoping for 400+ RWHP I hope it can handle it.
Old Feb 16, 2015 | 12:16 AM
  #265
Engine: 305 to 350
Axle/Gears: 10 Bolt
I upgraded my trans myself and built it , difficult part s is removing it and installing I do everything thing myself and haven't had another body to help lol which makes it a long tiring day
I'm referring to the previous owner stating it was rebuilt
IMO just throwing new clutches in and calling it a rebuilt trans with out making the need modification updates at a minimum is just considered a freshen up tranny to me and far from a rebuilt tranny
All in all its a easy fix but I just don't have the time to put into trans which I know I can do I rebuilt it already and wait for parts etc etc so just decided to take to a trans shop to do it in 1 days time and with it being a busy weekend already just seem to be the right choice for me
I already aware of what to do with converter as far as clearances but you are correct with a improper installed converter jacks up a pump instantly
Just upgrade 3-4 clutches and do a shift kit to take care of some weak points in trans get a very good tranny cooler and run AMSOIL atf synthetic and should be fine
Old Feb 16, 2015 | 02:40 AM
  #266
92BLKL98's Avatar
Oh yeah I agree with the Amsoil and cooler I plan a complete overhaul. I have done many other trans overhauls (All Ford transmissions and GM 3 speeds) but not the 4L60 series is it a big deal, I plan to do this one myself with upgraded internals and a Vigilante converter.
Old Feb 16, 2015 | 09:47 AM
  #267
Engine: 305 to 350
Axle/Gears: 10 Bolt
No it ls real easy just need about 4 tools it's not big deal , I would rebuild another one but just don't have the time or trans would sit for another 2 weeks or so
Old Feb 16, 2015 | 03:32 PM
  #268
92BLKL98's Avatar
Which tools do I absolutely need? Just looking at the tool list makes it look more advantageous to have it done. Heck doing the old Ford AODE took just a few tools, this thing looks like a whole tool box is required. I know some stuff you can improvise but some pieces appear to be needed.
Old Feb 16, 2015 | 04:27 PM
  #269
Engine: 305 to 350
Axle/Gears: 10 Bolt
Mainly the rear clutch and and input spring compressor EBAY has them for under 40 there deep in case so it needs a specialty tool some feeler gauges to check clearances long flat head and some picks that's pretty much it
Just pick up trans from shop
If you have the time to do it the do it it's easy me personally I like to have that feeling I had my hands on everything vs having shops do everything for you , I will build another again someday
Old Feb 16, 2015 | 06:14 PM
  #270
92BLKL98's Avatar
Thanks for the info bro didn't mean to hijack your thread. Glad you got the tranny back. I will build mine, going to ebay now. I just need the spring compressors, lip seal tool and I'm good.
Old Feb 17, 2015 | 02:30 AM
  #271
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea pretty much
Just finish putting it back in will try to take a drive tomorrow for some datalogging
Old Feb 20, 2015 | 11:35 PM
  #272
Engine: 305 to 350
Axle/Gears: 10 Bolt
I think i found a pair of wheels I can settle , posted my wheels for sell just to see what's out there , a guy was interested but wanted to sell his wheels first good thing I ask what wheels i offered to trade deal and I couldn't refused the deal
But alittle tease
Old Feb 21, 2015 | 07:29 AM
  #273
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
But alittle tease
You are a TEASE!
Old Feb 21, 2015 | 11:59 AM
  #274
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol I know , well hopefully I get to put milk bucket on ground finally with no other surprise
Removing and putting in trans is my list fav thing to do
They soooo nice looking tho lol
Old Feb 21, 2015 | 06:05 PM
  #275
Engine: 305 to 350
Axle/Gears: 10 Bolt
Old Feb 21, 2015 | 06:09 PM
  #276
Engine: 305 to 350
Axle/Gears: 10 Bolt
Old Feb 21, 2015 | 07:14 PM
  #277
Engine: 305 to 350
Axle/Gears: 10 Bolt
True Hid projector retrofit from skinnyboy
And hid yellow fogs
Old Feb 21, 2015 | 09:18 PM
  #278
WTR388's Avatar
Car: 87 Trans Am
Very sharp, what are those tire sizes?
Are you putting the trans in and out with the car on jack stands? How horrible is that job?
Old Feb 21, 2015 | 09:30 PM
  #279
Engine: 305 to 350
Axle/Gears: 10 Bolt
19x9 19x10.5
255 and 275/35
There Hre 590rs
Yes putting tran in and out on jackstands
I won't say it horrible but it takes me like 4-5 hours too pull it out myself and same amount of time to put back in
It's just very tiring doing so I won't say horrible if I had help could probable do it in half the time
Old Feb 21, 2015 | 09:51 PM
  #280
WTR388's Avatar
Car: 87 Trans Am
I have to pull mine out, have a 4th gear syncro issue which is why I asked.
I was going to do it in the garage on my own, but I figured I would wait until April, I'm headed to a new base where they have a really good auto hobby club with a lift.
I read you are in the military, I've been in the Canadian Army as a medic for over 8 years with a combat tour in Afghan, I've just switched over to a nice cushy Air Force trade working on aircraft so I'm back in the training system. (Hijack over)
Old Feb 21, 2015 | 10:30 PM
  #281
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol no worry I'm navy corpsman aka medic with marines just got back from afghan end of last year served in Iraq also been in 11 years
When I was in afghan worked a lot with the Brits army air force and Royal Navy and Jordan's ,afghan and Iraq army etc and others never had chance to work with the Canadians yet tho
It's all good
You have a 6 speed ? There easy too and lighter trans to bench press lol
I used 4 jack stand and to jacks with small ply wood
Old Feb 21, 2015 | 10:40 PM
  #282
92BLKL98's Avatar
I removed my 700R4 last weekend on jacks, about 4 hrs. They aren't as easy as they were when I was 25 years old, and seems the 4L60 is heavier than the 3 speed autos.
Old Feb 22, 2015 | 12:04 AM
  #283
Engine: 305 to 350
Axle/Gears: 10 Bolt
700rt and 4l60 is same trans yea I'm 29 and it's hard for me still
Old Feb 22, 2015 | 12:36 AM
  #284
Engine: 305 to 350
Axle/Gears: 10 Bolt
Reverse glow gauges
Old Feb 22, 2015 | 07:48 AM
  #285
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Those wheels are sexy as can be! Wish I could find a cheap solution to my gauges for my gta. Oh well I'll be happy when ohio decides to warm up and I can get my swap buttoned up. Swaps looking good the keep it up!
Old Feb 22, 2015 | 09:25 AM
  #286
WTR388's Avatar
Car: 87 Trans Am
How much are you budgeting for gauges? Take a look at my swap thread, I used speed hut gauges, custom built for order, digital with the analog look and a great price for the quality, super happy with them, they look like a really nice stock set in a trans am, perfect fit.
Old Feb 22, 2015 | 10:32 AM
  #287
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
That's the way I'd probably eventually go but Im just cheap and don't want to shell out the cash.
Old Feb 22, 2015 | 10:50 AM
  #288
Engine: 305 to 350
Axle/Gears: 10 Bolt
Mines are just a overlay I wanted stock gauges still I don't care for much on aftermarket gauges and like them I even changed the bulbs to led probably spent 40 bucks total
http://pages.ebay.com/link/?nav=item...d=161525275505
For you firebird guys
Old Feb 22, 2015 | 11:29 AM
  #289
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
That's amazing. I almost bought something like that years ago but the stopped. Consider it ordered till I feel like paying out for new ones.
Thanks man
Old Feb 22, 2015 | 09:18 PM
  #290
92BLKL98's Avatar
Yup
Old Feb 22, 2015 | 09:42 PM
  #291
Engine: 305 to 350
Axle/Gears: 10 Bolt
Are you keeping trans stock ?
Old Feb 23, 2015 | 11:48 AM
  #292
92BLKL98's Avatar
My plan is to install performance band and clutches ensure it has the stronger 5 pinion planetaries and sun shell 13 vane pump and a Vigilante torque converter. I want it to handle whatever I throw at it (within reason). It will be a street driver with maybe some strip use.
Old Feb 23, 2015 | 12:00 PM
  #293
R13_Braz's Avatar
Car: 2014 Z28 #80
Duuude.. Nice wheels! Almost exactly what I will be going for, except way more $$$ lol. I was looking at the TSW Valencia's... Half the cost of new HRE's.
Old Feb 23, 2015 | 01:09 PM
  #294
Engine: 305 to 350
Axle/Gears: 10 Bolt
It's not really necessary to upgrade to 5 pinion
Some must reads before jumping in
http://www.impalassforum.com/vBullet...orumsite/21007
http://gmlongroof.4umer.com/t6394-common-4l60e-problems
And where I got my stuff from
http://www.700r4l60e.com/store/home.php
Thanks yea the look good but down come wider than 9.5 and not much selection but nice if your happy with that
I was lucky and got them thru a trade deal for wheels I had
Old Feb 23, 2015 | 01:27 PM
  #295
R13_Braz's Avatar
Car: 2014 Z28 #80
That's the only part I don't like.. only coming as a 9.5". I WANTED to go to 315 (I'm going to need it for my build), but will have to settle for 295's... maybe 305 if I don't mind the slight bulge... I don't know.
I've got 17x8's right now with 275's on the rear and they fit surprisingly well.. very little bulge and perfect tire contact. /shrug
Old Feb 23, 2015 | 04:12 PM
  #296
Engine: 305 to 350
Axle/Gears: 10 Bolt
Decisions decisions lol
Old Feb 23, 2015 | 05:13 PM
  #297
BADNBLK's Avatar
COTM Editor
And hid yellow fogs
Looks KILLER!!!! Gotta be damn proud to find a smoking deal on HRE's, and it looks like the offset is correct too. You gonna pull the rear fenders or what to keep from cutting a sidewall?
Old Feb 23, 2015 | 06:34 PM
  #298
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea pretty stoke can't stop looking at her finally starting to have that complete feeling now just need to beautify her
I had rolled rear fenders awhile back ago when I had 18x11
These don't rub what so ever in pic above rear end isn't aligned I just installed a adjustable Panhard bar so we correct that when I get a chance
Took her for a spin around the block and WOW Really feels like a modern car now well even better than a modern car can't wait to step on it has and brakes and carve some turns , last time I drove her i only had stock tpi and sportlines and wider wheels , but now with everything it feels totally different
Old Feb 24, 2015 | 05:13 PM
  #299
BADNBLK's Avatar
COTM Editor
From that pic it sure looked like it would rub. Glad it doesn't. Sure looks good man. I bet that is a great feeling. I'm putting my LS stuff together right now, and I'm looking forward to that feeling.
Old Feb 24, 2015 | 08:42 PM
  #300
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea for some reason it does look like it looking at pic but I can ensure it doesn't
Yea I haven't driven her for 2 years and just been completing the swap here and there as one allowed or shall I say as much Uncle Sam lets me off the lease lol it's been very slow process , it started in my apartment working on her in rain and out side parking area but now live on base and have garage so it's more easier and where I'm stationed at I just luck out having a lot of free time so it's very good feeling kinda like a kid in a candy store lol
Kinda mad cause I wanted to drive her this weekend to do some more datalog and tuning but I'm in the field all week lol sigh
Your car looks far cleaner then mines as I started on performance upgrades vs beauty , so I'm kind of embarrassed on cosmetic part but that will be my main focus for now since all performance upgrades are done
What you have plan for your LSX swap
